[DemoCode下载] 硬件除法器的使用
970|4
 楼主| 小明的同学 发表于 2019-11-30 18:14 | 显示全部楼层 |阅读模式
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V2.10
  4. * $Revision: 3 $
  5. * $Date: 14/01/28 11:44a $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series Timer Controller and Watchdog Timer Driver Sample Code
  7. *
  8. * @note
  9. * Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
  10. *
  11. ******************************************************************************/
  12. #include <stdio.h>
  13. #include "M051Series.h"
  14. #define PLLCON_SETTING      CLK_PLLCON_50MHz_XTAL
  15. #define PLL_CLOCK           50000000
  16. void SYS_Init(void)
  17. {
  18.     /*---------------------------------------------------------------------------------------------------------*/
  19.     /* Init System Clock        */
  20.     /*---------------------------------------------------------------------------------------------------------*/
  21.     /* Enable External XTAL (4~24 MHz) */
  22.     CLK->PWRCON &= ~CLK_PWRCON_XTL12M_EN_Msk;
  23.     CLK->PWRCON |= (0x1 << CLK_PWRCON_XTL12M_EN_Pos); // XTAL12M (HXT) Enabled
  24.     /* Waiting for 12MHz clock ready */
  25.     while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_XTL12M_STB_Msk));
  26.     /* Enable IP clock */
  27.     CLK->APBCLK |= CLK_APBCLK_UART0_EN_Msk; // UART Clock Enable
  28.     /* Select IP clock source */
  29.     CLK->CLKSEL1 &= ~CLK_CLKSEL1_UART_S_Msk;
  30.     CLK->CLKSEL1 |= (0x0 << CLK_CLKSEL1_UART_S_Pos);// Clock source from external 12 MHz
  31.     /* Set P30(RXD0),P31(TXD0) multi-function pins for UART0 RXD and TXD  */
  32.     SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
  33. }
  34. void UART0_Init(void)
  35. {
  36.     /*---------------------------------------------------------------------------------------------------------*/
  37.     /* Init UART        */
  38.     /*---------------------------------------------------------------------------------------------------------*/
  39.     /* Configure UART0 and set UART0 Baudrate */
  40.     UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
  41.     UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
  42. }
  43. void HDIV_Init(void)
  44. {
  45.     /* Enable Hardware Divider Clock */
  46.     CLK->AHBCLK |= CLK_AHBCLK_HDIV_EN_Msk;
  47. }
  48. /*---------------------------------------------------------------------------------------------------------*/
  49. /*  MAIN function        */
  50. /*---------------------------------------------------------------------------------------------------------*/
  51. int main(void)
  52. {
  53.     /* Disable register write-protection function */
  54.     SYS_UnlockReg();
  55.     /* Init System, IP clock and multi-function I/O */
  56.     SYS_Init();
  57.     /* Init UART0 for printf */
  58.     UART0_Init();
  59.     /* Init Divider */
  60.     HDIV_Init();
  61.     printf("+----------------------------------------------+\n");
  62.     printf("|    M05xx Divider Sample Code                 |\n");
  63.     printf("+----------------------------------------------+\n");
  64.     printf("\n");
  65.     printf("12341 / 123 = %d\n", HDIV_Div(12341, 123));
  66.     printf("12341 %% 123 = %d\n", HDIV_Mod(12341, 123));
  67.     /* Lock protected registers */
  68.     SYS_LockReg();
  69.     printf("Done\n");
  70.     while(SYS->PDID);
  71.     return 0;
  72. }
 楼主| 小明的同学 发表于 2019-11-30 18:15 | 显示全部楼层
这种不知道支持小数吗,我看支持余数计算。不知道支持计算小数不。
zhuotuzi 发表于 2019-11-30 21:10 来自手机 | 显示全部楼层
好多时候大家都想不起来用这个
天灵灵地灵灵 发表于 2019-12-2 18:46 | 显示全部楼层
我去试试看
幸福小强 发表于 2019-12-2 21:54 | 显示全部楼层
这种还真是想不起来用。
