封装一个动态库
894|6
 楼主| kangzj 发表于 2019-11-21 20:17 | 显示全部楼层 |阅读模式
需要用cypress的USB通信库封装一个动态库供上层调用。小弟写了一个,可是调用的时候发现写数据有问题。写两次才有一次返回
zwll 发表于 2019-11-21 20:21 | 显示全部楼层
正常情况呢
 楼主| kangzj 发表于 2019-11-21 20:26 | 显示全部楼层
应该是每次都有数据返回。
dingy 发表于 2019-11-21 20:29 | 显示全部楼层
程序看看
 楼主| kangzj 发表于 2019-11-21 20:32 | 显示全部楼层
//打开USB端口
int CUSBPrintDLL::Open()
int i = 0;
int iDeviceNum = 0;
//获取设备数目
iDeviceNum = m_pUSBDevice->DeviceCount();
// make sure there is at lesat one device out there
if (iDeviceNum == 0)
  return 1;
// search for all connected devices
for ( i = 0; i < iDeviceNum; i++)
  //Only Get the Bulkloop back compatinle device
  m_pUSBDevice->Open(i);
  //Get config descriptor
  USB_CONFIGURATION_DESCRIPTOR ConfDesc;
  m_pUSBDevice->GetConfigDescriptor(&ConfDesc);
  // Number of interface one
  if(ConfDesc.bNumInterfaces == 1)
   //Get Interface descriptor
   USB_INTERFACE_DESCRIPTOR IntfDesc;
   m_pUSBDevice->GetIntfcDescriptor(&IntfDesc);
   if(IntfDesc.bAlternateSetting == 0)
    // Number of endpoint is 2
    if(IntfDesc.bNumEndpoints == 2)
     m_DeviceIndex = i;
     break;
  }//if number
}//for
//无符合要求的设备
if (i == iDeviceNum)
  return 1;
m_pUSBDevice->Open(m_DeviceIndex);
//获取所有端点
int epts = m_pUSBDevice->EndPointCount();
CCyUSBEndPoint *endpt;
for (i=1; i<epts; i++)
  endpt = m_pUSBDevice->EndPoints[i];
  if (endpt->Attributes == 2)    // Bulk
   if (endpt->Address & 0x80)
    m_pInEndPt =  m_pUSBDevice->EndPoints[i];
   else
    m_pOutEndPt = m_pUSBDevice->EndPoints[i];
//设置读、写超时时间
m_pOutEndPt->TimeOut = 0;
m_pInEndPt->TimeOut = 0;
m_pOutEndPt->TimeOut = 2000;
m_pInEndPt->TimeOut = 2000;
//设置可用标记
m_bEnable = true;
return 0;
//往USB端口发送数据
LONG CUSBPrintDLL::Write( const char *buffer,LONG length )
if (!m_bEnable || !m_pUSBDevice->Open(m_DeviceIndex))
  return 0;
LONG lBufLen = length;
if(!m_pOutEndPt->XferData((PUCHAR)buffer,lBufLen))
  m_pUSBDevice->Reset();
  return 0;
return lBufLen;
//从USB端口读取数据
LONG CUSBPrintDLL::Read( char *buffer,LONG length )
//未进行初始化
if(!m_bEnable || !m_pUSBDevice->Open(m_DeviceIndex))
  return 0;
if (!m_pInEndPt->XferData((PUCHAR)buffer,length))
  return 0;
return length;
renyaq 发表于 2019-11-21 20:35 | 显示全部楼层
建议楼主看看SuiteUSB  - USB Development tools for Visual Studio中的DLL参考例子看看
 楼主| kangzj 发表于 2019-11-21 20:38 | 显示全部楼层
搞定了,呵呵,犯了低级错误……结贴啦,多谢各位
