[DemoCode下载] 时钟还可输出
735|16
 楼主| antusheng 发表于 2019-6-30 23:12 | 显示全部楼层 |阅读模式
  1. /*---------------------------------------------------------------------------------------------------------*/
  2. /*        */
  3. /* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
  4. /*        */
  5. /*---------------------------------------------------------------------------------------------------------*/
  6. //***********************************************************************************************************
  7. //  Nuvoton Technoledge Corp.
  8. //  Website: http://www.nuvoton.com
  9. //  E-Mail : MicroC-8bit@nuvoton.com
  10. //  Date   : Apr/21/2017
  11. //***********************************************************************************************************
  12. //***********************************************************************************************************
  13. //  File Function: N76E003 Clock Output demo code
  14. //***********************************************************************************************************
  15. #include "N76E003.h"
  16. #include "SFR_Macro.h"
  17. #include "Function_define.h"
  18. #include "Common.h"
  19. #include "Delay.h"
  20. //======================================================================================================
  21. void main(void)
  22. {
  23.
  24.     /* Note
  25.        MCU power on system clock is HIRC (16.0000MHz), if need change Fsys source pleaes copy hange system closk source demo
  26.     */
  27.
  28.                 Set_All_GPIO_Quasi_Mode;                    //in Function_define.h
  29.     set_CLOEN;                                  //System Clock Output Enable
  30. //     Please measure P1.1 (CLO) pin for system clock output, it should as system clock;
  31.     while(1)
  32.     {
  33.         clr_GPIO1;
  34.         Timer0_Delay1ms(500);
  35.         set_GPIO1;
  36.         Timer0_Delay1ms(500);
  37.     }
  38. /* =================== */
  39. }
zhuomuniao110 发表于 2019-7-22 13:34 | 显示全部楼层
循环里面那个是啥用处
xuanhuanzi 发表于 2019-7-23 11:33 | 显示全部楼层
有人测试过没,是哪个时钟,核心的吗
xinxianshi 发表于 2019-7-23 21:54 | 显示全部楼层
实现这个功能真容易。
huahuagg 发表于 2019-7-23 22:32 | 显示全部楼层
system clock output
wahahaheihei 发表于 2019-7-26 10:04 | 显示全部楼层
非常不错的功能。
捉虫天师 发表于 2019-7-28 23:27 | 显示全部楼层
可以给其他需要时钟的芯片提供时钟源。
643757107 发表于 2019-7-28 23:32 | 显示全部楼层
这个功能,新唐的都具备。
幸福小强 发表于 2019-7-28 23:42 | 显示全部楼层
所有的都可以输出?太方便了。
小灵通2018 发表于 2019-7-29 11:38 | 显示全部楼层
原始时钟还是分频后的
yiy 发表于 2019-7-29 19:51 | 显示全部楼层
这个功能还可以用于测量内部时钟是不是准。
susceptibility 发表于 2019-7-31 15:24 | 显示全部楼层
输出的时钟是固定的某个时钟还是可配置的
 楼主| antusheng 发表于 2019-8-4 15:08 | 显示全部楼层
输出的时钟是固定的某个时钟还是可配置的
CLO: 系统时钟输出脚
 楼主| antusheng 发表于 2019-8-4 15:09 | 显示全部楼层
N76E003提供一个CLO(P1.1)引脚可以输出系统时钟,该频率与FSYS 频率相同。通
 楼主| antusheng 发表于 2019-8-4 15:10 | 显示全部楼层
CPU 的时钟,时钟源分频后的。
 楼主| antusheng 发表于 2019-8-4 15:28 | 显示全部楼层
