[活动专区] 【AC7811开发板试用活动】+HT1621
713|0
 楼主| Cjy_JDxy 发表于 2019-10-18 20:11 | 显示全部楼层 |阅读模式
今晚搞了一下HT1621.
代码:
#include "ac78xx_gpio.h"
#include "ac78xx_debugout.h"
#include "ac78xx.h"
#define uchar unsigned char
#define uint unsigned int
/* makesure n < 16 */
#define PAout(n)   BIT_ADDR(GPIOA_ODR_ADDR, n)
#define PAin(n)    BIT_ADDR(GPIOA_IDR_ADDR, n)
#define PBout(n)   BIT_ADDR(GPIOB_ODR_ADDR, n)
#define PBin(n)    BIT_ADDR(GPIOB_IDR_ADDR, n)
#define PCout(n)   BIT_ADDR(GPIOC_ODR_ADDR, n)
#define PCin(n)    BIT_ADDR(GPIOC_IDR_ADDR, n)
#define PDout(n)   BIT_ADDR(GPIOD_ODR_ADDR, n)
#define PDin(n)    BIT_ADDR(GPIOD_IDR_ADDR, n)
#define PEout(n)   BIT_ADDR(GPIOE_ODR_ADDR, n)
#define PEin(n)    BIT_ADDR(GPIOE_IDR_ADDR, n)
/* gpio bit-band control */
#define LED PAout(0)
#define Smg_a    0x80
#define Smg_b    0x40
#define Smg_c    0x20
#define Smg_d    0x01
#define Smg_e    0x02
#define Smg_f    0x08
#define Smg_g    0x04
#define Smg_dp   0x10
#define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map          Smg_b | Smg_c
#define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map          Smg_a | Smg_b | Smg_c
#define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
#define CS_0           PAout(0)=0
#define CS_1           PAout(0)=1
#define WR_0           PAout(2)=0
#define WR_1           PAout(2)=1
#define DA_0           PAout(4)=0
#define DA_1           PAout(4)=1
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //?????
unsigned int i;
void delay(uchar x)
        for(i=0;i<x;i++);
void COMMAND_HT1621(unsigned char comm)
        unsigned char i;
        CS_0;
        delay(5);
        WR_0;
        delay(5);
        for(i=0;i<3;i++)        //???
                if((0x04<<i)&0x04)  DA_1;    //100
                else                DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        for(i=0;i<9;i++)        //?????
                if((comm<<i)&0x80)  DA_1;    //100
                else                DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        CS_1;
        delay(5);
void HT1621_Display(void)
        unsigned char i;
        CS_0;                        //??CS
        delay(5);
        WR_0;
        delay(5);
                if((0x05<<i)&0x04)  DA_1;
                else                DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        for(i=0;i<6;i++)                   //???
                if((20<<i)&0x20)    DA_1;  //20?? SEG??
                  else                DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        for(i=0;i<8;i++)                   //???
                if((DpyNum[5]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[4]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[3]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[2]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[1]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
                if((DpyNum[0]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(5);
                WR_0;
                delay(5);
                WR_1;
                delay(5);
        CS_1;                          //??CS
        delay(5);
void LCD_Init(void)
        COMMAND_HT1621(0x01);         //SYS EN
        COMMAND_HT1621(0x03);         //LCD ON
        COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
        HT1621_Display();             //clear screen
* main
* @param[in]  none
* @return none
* @brief  entry
int main(void)
    InitDebug();    //´òÓ¡³õʼ»¯
    InitDelay();    //ÑÓʱº¯Êý³õʼ»¯
    GPIO_SetDir(GPIO_PA0, 1);
                GPIO_SetDir(GPIO_PA2, 1);
                GPIO_SetDir(GPIO_PA4, 1);
                LCD_Init();
                DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"?"
                DpyNum[1] = SegCode[1];
                DpyNum[2] = SegCode[3];
                DpyNum[3] = SegCode[5];
                DpyNum[4] = SegCode[7];
                DpyNum[5] = SegCode[9];
                HT1621_Display();               //??LCD
    while (1)
        LED = !LED;
        mdelay(500);
效果图:
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
