- void ADC_Init(void)
-         rcu_periph_clock_enable(RCU_ADC);
-         rcu_periph_clock_enable(RCU_GPIOA);
-         rcu_periph_clock_enable(RCU_GPIOC);
-         rcu_adc_clock_config(RCU_ADCCK_APB2_DIV8);        // 10MHz
-         gpio_mode_set(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_0);
-         gpio_mode_set(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_1);
-         gpio_mode_set(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_2);
-         gpio_mode_set(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_3);
-         gpio_mode_set(GPIOA, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_5);
-         gpio_mode_set(GPIOC, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_0);
-         gpio_mode_set(GPIOC, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_1);
-         gpio_mode_set(GPIOC, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_2);
-         gpio_mode_set(GPIOC, GPIO_MODE_ANALOG, GPIO_PUPD_NONE, GPIO_PIN_3);
-         // 规则排序可以改变每个通道采回来的值,对应DMA数组的下标
-         adc_channel_length_config(ADC_REGULAR_CHANNEL, 9);          // 规则组
-         adc_regular_channel_config(0, ADC_CHANNEL_10, ADC_SAMPLETIME_239POINT5);        // 通道10: PC0
-         adc_regular_channel_config(1, ADC_CHANNEL_11, ADC_SAMPLETIME_239POINT5);        // 通道11: PC1
-         adc_regular_channel_config(2, ADC_CHANNEL_12, ADC_SAMPLETIME_239POINT5);        // 通道12: PC2
-         adc_regular_channel_config(3, ADC_CHANNEL_13, ADC_SAMPLETIME_239POINT5);        // 通道13: PC3 3.3v
-         adc_regular_channel_config(4, ADC_CHANNEL_0,  ADC_SAMPLETIME_239POINT5);        // 通道00: PA0
-         adc_regular_channel_config(5, ADC_CHANNEL_1,  ADC_SAMPLETIME_239POINT5);        // 通道01: PA1
-         adc_regular_channel_config(6, ADC_CHANNEL_2,  ADC_SAMPLETIME_239POINT5);        // 通道02: PA2
-         adc_regular_channel_config(7, ADC_CHANNEL_3,  ADC_SAMPLETIME_239POINT5);        // 通道04: PA3
-         adc_regular_channel_config(8, ADC_CHANNEL_5,  ADC_SAMPLETIME_239POINT5);        // 通道05: PA5 3.3V
-         //12位ADC的转换时间为(239.5+12.5)/10 = 25.2us added by eagle
-         adc_external_trigger_config(ADC_REGULAR_CHANNEL, ENABLE);        // 规则组触发使能
-         adc_external_trigger_source_config(ADC_REGULAR_CHANNEL, ADC_EXTTRIG_REGULAR_NONE);
-         adc_data_alignment_config(ADC_DATAALIGN_RIGHT);         // 数据右对齐
-         adc_enable();
-         //delay_1ms(1);
-         adc_calibration_enable();
-         adc_special_function_config(ADC_SCAN_MODE, ENABLE);                // 扫描模式使能
-         adc_special_function_config(ADC_CONTINUOUS_MODE, ENABLE);    // 连续转换模式使能
-         adc_dma_mode_enable();                                                               // DMA请求
-         ADC_DMAInit();
-         dma_channel_enable(DMA_CH0);
-         adc_interrupt_flag_clear(ADC_INT_FLAG_EOC);
-         nvic_priority_group_set(NVIC_PRIGROUP);
-         nvic_irq_enable(ADC_CMP_IRQn, PRI_ADC);
-         adc_interrupt_enable(ADC_INT_EOC);        // added by eagle
-         adc_software_trigger_enable(ADC_REGULAR_CHANNEL);
- void ADC_DMAInit(void)
-         dma_parameter_struct  dma_init_struct;
-         rcu_periph_clock_enable(RCU_DMA);
-         dma_deinit(DMA_CH0);
-         dma_init_struct.direction    = DMA_PERIPHERAL_TO_MEMORY;        // 外设到内存
-         dma_init_struct.memory_addr  = (uint32)Adc_HwValue;                // 内存地址
-         dma_init_struct.memory_inc   = DMA_MEMORY_INCREASE_ENABLE;        // 内存地址增量
-         dma_init_struct.memory_width = DMA_MEMORY_WIDTH_16BIT;                // 内存地址长度
-         dma_init_struct.number       = FILTER_SAMPLES*ADC_CHN_SIZE;        // 传输数据总长度
-         dma_init_struct.periph_addr  = (uint32)&ADC_RDATA;                        // 外设地址
-         dma_init_struct.periph_inc   = DMA_PERIPH_INCREASE_DISABLE;        // 外设地址增量
-         dma_init_struct.periph_width = DMA_PERIPHERAL_WIDTH_16BIT;        // 外设地址长度
-         dma_init_struct.priority     = DMA_PRIORITY_MEDIUM;                        // 优先级
-         dma_init(DMA_CH0, &dma_init_struct);
-         dma_circulation_enable(DMA_CH0);
-         dma_memory_to_memory_disable(DMA_CH0);
