1、概述 HTTP web server作为ESP8266的一个常用功能,在这里使用零知开源平台进行该示例的演示。 2、软件和硬件 硬件使用零知-ESP8266; 软件使用零知开发工具,自带示例: 3、方法步骤
(1)先在零知开发工具中打开AdvancedWebServer示例,或者复制下面的代码到零知开发工具中: - /**********************************************************
- * 文件: x.ino by 零知实验室
- * -^^- 零知开源,让电子制作变得更简单! -^^-
- * 时间: 2019/05/28 12:22
- * 说明:
- #include <ESP8266WiFi.h>
- #include <WiFiClient.h>
- #include <ESP8266WebServer.h>
- #include <ESP8266mDNS.h>
- #ifndef STASSID
- #define STASSID "ssid"
- #define STAPSK "passwd"
- #endif
- const char *ssid = STASSID;
- const char *password = STAPSK;
- ESP8266WebServer server(80);
- const int led = 13;
- void handleRoot() {
- digitalWrite(led, 1);
- char temp[400];
- int sec = millis() / 1000;
- int min = sec / 60;
- int hr = min / 60;
- snprintf(temp, 400,
- "<html>\
- <head>\
- <meta http-equiv='refresh' content='5'/>\
- <title>ESP8266 Demo</title>\
- <style>\
- body { background-color: #cccccc; font-family: Arial, Helvetica, Sans-Serif; Color: #000088; }\
- </style>\
- </head>\
- <body>\
- <h1>Hello from ESP8266!</h1>\
- <p>Uptime: %02d:%02d:%02d</p>\
- <img src="/test.svg" />\
- </body>\
- </html>",
- hr, min % 60, sec % 60
- server.send(200, "text/html", temp);
- digitalWrite(led, 0);
- void handleNotFound() {
- String message = "File Not Found\n\n";
- message += "URI: ";
- message += server.uri();
- message += "\nMethod: ";
- message += (server.method() == HTTP_GET) ? "GET" : "POST";
- message += "\nArguments: ";
- message += server.args();
- message += "\n";
- for (uint8_t i = 0; i < server.args(); i++) {
- message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
- server.send(404, "text/plain", message);
- void setup(void) {
- pinMode(led, OUTPUT);
- Serial.begin(115200);
- WiFi.mode(WIFI_STA);
- WiFi.begin(ssid, password);
- Serial.println("");
- // Wait for connection
- while (WiFi.status() != WL_CONNECTED) {
- delay(500);
- Serial.print(".");
- Serial.print("Connected to ");
- Serial.println(ssid);
- Serial.print("IP address: ");
- Serial.println(WiFi.localIP());
- if (MDNS.begin("esp8266")) {
- Serial.println("MDNS responder started");
- server.on("/", handleRoot);
- server.on("/test.svg", drawGraph);
- server.on("/inline", []() {
- server.send(200, "text/plain", "this works as well");
- server.onNotFound(handleNotFound);
- server.begin();
- Serial.println("HTTP server started");
- void loop(void) {
- server.handleClient();
- MDNS.update();
- void drawGraph() {
- String out = "";
- char temp[100];
- out += "<svg xmlns="http://www.w3.org/2000/svg" version="1.1" width="400" height="150">\n";
- out += "<rect width="400" height="150" fill="rgb(250, 230, 210)" stroke-width="1" stroke="rgb(0, 0, 0)" />\n";
- out += "<g stroke="black">\n";
- int y = rand() % 130;
- for (int x = 10; x < 390; x += 10) {
- int y2 = rand() % 130;
- sprintf(temp, "<line x1="%d" y1="%d" x2="%d" y2="%d" stroke-width="1" />\n", x, 140 - y, x + 10, 140 - y2);
- out += temp;
- y = y2;
- out += "</g>\n</svg>\n";
- server.send(200, "image/svg+xml", out);
(2)验证上述代码并上传到零知-ESP8266开发板; (3)我们打开零知开发工具的串口调试窗口,可以看到如下信息: (4)现在我们用ping工具测试下网络,得到如下信息: (5)上述步骤成功后,我们现在打开浏览器,打开网址:http://esp8266.local,可以看到如下信息: 更多详细资料可到零知实验室官网免费获取。
