 Waiting for HC(S)08 reset ACK (timeout: 10s)...rb returned 1 data:fc,
 received 0xfc (good).
 wb(fc,) returned 1
 wb(49,) returned 1
 rb returned 1 data:88,
 rb returned 1 data:1,
 rb returned 1 data:4a,
 rb returned 4 data:0,0,0,1,
 rb returned 4 data:0,0,10,0,
 rb returned 4 data:0,0,80,0,
 rb returned 4 data:0,0,0,0,
 rb returned 4 data:0,0,2,0,
 rb returned 4 data:0,0,0,40,
 rb returned 1 data:4b,
 rb returned 1 data:45,
 rb returned 1 data:30,
 rb returned 1 data:32,
 rb returned 1 data:0,
 Bootloader protocol version: 0x08 (Kinetis, read command supported)
 CRC protocol NOT supported)
 Bootloader version string: KE02
 System device ID: 0x14A [Kinetis K60] rev. 0
 Kinetis Package: 144-pin .
 Number of memory blocks: 1
 Memory block #1: 0x00001000-0x00008000
 Erase block size: 512 bytes
 Write block size:  64 bytes
 Original vector table: 0x00000000-0x000003FF
 New vector table: 0x00001000-0x000013FF
 S19 Image Control.
 Parsed S-record lines: 320  Bytes total: 5076
 Source address range: 0x0400-0x2713
 The S19 image also contains redirected vectors. The automatic redirection is skipped now.
 WARNING! S19 image will not fit into available memory (at address 0x00000400)!
 Memory programming block 0: W 0x00000400 0%
 prg_blk: 0x00000400-0x0000040f
 wb(57,) returned 1
 wb(0,0,4,0,) returned 4
 wb(10,) returned 1
 wb(ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,fe,ff,) returned 16
 rb returned 1 data:fc,Memory programming block 0: W 0x00001000 0%
 prg_blk: 0x00001000-0x0000103f
 wb(57,) returned 1
 wb(0,0,10,0,) returned 4
 wb(40,) returned 1
 wb(f8,b,0,20,11,14,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,) returned 64
 rb returned 1 data:3,
 Can't program block 0 at address 0x00001000
 按照网友发的 先修改了bootloader里面跳转的地址  然后又设置app icf里面的地址  分别都能单独运行 ,可是升级出现这种问题 其他网友也出现这种情况  不过 帖子都没有给出解决方法
