仿真器SEED-XDS510PLUS,DSP6713,connect错误如下:
Error connecting to the target:
Error 0x80000200/-118
Fatal Error during: OCS,
This error was generated by TI's USCIF driver.
SC_ERR_CTL_PORT <-118>
An invalid controller port value has been used.
Thus Unified-SCIF will not attempt to detect a controller
The standard 560 ports are 0x0, 0x1, 0x2 and 0x3.
The standard EVM ports are 0x0, 0x1, 0x2 and 0x3.
The standard DSK ports are 0x378, 0x278 and 0x3BC.
The standard 510 ports are 0x240, 0x280, 0x320 and 0x340.
Sequence ID: 0
Error Code: -118
Error Class: 0x80000200
I/O Port = 0
Board Name: C671x XDS510 Emulator
Cpu Name: TMS320C6710_0
Abort: Close Code Composer Studio.
Retry: Try to connect to the target again.
Cancel: Remain disconnected from the target
Diagnostic: Run diagnostic utility. |
