[国产单片机] 51单片机红外遥控点歌,具体问题已有红字说明,求仁兄解答
2839|2
 楼主| 独钓寒江 发表于 2011-11-14 10:58 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
#define YF_YF 160
#define SFYF_JG 4/5
sbit BEEP = P1^5;   //蜂鸣器驱动线
//红外引脚接P3^3(外部中断1引脚)
///////lcd12864///
sbit rs=P2^6;      //寄存器选择输入
sbit rw=P2^5;      //液晶读/写控制
sbit en= P2^7;      //液晶使能控制
sbit psb=P3^2;      //(此引脚为INT0接口)串/并方式控制 (由于psb=P3^2;与红外的P3^2接口重复,所以红外选P3^3,即INT1)
sbit rst1=P3^7;      //液晶复位端口(注意:开发板连的是P3^7,这里用P2^0,由于和DQ=P3^7引脚重复,所以导致实验失败!!!)
uchar Time_H=0;
uchar Time_L=0;
uint code FreTab[12]={262,277,293,311,329,349,370,392,415,440,466,494};    // 原始频率表,低音
uchar code XY_Tab[7]={0,2,4,5,7,9,11};    // 1-7
uint New_FreTab[12];
uchar YC_Tab[]={1,2,4,8,16,32,64};
uchar IRtime;             //记录中断次数,每次256us;
uchar startflag;        //开始标志位
uchar bitnum;        //位标号
uchar IRdata[33];          //装一帧数据33个IRtime的个数(1个引导码,8个用户码,8个用户码,8个数据码,8个数据反码)
uchar IRrecOK;              //接收完成标志位
uchar IRcode[4];   //一帧数据的4组码
uchar IRprosOK;         //处理完成标志位
uchar code table1[]=" 1挥着翅膀的女孩";
uchar code table2[]=" 2同一首歌      ";
uchar code table3[]=" 3两只蝴蝶      ";
uchar code table4[]=" 4祝你生日快乐  ";
//挥着翅膀的女孩
uchar code MusicGirl[]={ 0x17,0x02, 0x17,0x03, 0x18,0x03, 0x19,0x02, 0x15,0x03,
                         0x16,0x03, 0x17,0x03, 0x17,0x03, 0x17,0x03, 0x18,0x03,
                         0x19,0x02, 0x16,0x03, 0x17,0x03, 0x18,0x02, 0x18,0x03,
                         0x17,0x03, 0x15,0x02, 0x18,0x03, 0x17,0x03, 0x18,0x02,
                         0x10,0x03, 0x15,0x03, 0x16,0x02, 0x15,0x03, 0x16,0x03,
                         0x17,0x02, 0x17,0x03, 0x18,0x03, 0x19,0x02, 0x1A,0x03,
                         0x1B,0x03, 0x1F,0x03, 0x1F,0x03, 0x17,0x03, 0x18,0x03,
                         0x19,0x02, 0x16,0x03, 0x17,0x03, 0x18,0x03, 0x17,0x03,
                         0x18,0x03, 0x1F,0x03, 0x1F,0x02, 0x16,0x03, 0x17,0x03,
                         0x18,0x03, 0x17,0x03, 0x18,0x03, 0x20,0x03, 0x20,0x02,
                         0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x20,0x03, 0x21,0x03,
                         0x20,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66, 0x1F,0x03,
                         0x1B,0x03, 0x19,0x03, 0x19,0x03, 0x15,0x03, 0x1A,0x66,
                         0x1A,0x03, 0x19,0x03, 0x15,0x03, 0x15,0x03, 0x17,0x03,
                         0x16,0x66, 0x17,0x04, 0x18,0x04, 0x18,0x03, 0x19,0x03,
                         0x1A,0x03, 0x19,0x03, 0x19,0x03, 0x1F,0x03, 0x1B,0x03,
                         0x1F,0x00, 0x1A,0x03, 0x1A,0x03, 0x1A,0x03, 0x1B,0x03,
                         0x1B,0x03, 0x1A,0x03, 0x19,0x03, 0x19,0x02, 0x17,0x03,
                         0x15,0x17, 0x15,0x03, 0x16,0x03, 0x17,0x03, 0x18,0x03,
                         0x17,0x04, 0x18,0x0E, 0x18,0x03, 0x17,0x04, 0x18,0x0E,
                         0x18,0x66, 0x17,0x03, 0x18,0x03, 0x17,0x03, 0x18,0x03,
                         0x20,0x03, 0x20,0x02, 0x1F,0x03, 0x1B,0x03, 0x1F,0x66,
                         0x20,0x03, 0x21,0x03, 0x20,0x03, 0x1F,0x03, 0x1B,0x03,
                         0x1F,0x66, 0x1F,0x04, 0x1B,0x0E, 0x1B,0x03, 0x19,0x03,
                         0x19,0x03, 0x15,0x03, 0x1A,0x66, 0x1A,0x03, 0x19,0x03,
                         0x15,0x03, 0x15,0x03, 0x17,0x03, 0x16,0x66, 0x17,0x04,
                         0x18,0x04, 0x18,0x03, 0x19,0x03, 0x1F,0x03, 0x1B,0x03,
                         0x1F,0x66, 0x20,0x03, 0x21,0x03, 0x20,0x03, 0x1F,0x03,
                         0x1B,0x03, 0x1F,0x66, 0x1F,0x03, 0x1B,0x03, 0x19,0x03,
                         0x19,0x03, 0x1F,0x03, 0x1B,0x03, 0x1F,0x00, 0x18,0x02,
                         0x18,0x03, 0x1A,0x03, 0x19,0x0D, 0x15,0x03, 0x15,0x02,
                         0x18,0x66, 0x16,0x02, 0x17,0x02, 0x15,0x00, 0x00,0x00};
//同一首歌
uchar code MusicSame[]={ 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x66, 0x18,0x03,
                         0x17,0x02, 0x15,0x02, 0x16,0x01, 0x15,0x02, 0x10,0x02,
                         0x15,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x02,
                         0x17,0x03, 0x18,0x03, 0x19,0x02, 0x15,0x02, 0x18,0x66,
                         0x17,0x03, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x00,
                         0x17,0x01, 0x19,0x02, 0x1B,0x02, 0x1B,0x70, 0x1A,0x03,
                         0x1A,0x01, 0x19,0x02, 0x19,0x03, 0x1A,0x03, 0x1B,0x02,
                         0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x18,0x66, 0x18,0x03,
                         0x19,0x02, 0x1A,0x02, 0x19,0x0C, 0x18,0x0D, 0x17,0x03,
                         0x16,0x01, 0x11,0x02, 0x11,0x03, 0x10,0x03, 0x0F,0x0C,
                         0x10,0x02, 0x15,0x00, 0x1F,0x01, 0x1A,0x01, 0x18,0x66,
                         0x19,0x03, 0x1A,0x01, 0x1B,0x02, 0x1B,0x03, 0x1B,0x03,
                         0x1B,0x0C, 0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x1F,0x01,
                         0x1A,0x01, 0x18,0x66, 0x19,0x03, 0x1A,0x01, 0x10,0x02,
                         0x10,0x03, 0x10,0x03, 0x1A,0x0C, 0x18,0x0D, 0x17,0x03,
                         0x16,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x70,
                         0x18,0x03, 0x17,0x02, 0x15,0x03, 0x15,0x03, 0x16,0x66,
                         0x16,0x03, 0x16,0x02, 0x16,0x03, 0x15,0x03, 0x10,0x02,
                         0x10,0x01, 0x11,0x01, 0x11,0x66, 0x10,0x03, 0x0F,0x0C,
                         0x1A,0x02, 0x19,0x02, 0x16,0x03, 0x16,0x03, 0x18,0x66,
                         0x18,0x03, 0x18,0x02, 0x17,0x03, 0x16,0x03, 0x19,0x00,
                         0x00,0x00 };
//两只蝴蝶
uchar code MusicTwo[]={  0x17,0x03, 0x16,0x03, 0x17,0x01, 0x16,0x03, 0x17,0x03,
                         0x16,0x03, 0x15,0x01, 0x10,0x03, 0x15,0x03, 0x16,0x02,
                         0x16,0x0D, 0x17,0x03, 0x16,0x03, 0x15,0x03, 0x10,0x03,
                         0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x16,0x03,
                         0x17,0x01, 0x16,0x03, 0x17,0x03, 0x16,0x03, 0x15,0x01,
                         0x10,0x03, 0x15,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03,
                         0x16,0x03, 0x15,0x03, 0x10,0x03, 0x15,0x03, 0x16,0x01,
                         0x10,0x0E, 0x15,0x04, 0x0F,0x01, 0x17,0x03, 0x19,0x03,
                         0x19,0x01, 0x19,0x03, 0x1A,0x03, 0x19,0x03, 0x17,0x01,
                         0x16,0x03, 0x16,0x03, 0x16,0x02, 0x16,0x0D, 0x17,0x03,
                         0x16,0x03, 0x15,0x03, 0x10,0x03, 0x10,0x0D, 0x15,0x00,
                         0x19,0x03, 0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03,
                         0x1B,0x03, 0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03,
                         0x16,0x0D, 0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03,
                         0x1A,0x02, 0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03,
                         0x16,0x01, 0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03,
                         0x19,0x02, 0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E,
                         0x1B,0x04, 0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E,
                         0x1B,0x04, 0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03,
                         0x17,0x0D, 0x16,0x03, 0x17,0x03, 0x19,0x01, 0x19,0x03,
                         0x19,0x03, 0x1A,0x03, 0x1F,0x03, 0x1B,0x03, 0x1B,0x03,
                         0x1A,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x03, 0x16,0x03,
                         0x17,0x01, 0x17,0x03, 0x17,0x03, 0x19,0x03, 0x1A,0x02,
                         0x1A,0x02, 0x10,0x03, 0x17,0x0D, 0x16,0x03, 0x16,0x01,
                         0x17,0x03, 0x19,0x03, 0x19,0x03, 0x17,0x03, 0x19,0x03,
                         0x1F,0x02, 0x1B,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
                         0x17,0x02, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
                         0x17,0x16, 0x1A,0x03, 0x1A,0x03, 0x1A,0x0E, 0x1B,0x04,
                         0x1A,0x03, 0x19,0x03, 0x17,0x03, 0x16,0x03, 0x0F,0x02,
                         0x10,0x03, 0x15,0x00, 0x00,0x00 };
//祝你生日快乐
uchar code MusicHappy[]={0x0F,0x03, 0x0F,0x03, 0x10,0x02, 0x0F,0x02, 0x15,0x02,
                         0x11,0x01, 0x0F,0x03, 0x0F,0x03, 0x10,0x02, 0x0F,0x02,
                         0x16,0x02, 0x15,0x01, 0x0F,0x03, 0x0F,0x03, 0x19,0x02,
                         0x17,0x02, 0x15,0x02, 0x11,0x0C, 0x10,0x02, 0x18,0x03,
                         0x18,0x03, 0x17,0x02, 0x15,0x02, 0x16,0x02, 0x17,0x01,
                         0x18,0x03, 0x17,0x02, 0x15,0x02, 0x16,0x02, 0x10,0x01,
                         0x00,0x00 };
void Delay_10MS(void);
void JX_New_Few_FerTab(uchar QSD,uchar SYD);
void Play_Music(uchar *Sound,uchar QSD,uchar SYD);
void timer1_init(void);
void timer0_init(void);
void int1_init(void);
void IRpros(void);
void beep(void);
void delay_50us(uint t);
void delay_1ms(uint z);
void LCD12864_write_com(uchar com);
void LCD12864_write_data(uchar dat);
void LCD12864_init(void);
void delay_50us(uint t)//已调试过,延时50us
uchar j;
for(;t>0;t--)
  for(j=38;j>0;j--);
void delay_1ms(uint z)//已调试过,延时1ms
uint x,y;
for(x=z;x>0;x--)
  for(y=247;y>0;y--);
en=0;
rs=0;
rw=0;
delay_50us(1);
P0=com;
en=1;
delay_50us(3);
en=0;
delay_50us(4);
en=0;
rs=1;
rw=0;
delay_50us(1);
P0=dat;
en=1;
delay_50us(3);
en=0;
delay_50us(4);
uchar i;
psb=1;
rst1=0;
delay_1ms(100);
rst1=1;
LCD12864_write_com(0x30);
delay_50us(4);
delay_50us(2);
LCD12864_write_com(0x0c);
delay_50us(4);
LCD12864_write_com(0x01);
delay_50us(1);
LCD12864_write_com(0x06);
delay_1ms(10);
LCD12864_write_com(0x80); //显示的一行
for(i=0;i<16;i++)
   LCD12864_write_data(table1);
LCD12864_write_com(0x90); //显示的二行
for(i=0;i<16;i++)
   LCD12864_write_data(table2);
LCD12864_write_com(0x88);  //显示的三行
for(i=0;i<16;i++)
   LCD12864_write_data(table3);
LCD12864_write_com(0x98);  //显示的四行
for(i=0;i<16;i++)
   LCD12864_write_data(table4);
TMOD=0x02;       //定时器0工作在方式2(自动重装8位初值)
TH0=0x00;
TL0=0x00;   //256us溢出产生中断
ET0=1;
EA=1;
TR0=1;
IT1=1;          //外部中断0选择下降沿触发
EX1=1;
EA=1;
void IRpros(void)
uchar i,j,k;
uchar value;
k=1;                 //跳过引导码
for(i=0;i<4;i++)         //一帧数据4组,一组一组来
   for(j=0;j<8;j++)   //一组数据8位,一位一位来
     value=value>>1;      //由于从低位读起,所以用循环右移
     if(IRdata[k]>6)         //  (1.125ms/0.256ms=4.39)< 6 <(2.25ms/0.256ms=8.80),取中间值6做判断标准
      value=value|0x80;
     k++;                  //k一直加到32,k不需清零,因为接收下一帧数据的时候从头开始,即k=1
   IRcode=value;
IRprosOK=1;
void beep(void)
uchar i;
for (i=0;i<200;i++)     //喇叭发声的时间循环,改变大小可以改变发声时间长短
      delay_50us(20);     //参数决定发声的频率,估算值,可以自行更改参数并
      BEEP=!BEEP;                 //BEEP取反
   BEEP=1;                      //关闭蜂鸣器
TMOD=0x10;
TH1=0xFF;
TL1=0xFF;
ET1=1;
TR1= 0;
EA=1;
void main(void)
timer0_init();
int1_init();
timer1_init();
LCD12864_init();
while(1)
  if(IRrecOK)
   IRpros();
   IRrecOK=0;
  if(IRprosOK)
   beep();
   IRprosOK=0;
  if((IRcode[2])==(~IRcode[3])&&(IRcode[0]==0x00)&&(IRcode[1]==0xff))//地址码数据码验证
   switch(IRcode[2])  // 注意:红外解码、12864显示、蜂鸣器演奏模块调试过正常,本人第一次使用红外键码,一到 switch(IRcode[2]) 就进不去了,求高手指点,感激不尽!
     case 0x0c: LCD12864_write_com(0x80);LCD12864_write_data(0x10);Play_Music(MusicGirl,0,0);//按键1
         break;
    case 0x18: LCD12864_write_com(0x90);LCD12864_write_data(0x10);Play_Music(MusicSame,0,0);//按键2
         break;
    case 0x5e: LCD12864_write_com(0x88);LCD12864_write_data(0x10);Play_Music(MusicTwo,0,0);//按键3
         break;
    case 0x08: LCD12864_write_com(0x98);LCD12864_write_data(0x10);Play_Music(MusicHappy,5,0);//按键4
         break;
/* if(IRcode[2]==0x0c)
  else
void timer0() interrupt 1 //中断服务子程序不需函数声明,定时器0的中断号为1
IRtime++;
void int1() interrupt 2    //中断服务子程序不需函数声明,外部中断1的中断号为2
if(startflag)
  if(IRtime>33)       //  9ms/0.256ms=35.15,传播途中波形有变化,选33。检测引导码
   bitnum=0;
  IRdata[bitnum]=IRtime;
  IRtime=0;
  bitnum++;
  if(bitnum==33)
   bitnum=0;
   IRrecOK=1;      //一帧数据接受完毕
   startflag=0;     //标志位清零,每一帧都开头都进入else,打开startflag=1
else      //每一帧数据开头打开startflag=1,一帧内再不进入else,下一帧再进入
  startflag=1;
  IRtime=0;
void timer1() interrupt 3
BEEP=~BEEP;
TH1=Time_H;
TL1=Time_L;
void JX_New_Few_FerTab(uchar QSD,uchar SYD)   // QSD 0-11  SYD 1-3 1降8度 2不变,3升8度
uchar i=0;
uchar j=0;
for(i=0;i<12;i++)    // 12次循环
   j=i+QSD;    //根据起始调判断起始音符位置
   if(j>11)     //如果起始调不是最低
     j=j-12;  // 0-11
     New_FreTab=FreTab[j]*2;// 频率*2
   else        //频率不变
     New_FreTab=FreTab[j];
   if(SYD==1)      //判断升降调。1降调,2不变,3升调。
     New_FreTab>>=1;//频率减一半
   else
     if(SYD==3)
       New_FreTab<<=1;
uint GQ_CD=0;     //歌曲长度
uint GQ_WZ=0;
uchar GQ_YG=0;
uchar GQ_YC=0;
uint YP_PL=0;
uchar YG_Bai=0;
uchar YG_Shi=0;
uchar YG_Ge=0;
uchar YC_Bai=0;
uchar YC_Shi=0;
uchar YC_Ge=0;
uint DSD_PL=0;
uint YF0=0; // 1分音符变量
uint YF1=0; // 发音长度时间
uint YF2=0; //不发音长度时间
uint YF4=0; // 4分音符时间
uint FY_JG=0;
uint YZ_TC=0;
uint JF_YF=0;
uchar i=0;
JX_New_Few_FerTab(QSD,SYD);
while(Sound[GQ_CD]!=0)   //判断歌曲长度
  GQ_CD+=2;    //指向下一位音符数据
while(GQ_WZ<GQ_CD)
  GQ_YG=Sound[GQ_WZ];
  YG_Bai=GQ_YG/100;  // 1升半音,0不升
  YG_Shi=GQ_YG/10%10; // 1低音,2为中音,3为高音
  YG_Ge=GQ_YG%10;  // 1-7 音符位;
  YP_PL=New_FreTab[XY_Tab[YG_Ge-1]+YG_Bai];// yg_ge -1 1-7 0-6
  if(YG_Ge!=0)
    switch(YG_Shi)
      case 2: YP_PL<<=1;break;
      case 3: YP_PL<<=2;break;
    DSD_PL=65536-(50000/YP_PL)*10;
    Time_H=DSD_PL>>8;
    Time_L=DSD_PL&0x00FF;
    TH1=Time_H;
    TL1=Time_L;
  GQ_YC=Sound[GQ_WZ+1];
  YC_Bai=GQ_YC/100;  // 1有符点,0无符点
  YC_Shi=GQ_YC/10%10; // 演奏效果0普通,1连音,2顿音
  YC_Ge=GQ_YC%10;  // 几分音符。
  YF0=YF_YF;
  YF4=YF0/4;
  FY_JG=YF4-YF4*SFYF_JG;
  JF_YF=YC_Tab[YC_Ge];// 几分音符;
  YZ_TC=YF0/JF_YF;   // 算出对应延时长度多少个10MS
  if(YC_Bai==1)   //判断是否有符点
    YZ_TC=YZ_TC+YZ_TC/2;//有符点
  if(YC_Shi!=1)   //不是连音
    if(YC_Shi==0) //是否为普通音
      if(JF_YF<=4) // 是否小于16分音
        YF1=YZ_TC-FY_JG; // 发音有间隔
      else   // 不小于16分音
        YF1=YZ_TC*SFYF_JG;//发音无音隔
    else     //是顿音,演奏时间为原来的一半
      YF1=YZ_TC/2;
  else       //是连音,发音无音隔
    YF1 =YZ_TC;
  if(YG_Ge==0)    //没有音符数据
    YF1=0;    //演奏时间 = 0
  else       //有音符数据
    YF2=YZ_TC-YF1;
    TR1=1;
    for(i=YF1;i>0;i--)
      Delay_10MS();
    BEEP=1;
    TR1=0;
    for(i= YF2;i>0;i--)
      Delay_10MS();
  GQ_WZ+=2;     //指向下一个音符
void Delay_10MS(void)   //延时函数 10MS
uchar a=0;
uchar b=0;
for(a=50;a>0;a--)
   for(b=100;b>0;b--);
 楼主| 独钓寒江 发表于 2011-11-26 21:32 | 显示全部楼层
问题已解决。问题出现在使用两个定时器,分别设定了两个TMOD值而出错,感谢大家的思考
请问TMOD的值应该为什么 不是0x01么  发表于 2018-12-14 18:50
