EasyARM8962板子遇到的问题
2636|0
 楼主| chjyu_0508 发表于 2011-10-12 23:46 | 显示全部楼层 |阅读模式
开发板是EasyARM8962,仿真器是LM LINK,开发环境是IAR5.11用了一段时间都是没问题的,但忽然出了这个问题:
The debugging session could not be started.
Either the debugger initialization failed, or else the file “F:\****\BitBand.out” was corrupt or of an unsuported format.
There might be more information in the Debug Log Window.
Debug Log如下:
Wed Oct 12 23:50:56 2011: Loaded macro file: D:\ProgramFiles\IAR Systems\Embedded Workbench 5.0 Kickstart\ARM\config\flashloader\Luminary\FlashLM3Sxxxx64k.mac
Wed Oct 12 23:50:57 2011: JTAG Speed is set to: 100 kHz
Wed Oct 12 23:50:57 2011: Warning: Identity check failed, target returned unknown AHB-AP ROM/ENTRY: 0xE00FF003/0xFDFF3F3F
Wed Oct 12 23:50:57 2011: JTAG IDCODE      = 0x3BA00477
Wed Oct 12 23:50:57 2011: AHB-AP ID        = 0x14770011
Wed Oct 12 23:50:57 2011: AHB-AP ROM       = 0xE00FF003
Wed Oct 12 23:50:57 2011: ROM Component ID = 0xFDFF3F3F
Wed Oct 12 23:50:57 2011: Device ID        = 0x00000000 ()
Wed Oct 12 23:51:03 2011: Software reset was performed
Wed Oct 12 23:51:03 2011: Initial reset was performed
Wed Oct 12 23:51:03 2011: Turning off watchdog
Wed Oct 12 23:51:06 2011: 3820 bytes downloaded and verified (1.18 Kbytes/sec)
Wed Oct 12 23:51:06 2011: Warning:
Verify error at address 0x20000000, target byte: 0xE0, byte in file: 0x80
Verify error at address 0x20000001, target byte: 0x25, byte in file: 0x01
Verify error at address 0x20000002, target byte: 0x0B, byte in file: 0x00
这种情况是用着用着忽然出现的,之前都是正常的!很郁闷。。。谷歌了一下,没有解决我这个问题的答案。
有没有高人给我指点一下呢?先谢过了!
