[活动] EFM8BB1测评——串口
763|0
 楼主| Cjy_JDxy 发表于 2019-12-1 14:58 | 显示全部楼层 |阅读模式
今天捣鼓了一下串口。
代码:
// Includes
#include <SI_EFM8BB1_Register_Enums.h>
#include "retargetserial.h"
#include "InitDevice.h"
// SiLabs_Startup() Routine
// This function is called immediately after reset, before the initialization
// code is run in SILABS_STARTUP.A51 (which runs before main() ). This is a
// useful place to disable the watchdog timer, which is enable by default
// and may trigger before main() in some instances.
void SiLabs_Startup (void)
  // Disable the watchdog here
// Main Routine
void main (void)
   unsigned char inputcharacter;       // Used to store character from UART
   enter_DefaultMode_from_RESET();
   SCON0_TI = 1;                       // This STDIO library requires TI to
                                       // be set for prints to occur
   while (1)
      RETARGET_PRINTF ("\nEnter character: ");
      inputcharacter = getchar();
      RETARGET_PRINTF ("\nCharacter entered: %c", inputcharacter);
      RETARGET_PRINTF ("\n     Value in Hex: %bx", inputcharacter);
效果图:
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
