4、裁剪microLIB的输入输出函数
Microlib provides a limited stdio subsystem. To use high-level I/O functions you must reimplement the base I/O functions. Microlib provides a limited stdio subsystem that supports unbuffered stdin, stdout and stderr only. This enables you to use printf() for displaying diagnostic messages from your application. To use high-level I/O functions you must provide your own implementation of the following base functions so that they work with your own I/O device.
fputc()
Implement this base function for all output functions. For example, fprintf(), printf(), fwrite(), fputs(), puts(), putc() and putchar().
fgetc()
Implement this base function for all input functions. For example, fscanf(), scanf(), fread(), read(), fgets(), gets(), getc() and getchar().
__backspace()
Implement this base function if your input functions use scanf() or fscanf().
