这个简单程序有调通的吗
2314|2
 楼主| klffnj 发表于 2011-10-30 21:10 | 显示全部楼层 |阅读模式
今天有空,按照附件指导,做了一个程序,没想到这么简单的一个东西,通过不了编译,
我想看看有没有做过的,是我的问题,还是系统问题
c51.exe E:\project\Design01\Design01.cydsn\Generated_Source\PSoC3\VoltageLo_isr.c NOIV LARGE MODDP2 OMF2 VB(1) PR(E:/project/Design01/Design01.cydsn/DP8051_Keil_816/Debug/VoltageLo_isr.lst) CD DB NOIP OT(2, Size) INCDIR(Generated_Source/PSoC3) OJ(E:/project/Design01/Design01.cydsn/DP8051_Keil_816/Debug/VoltageLo_isr.OBJ)
ERROR: E:\PROJECT\DESIGN01\DESIGN01.CYDSN\GENERATED_SOURCE\PSOC3\VOLTAGELO_ISR.C:30: non-address/-constant initializer
ERROR: E:\PROJECT\DESIGN01\DESIGN01.CYDSN\GENERATED_SOURCE\PSOC3\VOLTAGELO_ISR.C:32: 'val': multiple initialization
ERROR: E:\PROJECT\DESIGN01\DESIGN01.CYDSN\GENERATED_SOURCE\PSOC3\VOLTAGELO_ISR.C:32: 'val': redefinition
ERROR: E:\PROJECT\DESIGN01\DESIGN01.CYDSN\GENERATED_SOURCE\PSOC3\VOLTAGELO_ISR.C:33: syntax error near 'if'
ERROR: E:\PROJECT\DESIGN01\DESIGN01.CYDSN\GENERATED_SOURCE\PSOC3\VOLTAGELO_ISR.C:33: syntax error near '>', expected ')'
ERROR: E:\PROJECT\DESIGN01\DESIGN01.CYDSN\GENERATED_SOURCE\PSOC3\VOLTAGELO_ISR.C:33: missing ';' before ')'
The command 'c51.exe' failed with exit code '2'.
 楼主| klffnj 发表于 2011-10-30 21:11 | 显示全部楼层
VoltageLo_isr.C 文件前面部分如下
#include <CYDEVICE.H>
#include <CYDEVICE_TRM.H>
#include <CYLIB.H>
#include <VoltageLo_isr.H>
#include <OverVoltageTimer.h>
*  Place your includes, defines and code here
/* `#START VoltageLo_isr_Interrupt` */
/* Read status register to clear interrupt source */
uint32 val = OverVoltageTimer_ReadStatusRegister();
/* Get capture time and set globals as necessary */
val = OverVoltageTimer_ReadCapture();
if( val > over_max_time )
over_max_time = val;
over_count++;
/* `#END` */
zhuww 发表于 2011-10-31 21:21 | 显示全部楼层
没看出来
