AT91RM9200 的PLLB设置问题
7244|0
 楼主| mm7989680 发表于 2008-8-22 10:19 | 显示全部楼层 |阅读模式
AT91RM9200&nbsp;的PLLB设置问题<br />&nbsp;&nbsp;&nbsp;basicUsb文件夹中AT91RM9200DK.ini里有&nbsp;&nbsp;<br />com&nbsp;setmem&nbsp;0xFFFFFC20&nbsp;0x0000FF01&nbsp;32<br />com&nbsp;setmem&nbsp;0xFFFFFC2C&nbsp;0x102F3E05&nbsp;32<br />com&nbsp;select&nbsp;PLLB&nbsp;as&nbsp;master&nbsp;clock<br />com&nbsp;setmem&nbsp;0xFFFFFC30&nbsp;0x00000007&nbsp;32<br />按照PLLB的USB时钟需要48M,从上面的设置来看&nbsp;(18.432/2)*48/5=88.4736M,而非96M,是不是应该<br />setmem&nbsp;0xFFFFFC28&nbsp;0x2026BE04&nbsp;&nbsp;32&nbsp;&nbsp;&nbsp;&nbsp;<br />setmem&nbsp;0xFFFFFC2C&nbsp;0x10483E0E&nbsp;32&nbsp;&nbsp;&nbsp;&nbsp;18.432*74/14=96M<br />setmem&nbsp;0xFFFFFC30&nbsp;0x00000202&nbsp;32<br />另外我的pllb设为0xFFFFFC2C&nbsp;0x10483E0E&nbsp;,串口就没输出了,改为上面的0x102F3E05,又能输出,难道PLLB影响串口时钟?我串口主时钟用的是plla的179m/3=60m,在此基础上算波特率115200
