[资料分享] 车辆乘员检测参考设计TIDEP-01001
871|2
 楼主| dirtwillfly 发表于 2019-3-31 22:06 | 显示全部楼层 |阅读模式
描述
This reference design demonstrates the use of the AWR1642 single-chip mmWave sensor with integrated DSP as a vehicle occupant detection sensor enabling the detection of occupants in a vehicle. This design provides a reference processing chain that runs on the C674x DSP, enabling generation of a heat map to detect occupants in a field of view (FOV) of ±60 degrees. Watch Vehicle Occupant Detection using mmWave Sensors Video.
Additional Information
特性
  • Demonstration of mmWave sensor technology for robust detection of occupants (adults, children, pets) in a vehicle
  • Generate presence heat map with FOV of ±60 degrees
  • Source code for processing and detection based on mmWave software development kit (SDK)
  • Based on proven EVM hardware designs, enabling quick time to market and out-of-the-box demonstration
  • Radar front-end and detection configuration fully explained
 楼主| dirtwillfly 发表于 2019-3-31 22:08 | 显示全部楼层
车辆乘员检测参考设计.pdf (6.69 MB, 下载次数: 0)
AWR1642 Evaluation Module Single-Chip mmWave Sensing Solution User's Guide.pdf (1.87 MB, 下载次数: 0)
 楼主| dirtwillfly 发表于 2019-3-31 22:16 | 显示全部楼层
AWR1642BOOST Design Database.zip (7.48 MB, 下载次数: 1)
AWR1642BOOST Schematic, Assembly, and BOM.zip (1.09 MB, 下载次数: 0)
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1199
