[活动专区] 【AC7811开发板试用活动】+TN9模块
736|0
 楼主| Cjy_JDxy 发表于 2019-10-17 19:27 | 显示全部楼层 |阅读模式
今天搞了一下TN9模块,就是红外体温计模块。
代码:
#include "ac78xx_gpio.h"
#include "ac78xx_debugout.h"
#include "ac78xx.h"
#define uchar unsigned char
#define uint unsigned int
/* makesure n < 16 */
#define PAout(n)   BIT_ADDR(GPIOA_ODR_ADDR, n)
#define PAin(n)    BIT_ADDR(GPIOA_IDR_ADDR, n)
#define PBout(n)   BIT_ADDR(GPIOB_ODR_ADDR, n)
#define PBin(n)    BIT_ADDR(GPIOB_IDR_ADDR, n)
#define PCout(n)   BIT_ADDR(GPIOC_ODR_ADDR, n)
#define PCin(n)    BIT_ADDR(GPIOC_IDR_ADDR, n)
#define PDout(n)   BIT_ADDR(GPIOD_ODR_ADDR, n)
#define PDin(n)    BIT_ADDR(GPIOD_IDR_ADDR, n)
#define PEout(n)   BIT_ADDR(GPIOE_ODR_ADDR, n)
#define PEin(n)    BIT_ADDR(GPIOE_IDR_ADDR, n)
/* gpio bit-band control */
#define LED PAout(0)
void ACK_0() { PBout(14)=0;}  //
void ACK_1() { PBout(14)=1;}
#define DATA            PBin(10)
#define CLOCK           PBin(12)
float Temp;
float Temp1,Temp2;
unsigned char ReadData[5];
unsigned int a,b;
//????:Delay()
void Delay(unsigned char us)  //5,7,9
  while(--us);
//????:Delayms()
void Delayms(unsigned int ims)
  unsigned int i,j;
    for(i=0;i<ims;i++)
      for(j=0;j<65;j++) { Delay(1); }
void TN_IRACK_EN(void)
        ACK_0();
        Delay(1);
void TN_IRACK_UN(void)
        ACK_1();
        Delay(1);
void InitIO(void)
        GPIO_SetDir(GPIO_PB10, 0);
        GPIO_SetDir(GPIO_PB12, 0);
        GPIO_SetDir(GPIO_PB14, 1);
void TN_ReadData(unsigned char Flag)
        unsigned char i,j,k,BitState=0;
        for(k=0;k<7;k++)
                for(j=0;j<5;j++)
                        for(i=0;i<8;i++)
                                while(1)
                                  if(CLOCK==0)
                                    break;
                                  Delay(1);
                                Delay(1);
                                if(DATA==1)
                                  BitState=1;
                                else
                                  BitState=0;
                                ReadData[j]= ReadData[j]<<1;
                                ReadData[j]= ReadData[j]|BitState;
                                Delay(1);
                                while(1)
                                  if(CLOCK==1)
                                    break;
                                  Delay(1);
                if(ReadData[0]==Flag)
                        k=8;
        TN_IRACK_UN();
float TN_GetData(unsigned char X)
        //Ack_Clk_Data_init;
        InitIO();
        TN_ReadData(X);
        Temp=(ReadData[1]<<8)|ReadData[2];
        Temp=(float)Temp/16.00-273.15;
        return Temp;
float TN_GetTemp(unsigned char mode)
        float T;
                TN_IRACK_UN();
                TN_IRACK_EN();
                if(mode==0)
                        T=TN_GetData(0x4c);
                else
                        T=TN_GetData(0x66);
        return T;
* main
* @param[in]  none
* @return none
* @brief  entry
int main(void)
    InitDebug();    //´òÓ¡³õʼ»¯
    InitDelay();    //ÑÓʱº¯Êý³õʼ»¯
    GPIO_SetDir(GPIO_PA0, 1);
                GPIO_SetDir(GPIO_PA2, 1);
                GPIO_SetDir(GPIO_PA4, 1);
                InitIO();
    while (1)
                                Temp1=TN_GetTemp(0);
        Temp2=TN_GetTemp(1);
        //a=((unsigned int)(Temp1*10));
                                //b=((unsigned int)(Temp2*10));
                                printf("T1: %f\r\n",Temp1);
                                printf("T2: %f\r\n",Temp2);
        LED = !LED;
        mdelay(500);
效果图:
T1是人体温度,哈一口气温度就上升。T2是环境温度。
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
