- #include "max6675.h"
- #include "spi.h"
- * [url=home.php?mod=space&uid=247401]@brief[/url] max66675模块初始化
- * @param None
- * @retval None
- void max6675_init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(MAX6675_CS1_CLK, ENABLE); //PORTA时钟使能
- GPIO_InitStructure.GPIO_Pin = MAX6675_CS1_PIN; // PA4 推挽 T_CS
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(MAX6675_CS1_PORT, &GPIO_InitStructure);
- GPIO_SetBits(MAX6675_CS1_PORT,MAX6675_CS1_PIN); // T_CS=1
- spi1_init();
- * @brief max6675模块读写一个字节的数据
- * @param txData:要发送的数据
- * @retval 接收到的数据
- uint8_t max6675_readWriteByte(uint8_t txData)
- return spi1_readWriteByte(txData);
- * @brief max6675模块读取测得的原始数据
- * @param None
- * @retval 温度的原始数据
- uint16_t max6675_readRawValue(void)
- uint16_t tmp;
- GPIO_ResetBits(MAX6675_CS1_PORT,MAX6675_CS1_PIN); //enable max6675
- tmp = max6675_readWriteByte(0XFF); //read MSB
- tmp <<= 8;
- tmp |= max6675_readWriteByte(0XFF); //read LSB
- GPIO_SetBits(MAX6675_CS1_PORT,MAX6675_CS1_PIN); //disable max6675
- if (tmp & 4)
- // thermocouple open
- tmp = 4095; //未检测到热电偶
- else
- tmp = tmp >> 3;
- return tmp;
- * @param None
- * @retval 温度值(单位:℃)
- float max6675_readTemperature(void)
- return (max6675_readRawValue() * 1024.0 / 4096);
