[程序源码] CC1101 发送数据成功, 接受不到数据,MISO一直有方波,GDO0有触发信号,
1121|5
 楼主| 拖拉机小司机 发表于 2019-11-8 09:32 | 显示全部楼层 |阅读模式
PIC16F690代+CC1101代码
* File:   main.c
* Author: sz
* Created on 2019年10月30日, 上午9:03
#include<pic.h>
#include <stdlib.h>
#include<math.h>
//#pragma config FOSC = EXTRCIO   // Oscillator Selection bits (RCIO oscillator: I/O function on RA4/OSC2/CLKOUT pin, RC on RA5/OSC1/CLKIN)
//#pragma config WDTE = ON        // Watchdog Timer Enable bit (WDT enabled)
//#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
//#pragma config MCLRE = ON       // MCLR Pin Function Select bit (MCLR pin function is MCLR)
//#pragma config CP = OFF         // Code Protection bit (Program memory code protection is disabled)
//#pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)
//#pragma config BOREN = OFF       // Brown-out Reset Selection bits (BOR enabled)
//#pragma config IESO = ON        // Internal External Switchover bit (Internal External Switchover mode is enabled)
//#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is enabled)
//#include <xc.h>
#pragma config FOSC = LP        // Oscillator Selection bits (LP oscillator: Low-power crystal on RA4/OSC2/CLKOUT and RA5/OSC1/CLKIN)
#pragma config WDTE = OFF        // Watchdog Timer Enable bit (WDT enabled)
#pragma config BOREN = ON       // Brown-out Reset Selection bits (BOR enabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#define                INT8U                unsigned char
#define                INT16U                unsigned int
INT16U ge,shi,bai,qian,count0;
#define  WRITE_BURST         0x40        //连续写入
#define  READ_SINGLE         0x80        //读
#define  READ_BURST          0xC0        //连续
#define  BYTES_IN_RXFIFO     0x7F          //接收缓冲区的有效字节数
#define  CRC_OK              0x80         //CRC校验通过位标志
#define  MOSI_0     RB4=0
#define  MOSI_1     RB4=1
//===================================SPI时钟端口================================
#define  SCK_0      RC2=0
#define  SCK_1      RC2=1
//==================================SPI使能端口=================================
#define  CSN_0      RC0=0
#define  CSN_1      RC0=1
//    MISO=RC1;
//    GDO0=RA2;
INT8U PaTabel[8] = {0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60};
void SpiInit(void);
void CpuInit(void);
void RESET_CC1100(void);
void POWER_UP_RESET_CC1100(void);
void halSpiWriteReg(INT8U addr, INT8U value);
void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count);
void halSpiStrobe(INT8U strobe);
INT8U halSpiReadReg(INT8U addr);
void halSpiReadBurstReg(INT8U addr, INT8U *buffer, INT8U count);
INT8U halSpiReadStatus(INT8U addr);
void halRfWriteRfSettings(void);
void halRfSendPacket(INT8U *txBuffer, INT8U size);
INT8U halRfReceivePacket(INT8U *rxBuffer, INT8U *length);
//*************************寄存器映射******************************************
#define CCxxx0_IOCFG2       0x00        // GDO2 output pin configuration
#define CCxxx0_IOCFG1       0x01        // GDO1 output pin configuration
#define CCxxx0_IOCFG0       0x02        // GDO0 output pin configuration
#define CCxxx0_FIFOTHR      0x03        // RX FIFO and TX FIFO thresholds
#define CCxxx0_SYNC1        0x04        // Sync word, high INT8U
#define CCxxx0_SYNC0        0x05        // Sync word, low INT8U
#define CCxxx0_PKTLEN       0x06        // Packet length
#define CCxxx0_PKTCTRL1     0x07        // Packet automation control
#define CCxxx0_PKTCTRL0     0x08        // Packet automation control
#define CCxxx0_ADDR         0x09        // Device address
#define CCxxx0_CHANNR       0x0A        // Channel number
#define CCxxx0_FSCTRL1      0x0B        // Frequency synthesizer control
#define CCxxx0_FSCTRL0      0x0C        // Frequency synthesizer control
#define CCxxx0_FREQ2        0x0D        // Frequency control word, high INT8U
#define CCxxx0_FREQ1        0x0E        // Frequency control word, middle INT8U
#define CCxxx0_FREQ0        0x0F        // Frequency control word, low INT8U
#define CCxxx0_MDMCFG4      0x10        // Modem configuration
#define CCxxx0_MDMCFG3      0x11        // Modem configuration
#define CCxxx0_MDMCFG2      0x12        // Modem configuration
#define CCxxx0_MDMCFG1      0x13        // Modem configuration
#define CCxxx0_MDMCFG0      0x14        // Modem configuration
#define CCxxx0_DEVIATN      0x15        // Modem deviation setting
#define CCxxx0_MCSM2        0x16        // Main Radio Control State Machine configuration
#define CCxxx0_MCSM1        0x17        // Main Radio Control State Machine configuration
#define CCxxx0_MCSM0        0x18        // Main Radio Control State Machine configuration
#define CCxxx0_FOCCFG       0x19        // Frequency Offset Compensation configuration
#define CCxxx0_BSCFG        0x1A        // Bit Synchronization configuration
#define CCxxx0_AGCCTRL2     0x1B        // AGC control
#define CCxxx0_AGCCTRL1     0x1C        // AGC control
#define CCxxx0_AGCCTRL0     0x1D        // AGC control
#define CCxxx0_WOREVT1      0x1E        // High INT8U Event 0 timeout
#define CCxxx0_WOREVT0      0x1F        // Low INT8U Event 0 timeout
#define CCxxx0_WORCTRL      0x20        // Wake On Radio control
#define CCxxx0_FREND1       0x21        // Front end RX configuration
#define CCxxx0_FREND0       0x22        // Front end TX configuration
#define CCxxx0_FSCAL3       0x23        // Frequency synthesizer calibration
#define CCxxx0_FSCAL2       0x24        // Frequency synthesizer calibration
#define CCxxx0_FSCAL1       0x25        // Frequency synthesizer calibration
#define CCxxx0_FSCAL0       0x26        // Frequency synthesizer calibration
#define CCxxx0_RCCTRL1      0x27        // RC oscillator configuration
#define CCxxx0_RCCTRL0      0x28        // RC oscillator configuration
#define CCxxx0_FSTEST       0x29        // Frequency synthesizer calibration control
#define CCxxx0_PTEST        0x2A        // Production test
#define CCxxx0_AGCTEST      0x2B        // AGC test
#define CCxxx0_TEST2        0x2C        // Various test settings
#define CCxxx0_TEST1        0x2D        // Various test settings
#define CCxxx0_TEST0        0x2E        // Various test settings
// Strobe commands
#define CCxxx0_SRES         0x30        // Reset chip.
#define CCxxx0_SFSTXON      0x31        // Enable and calibrate frequency synthesizer (if MCSM0.FS_AUTOCAL=1).
                                        // If in RX/TX: Go to a wait state where only the synthesizer is
                                        // running (for quick RX / TX turnaround).
#define CCxxx0_SXOFF        0x32        // Turn off crystal oscillator.
#define CCxxx0_SCAL         0x33        // Calibrate frequency synthesizer and turn it off
                                        // (enables quick start).
#define CCxxx0_SRX          0x34        // Enable RX. Perform calibration first if coming from IDLE and
                                        // MCSM0.FS_AUTOCAL=1.
#define CCxxx0_STX          0x35        // In IDLE state: Enable TX. Perform calibration first if
                                        // MCSM0.FS_AUTOCAL=1. If in RX state and CCA is enabled:
                                        // Only go to TX if channel is clear.
#define CCxxx0_SIDLE        0x36        // Exit RX / TX, turn off frequency synthesizer and exit
                                        // Wake-On-Radio mode if applicable.
#define CCxxx0_SAFC         0x37        // Perform AFC adjustment of the frequency synthesizer
#define CCxxx0_SWOR         0x38        // Start automatic RX polling sequence (Wake-on-Radio)
#define CCxxx0_SPWD         0x39        // Enter power down mode when CSn goes high.
#define CCxxx0_SFRX         0x3A        // Flush the RX FIFO buffer.
#define CCxxx0_SFTX         0x3B        // Flush the TX FIFO buffer.
#define CCxxx0_SWORRST      0x3C        // Reset real time clock.
#define CCxxx0_SNOP         0x3D        // No operation. May be used to pad strobe commands to two
                                        // INT8Us for simpler software.
#define CCxxx0_PARTNUM      0x30
#define CCxxx0_VERSION      0x31
#define CCxxx0_FREQEST      0x32
#define CCxxx0_LQI          0x33
#define CCxxx0_RSSI         0x34
#define CCxxx0_MARCSTATE    0x35
#define CCxxx0_WORTIME1     0x36
#define CCxxx0_WORTIME0     0x37
#define CCxxx0_PKTSTATUS    0x38
#define CCxxx0_VCO_VC_DAC   0x39
#define CCxxx0_TXBYTES      0x3A
#define CCxxx0_RXBYTES      0x3B
#define CCxxx0_PATABLE      0x3E
#define CCxxx0_TXFIFO       0x3F
#define CCxxx0_RXFIFO       0x3F
//********************配置CC1101寄存器*************************
typedef struct S_RF_SETTINGS
        INT8U FSCTRL2;                //
    INT8U FSCTRL1;   // Frequency synthesizer control.
    INT8U FSCTRL0;   // Frequency synthesizer control.
    INT8U FREQ2;     // Frequency control word, high INT8U.
    INT8U FREQ1;     // Frequency control word, middle INT8U.
    INT8U FREQ0;     // Frequency control word, low INT8U.
    INT8U MDMCFG4;   // Modem configuration.
    INT8U MDMCFG3;   // Modem configuration.
    INT8U MDMCFG2;   // Modem configuration.
    INT8U MDMCFG1;   // Modem configuration.
    INT8U MDMCFG0;   // Modem configuration.
    INT8U CHANNR;    // Channel number.
    INT8U DEVIATN;   // Modem deviation setting (when FSK modulation is enabled).
    INT8U FREND1;    // Front end RX configuration.
    INT8U FREND0;    // Front end RX configuration.
    INT8U MCSM0;     // Main Radio Control State Machine configuration.
    INT8U FOCCFG;    // Frequency Offset Compensation Configuration.
    INT8U BSCFG;     // Bit synchronization Configuration.
    INT8U AGCCTRL2;  // AGC control.
        INT8U AGCCTRL1;  // AGC control.
    INT8U AGCCTRL0;  // AGC control.
    INT8U FSCAL3;    // Frequency synthesizer calibration.
    INT8U FSCAL2;    // Frequency synthesizer calibration.
        INT8U FSCAL1;    // Frequency synthesizer calibration.
    INT8U FSCAL0;    // Frequency synthesizer calibration.
    INT8U FSTEST;    // Frequency synthesizer calibration control
    INT8U TEST2;     // Various test settings.
    INT8U TEST1;     // Various test settings.
    INT8U TEST0;     // Various test settings.
    INT8U IOCFG2;    // GDO2 output pin configuration
    INT8U IOCFG0;    // GDO0 output pin configuration
    INT8U PKTCTRL1;  // Packet automation control.
    INT8U PKTCTRL0;  // Packet automation control.
    INT8U ADDR;      // Device address.
    INT8U PKTLEN;    // Packet length.
} RF_SETTINGS;
const RF_SETTINGS rfSettings =
    0x00,
    0x06,   // FSCTRL1  频率合成器的控制
    0x00,   // FSCTRL0  频率合成器的控制
    0x10,   // FREQ2    频率控制字,高字节
    0xA7,   // FREQ1    频率控制字,中间字节
    0x62,   // FREQ0    频率控制字,低字节
    0x5B,   // MDMCFG4  调制解调器配置
    0xF8,   // MDMCFG3  调制解调器配置
    0x03,   // MDMCFG2  调制解调器配置
    0x22,   // MDMCFG1  调制解调器配置
    0xF8,   // MDMCFG0  调制解调器配置
    0x00,   // CHANNR    频道号码
    0x47,   // DEVIATN   现代偏差设置(如果启用了移频键控调制)
    0x56,   // FREND1    阵线end x光或类型
    0x10,   // FREND0    阵线end x光或类型
    0x18,   // MCSM0     主要的无线电控制状态机配置
    0x16,   // FOCCFG    频率偏移补偿配置
    0x6C,   // BSCFG     比特同步配置
    0x03,   // AGCCTRL2  自动增益控制
    0x40,   // AGCCTRL1  自动增益控制
    0x91,   // AGCCTRL0  自动增益控制
    0xEA,   // FSCAL3    频率合成器校准
    0x2A,   // FSCAL2    频率合成器校准
    0x00,   // FSCAL1    频率合成器校准
    0x1F,   // FSCAL0    频率合成器校准
    0x59,   // FSTEST    频率合成器校准
    0x88,   // TEST2     各种测试设置
    0x31,   // TEST1     各种测试设置
    0x09,   // TEST0     各种测试设置
    0x29,   // IOCFG2    GDO2输出管脚排列
    0x06,   // IOCFG0D   GDO0输出管脚排列。
            // 指SmartRF吗?工作室用户手册详细伪寄存器的解释
    0x04,   // PKTCTRL1  包自动化控制
    0x05,   // PKTCTRL0  包自动化控制
    0x00,   // ADDR      设备地址
    0x0c    // PKTLEN    数据包长度
static void delay(unsigned int s)
        unsigned int i;
        for(i=0; i<s; i++);
        for(i=0; i<s; i++);
void halWait(INT16U timeout) //18us
char i;
    do {
       for(i=0; i<2; i++);
    } while (--timeout);
//****************************SPI接口初始化***************************
void SpiInit(void)
   ANS4=0;      // CSN
   ANS6=0;      // SCLK
   ANS10=0;     // SI
   TRISC0=0;    // CSN   输出
   TRISC2=0;    // SCLK  输出
   RC0=0;
   RC2=0;
   RC0=1;
   TRISB4=0;    //  SI  输出
   TRISC1=1;    // SO  输入
   TRISA2=1;    // GDO0 输入
//***********************SPI初始化***********************
void CpuInit(void)
        SpiInit();
        delay(5000);
//函数名:SpisendByte(INT8U dat)
//输入:发送的数据
//输出:无
//功能描述:SPI发送一个字节
INT8U SpiTxRxByte(INT8U dat)
//----------------------以下是模拟SPI时序方式-----------------------------------
        INT8U i,temp;
        temp = 0;
        SCK_0 ;
        for(i=0; i<8; i++)
                if(dat&0x80)
              MOSI_1;
                else
                   MOSI_0;
                dat <<= 1;
                SCK_1;
           halWait(2);
                temp <<= 1;
        if(RC1==1)temp++;  //读取MISO状态
                SCK_0 ;
          halWait(2);
        return temp;
//函数名:void RESET_CC1100(void)
//输入:无
//输出:无
//功能描述:复位CC1100
        CSN_0 ;
        while (RC1==1);
    SpiTxRxByte(CCxxx0_SRES);                 //写入复位命令
        while (RC1==1);
        CSN_1;
//函数名:void POWER_UP_RESET_CC1100(void)
//输入:无
//输出:无
//功能描述:上电复位CC1100
        CSN_1;
        halWait(1);
        CSN_0 ;
        halWait(1);
        CSN_1;
        halWait(41);
        RESET_CC1100();                   //复位CC1100
//函数名:void halSpiWriteReg(INT8U addr, INT8U value)
//输入:地址和配置字
//输出:无
//功能描述:SPI写寄存器
    CSN_0;
    while(RC1==1);
    SpiTxRxByte(addr);                //写地址
    SpiTxRxByte(value);                //写入配置
    CSN_1;
//函数名:void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count)
//输入:地址,写入缓冲区,写入个数
//输出:无
//功能描述:SPI连续写配置寄存器
    INT8U i, temp;
    temp = addr | WRITE_BURST;
    CSN_0;
    while (RC1==1);
    SpiTxRxByte(temp);
    for (i = 0; i< count; i++)
        SpiTxRxByte(buffer[i]);
    CSN_1;
// ****************************SPI写命令******************************
    CSN_0;
    while (RC1==1);
    SpiTxRxByte(strobe);                //写入命令
    CSN_1;
//函数名:INT8U halSpiReadReg(INT8U addr)
//输入:地址
//输出:该寄存器的配置字
//功能描述:SPI读寄存器
    INT8U value,temp;
        temp = addr | READ_SINGLE;                //写入要读的状态寄存器的地址同时写入读命令
    CSN_0;
    while (RC1==1);
    SpiTxRxByte(temp);
        value = SpiTxRxByte(0);
        CSN_1;
        return value;
//******************************SPI连续读配置寄存器***********************
    INT8U i,temp;
        temp = addr | READ_BURST;                //写入要读的配置寄存器地址和读命令
    CSN_0;
    while (RC1==1);
        SpiTxRxByte(temp);
    for (i = 0; i < count; i++)
        buffer[i] = SpiTxRxByte(0);
    CSN_1;
//************************SPI读状态寄存器****************************
    INT8U value,temp;
        temp = addr | READ_BURST;                //写入要读的状态寄存器的地址同时写入读命令
    CSN_0;
    while (RC1==1);
    SpiTxRxByte(temp);
        CSN_1;
        return value;
//****************配置CC1101的寄存器*******************
halSpiWriteReg(CCxxx0_FSCTRL0,  rfSettings.FSCTRL2);//×???????
delay(50);
    // Write register settings
    halSpiWriteReg(CCxxx0_FSCTRL1,  rfSettings.FSCTRL1);
    delay(50);
    halSpiWriteReg(CCxxx0_FSCTRL0,  rfSettings.FSCTRL0);
    delay(50);
    halSpiWriteReg(CCxxx0_FREQ2,    rfSettings.FREQ2);
    delay(50);
    halSpiWriteReg(CCxxx0_FREQ1,    rfSettings.FREQ1);
    delay(50);
    halSpiWriteReg(CCxxx0_FREQ0,    rfSettings.FREQ0);
    delay(50);
    halSpiWriteReg(CCxxx0_MDMCFG4,  rfSettings.MDMCFG4);
    delay(50);
    halSpiWriteReg(CCxxx0_MDMCFG3,  rfSettings.MDMCFG3);
    delay(50);
    halSpiWriteReg(CCxxx0_MDMCFG2,  rfSettings.MDMCFG2);
    delay(50);
    halSpiWriteReg(CCxxx0_MDMCFG1,  rfSettings.MDMCFG1);
    delay(50);
    halSpiWriteReg(CCxxx0_MDMCFG0,  rfSettings.MDMCFG0);
    delay(50);
    halSpiWriteReg(CCxxx0_CHANNR,   rfSettings.CHANNR);
    delay(50);
    halSpiWriteReg(CCxxx0_DEVIATN,  rfSettings.DEVIATN);
    delay(50);
    halSpiWriteReg(CCxxx0_FREND1,   rfSettings.FREND1);
    delay(50);
    halSpiWriteReg(CCxxx0_FREND0,   rfSettings.FREND0);
    delay(50);
    halSpiWriteReg(CCxxx0_MCSM0 ,   rfSettings.MCSM0 );
    delay(50);
    halSpiWriteReg(CCxxx0_FOCCFG,   rfSettings.FOCCFG);
    delay(50);
    halSpiWriteReg(CCxxx0_BSCFG,    rfSettings.BSCFG);
    delay(50);
    halSpiWriteReg(CCxxx0_AGCCTRL2, rfSettings.AGCCTRL2);
    delay(50);
        halSpiWriteReg(CCxxx0_AGCCTRL1, rfSettings.AGCCTRL1);
    delay(50);
    halSpiWriteReg(CCxxx0_AGCCTRL0, rfSettings.AGCCTRL0);
    delay(50);
    halSpiWriteReg(CCxxx0_FSCAL3,   rfSettings.FSCAL3);
    delay(50);
        halSpiWriteReg(CCxxx0_FSCAL2,   rfSettings.FSCAL2);
    delay(50);
        halSpiWriteReg(CCxxx0_FSCAL1,   rfSettings.FSCAL1);
    delay(50);
    halSpiWriteReg(CCxxx0_FSCAL0,   rfSettings.FSCAL0);
    delay(50);
    halSpiWriteReg(CCxxx0_FSTEST,   rfSettings.FSTEST);
    delay(50);
    halSpiWriteReg(CCxxx0_TEST2,    rfSettings.TEST2);
    delay(50);
    halSpiWriteReg(CCxxx0_TEST1,    rfSettings.TEST1);
    delay(50);
    halSpiWriteReg(CCxxx0_TEST0,    rfSettings.TEST0);
    delay(50);
    halSpiWriteReg(CCxxx0_IOCFG2,   rfSettings.IOCFG2);
    halSpiWriteReg(CCxxx0_IOCFG0,   rfSettings.IOCFG0);
    delay(50);
    halSpiWriteReg(CCxxx0_PKTCTRL1, rfSettings.PKTCTRL1);
    delay(50);
    halSpiWriteReg(CCxxx0_PKTCTRL0, rfSettings.PKTCTRL0);
    delay(50);
    halSpiWriteReg(CCxxx0_ADDR,     rfSettings.ADDR);
    delay(50);
    halSpiWriteReg(CCxxx0_PKTLEN,   rfSettings.PKTLEN);
//函数名:void halRfSendPacket(INT8U *txBuffer, INT8U size)
//输入:发送的缓冲区,发送数据个数
//输出:无
//功能描述:CC1100发送一组数据
    halSpiWriteReg(CCxxx0_TXFIFO, size);
    halSpiWriteBurstReg(CCxxx0_TXFIFO, txBuffer, size);        //写入要发送的数据
    halSpiStrobe(CCxxx0_STX);                //进入发送模式发送数据
    // Wait for GDO0 to be set -> sync transmitted
    //while (!(RA2==1));
    // Wait for GDO0 to be cleared -> end of packet
    //while (RA2==1);
    halWait(1500);
        halSpiStrobe(CCxxx0_SFTX);
void setRxMode(void)
    halSpiStrobe(CCxxx0_SRX);                //进入接收状态
    INT8U status[2];
    INT8U packetLength;
        INT8U i=(*length)*4;  // ?????à?????ù??datarate??length?????¨
    halSpiStrobe(CCxxx0_SRX);                //????????×???
        //delay(5);
    //while (!GDO1);
    //while (GDO1);
        delay(2);
        while (1)
                delay(2);
                --i;
                if(i<1)
                   return 0;
    if ((halSpiReadStatus(CCxxx0_RXBYTES) & BYTES_IN_RXFIFO)) //????????×?????????0
        packetLength = halSpiReadReg(CCxxx0_RXFIFO);//??????????×???????×??????????????¤??
        if (packetLength <= *length)                 //?????ù???????§?????¤??????????????????????°ü???¤??
            halSpiReadBurstReg(CCxxx0_RXFIFO, rxBuffer, packetLength); //?????ù??????????????
            *length = packetLength;                                //°??????????¤???????????±?°???????¤??
            // Read the 2 appended status bytes (status[0] = RSSI, status[1] = LQI)
            halSpiReadBurstReg(CCxxx0_RXFIFO, status, 2);         //????CRC???é??
                        halSpiStrobe(CCxxx0_SFRX);                //??????????????
            return (status[1] & CRC_OK);                        //???????é????????????????
                 else
            return 0;
        else
        return 0;
void IO_init()
  //OSCCON = 0x75;  //内部晶振选为8M
  OSCCON = 0x65;  //内部晶振选为4M
  TRISA=0x00;
  PORTA=0x01;
  TRISB=0x00;
  PORTB=0x00;
  TRISC=0x00;
  PORTC=0x00; //把所有的引脚设置为输出,低电平。
  RA3=1; // MCLR引脚必须处于逻辑高电平
  RC5=0; //控制CC1101供电 1关闭 0开启
  RB7=1; //关闭ADC供电
void main()
    INT8U leng =0;
    count0=0;
        INT8U TxBuf[8]={0};
        INT8U RxBuf[8]={0};
    RA0=1;
    IO_init();
        CpuInit();
    RA0=1;
        POWER_UP_RESET_CC1100();
        halRfWriteRfSettings();
        halSpiWriteBurstReg(CCxxx0_PATABLE,PaTabel, 8);
    TxBuf[1] = 0x01 ;
        TxBuf[2] = 0x01 ;
    RxBuf[2] = 0x01 ;
    while(1)
       // halRfSendPacket(TxBuf,8);
        leng =8;
      if(halRfReceivePacket(RxBuf,leng))
      //if(1)
           if(RxBuf[2]==0x01)
              RA0=0;
                      delay(800);
                          RA0=1;
              delay(800);
              RA0=0;
                      delay(800);
                          RA0=1;
              delay(800);
              RxBuf[2] = 0xff;
            RA0=1;
                    RxBuf[2] = 0xff;
            halSpiStrobe(CCxxx0_SIDLE );
            delay(100);
 楼主| 拖拉机小司机 发表于 2019-11-8 09:35 | 显示全部楼层
求各位大哥指导一下,头发快挠完了
linxi6414 发表于 2019-11-13 15:10 | 显示全部楼层
楼主你的空中速率是多少?请看我的贴子,我的空中速率为250K的,正常,想改为2.4K的,就是改不好,你的调通了吗?
 楼主| 拖拉机小司机 发表于 2019-11-18 16:23 | 显示全部楼层
楼主你的空中速率是多少?请看我的贴子,我的空中速率为250K的,正常,想改为2.4K的,就是改不好,你的调通 ...
就是问题一直没解决
linxi6414 发表于 2019-11-18 18:32 | 显示全部楼层
准备直接买一个成品的串口模块,然后把SPI协议读出来,分析一下看看。
