想请教各路大神,关于官方提供的ISP代码中,我进入APROM后,While的循环只跑一次,就回到程序入口了,是怎么回呢?
配置中,看门狗已经关闭。
#include <stdio.h>
#include "N76E003.h"
#include "Typedef.h"
#include "Define.h"
#include "SFR_Macro.h"
#include "UART0_transfer.h"
#include "Function_define.h"
#include "ISP_USER.h"
sfr RCTRIM0 = 0x84;
sfr RCTRIM1 = 0x85;
unsigned char hircmap0,hircmap1;
unsigned int trimvalue16bit;
unsigned char temp0;
unsigned char idata temp1 _at_ 0x90;
unsigned char xdata temp2;
unsigned char PID_highB,PID_lowB,CONF0,CONF1,CONF2,CONF4;
unsigned char recv_CONF0,recv_CONF1,recv_CONF2,recv_CONF4;
/*user define*/
unsigned char countx =0;
void READ_ID_CONFIG(void)
set_IAPEN;
IAPCN = BYTE_READ_ID;
IAPAL = 0x00;
IAPAH = 0x00;
TA=0xAA; //trigger IAP
TA=0x55;
IAPTRG |= SET_BIT0;
PID_lowB = IAPFD;
IAPAL = 0x01;
TA=0x55;
IAPTRG |= SET_BIT0;
PID_highB = IAPFD;
IAPCN = BYTE_READ_CONFIG;
IAPAL = 0x00;
IAPAH = 0x00;
TA=0x55;
IAPTRG |= SET_BIT0;
CONF0 = IAPFD;
IAPAL = 0x01;
TA=0x55;
IAPTRG |= SET_BIT0;
CONF1 = IAPFD;
IAPAL = 0x02;
TA=0x55;
IAPTRG |= SET_BIT0;
CONF2 = IAPFD;
IAPAL = 0x04;
TA=0x55;
IAPTRG |= SET_BIT0;
CONF4 = IAPFD;
clr_IAPEN;
void Package_checksum(void)
g_checksum=0;
for(count=0;count<64;count++)
g_checksum =g_checksum+ uart_rcvbuf[count];
uart_txbuf[0]=g_checksum&0xff;
uart_txbuf[1]=(g_checksum>>8)&0xff;
uart_txbuf[4]=uart_rcvbuf[4]+1;
uart_txbuf[5]=uart_rcvbuf[5];
if(uart_txbuf[4]==0x00)
uart_txbuf[5]++;
void MODIFY_HIRC_16588(void)
if ((PCON|CLR_BIT4)==0xFF)
set_IAPEN;
IAPAL = 0x30;
IAPAH = 0x00;
IAPCN = READ_UID;
set_IAPGO;
hircmap0 = IAPFD;
IAPAL = 0x31;
IAPAH = 0x00;
set_IAPGO;
hircmap1 = IAPFD;
clr_IAPEN;
hircmap1 = hircmap1&0x01;
trimvalue16bit = ((hircmap0<<1)+(hircmap1&0x01));
trimvalue16bit = trimvalue16bit - 15;
hircmap1 = trimvalue16bit&0x01;
hircmap0 = trimvalue16bit>>1;
set_SFRPAGE;
TA=0XAA;
TA=0X55;
RCTRIM0 = hircmap0;
TA=0XAA;
TA=0X55;
RCTRIM1 = hircmap1;
PCON&=CLR_BIT4;
* Main function
void main (void)
//initial GPIO for quasi mode.
// P0M1 = 0x00;
// P0M2 = 0x00;
// P1M1 = 0x00;
// P1M2 = 0x00;
// P2M1 = 0x00;
// P2M2 = 0x00;
// P3M1 = 0x00;
// P3M2 = 0x00;
MODIFY_HIRC_16588();
//uart initial
READ_ID_CONFIG();
UART0_ini_115200();
TM0_ini();
g_timer0Over=0;
g_timer0Counter=5000;
g_progarmflag=0;
while(1)
if(bUartDataReady == TRUE)
EA=0; //DISABLE ALL INTERRUPT
if(g_progarmflag==1)
for(count=8;count<64;count++)
IAPCN = BYTE_PROGRAM_AP; //program byte
IAPAL = flash_address&0xff;
IAPAH = (flash_address>>8)&0xff;
IAPFD=uart_rcvbuf[count];
TA=0x55;
IAPTRG |= SET_BIT0 ;
IAPCN = BYTE_READ_AP; //program byte verify
TA=0x55;
if(IAPFD!=uart_rcvbuf[count])
while(1);
if (CHPCON==0x43) //if error flag set, program error stop ISP
while(1);
g_totalchecksum=g_totalchecksum+uart_rcvbuf[count];
flash_address++;
if(flash_address==AP_size)
g_progarmflag=0;
goto END_2;
END_2:
Package_checksum();
uart_txbuf[8]=g_totalchecksum&0xff;
uart_txbuf[9]=(g_totalchecksum>>8)&0xff;
Send_64byte_To_UART0();
switch(uart_rcvbuf[0])
case CMD_CONNECT:
case CMD_SYNC_PACKNO:
Package_checksum();
g_timer0Counter=0; //clear timer 0 for no reset
g_timer0Over=0;
break;
case CMD_GET_FWVER:
Package_checksum();
uart_txbuf[8]=FW_VERSION;
break;
case CMD_RUN_APROM:
goto _APROM;
break;
//please tool must define devices value
case CMD_GET_DEVICEID:
Package_checksum();
uart_txbuf[8]=PID_lowB;
uart_txbuf[9]=PID_highB;
uart_txbuf[10]=0x00;
uart_txbuf[11]=0x00;
break;
case CMD_ERASE_ALL:
set_IAPEN;
set_APUEN;
IAPFD = 0xFF; //Erase must set IAPFD = 0xFF
IAPCN = PAGE_ERASE_AP;
for(flash_address=0x0000;flash_address<APROM_SIZE/PAGE_SIZE;flash_address++)
IAPAL = LOBYTE(flash_address*PAGE_SIZE);
IAPAH = HIBYTE(flash_address*PAGE_SIZE);
set_IAPGO;
Package_checksum();
break;
case CMD_READ_CONFIG:
Package_checksum();
uart_txbuf[8]=CONF0;
uart_txbuf[9]=CONF1;
uart_txbuf[10]=CONF2;
uart_txbuf[11]=0xff;
uart_txbuf[12]=CONF4;
uart_txbuf[13]=0xff;
uart_txbuf[14]=0xff;
uart_txbuf[15]=0xff;
break;
case CMD_UPDATE_CONFIG:
recv_CONF0 = uart_rcvbuf[8];
recv_CONF1 = uart_rcvbuf[9];
recv_CONF2 = uart_rcvbuf[10];
recv_CONF4 = uart_rcvbuf[12];
set_IAPEN;
set_CFUEN;
IAPCN = PAGE_ERASE_CONFIG;
IAPAL = 0x00;
IAPAH = 0x00;
IAPFD = 0xFF;
TA=0x55;
IAPTRG |= SET_BIT0;
IAPCN = BYTE_PROGRAM_CONFIG;
IAPAL = 0x00;
IAPAH = 0x00;
IAPFD = recv_CONF0;
TA=0x55;
IAPTRG |= SET_BIT0;
IAPFD = recv_CONF1;
IAPAL = 0x01;
TA=0x55;
IAPTRG |= SET_BIT0;
IAPAL = 0x02;
IAPFD = recv_CONF2;
TA=0x55;
IAPTRG |= SET_BIT0;
IAPAL = 0x04;
IAPFD = recv_CONF4;
TA=0x55;
IAPTRG |= SET_BIT0;
clr_CFUEN;
IAPAL = 0x00;
TA=0x55;
IAPTRG |= SET_BIT0;
CONF0 = IAPFD;
IAPAL = 0x01;
TA=0x55;
IAPTRG |= SET_BIT0;
CONF1 = IAPFD;
IAPAL = 0x02;
TA=0x55;
IAPTRG |= SET_BIT0;
CONF2 = IAPFD;
IAPAL = 0x04;
TA=0x55;
IAPTRG |= SET_BIT0;
CONF4 = IAPFD;
clr_IAPEN;
Package_checksum();
break;
case CMD_UPDATE_APROM:
TA=0xAA; //set_IAPEN;
TA=0x55;
CHPCON |= SET_BIT0 ;
TA=0xAA; //set_APUEN;
TA=0x55;
IAPUEN |= SET_BIT0;
TA=0x55;
g_totalchecksum=0;
flash_address=0;
AP_size=0;
AP_size=uart_rcvbuf[12];
AP_size|=(uart_rcvbuf[13]<<8);
g_progarmflag=1;
for(count=16;count<64;count++)
//trigger IAP
TA=0xAA;
TA=0x55;
//trigger IAP
TA=0xAA;
TA=0x55;
while(1);
while(1);
flash_address++;
g_progarmflag=0;
goto END_1;
END_1:
Package_checksum();
break;
bUartDataReady = FALSE;
bufhead = 0;
EA=1;
//For connect timer out
if(g_timer0Over==1)
goto _APROM;
//for uart time out or buffer error
if(g_timer1Over==1)
if((bufhead<64)&&(bufhead>0)||(bufhead>64))
bufhead=0;
_APROM:
TA = 0xAA;
TA = 0x55;
CHPCON = 0x00; //set boot from AP
TA = 0xAA;
TA = 0x55;
CHPCON = 0x80; //software reset enable
/* Trap the CPU */
P00_Quasi_Mode;
while(1)
set_P00;
clr_P00;
