stm32的can实验 发送程序有问题
2965|0
 楼主| chenzongxi 发表于 2011-11-27 11:09 | 显示全部楼层 |阅读模式
#include "stm32f10x.h"
unsigned char TxTest;
void RCC_Configuration(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD | RCC_APB2Periph_AFIO,ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1,ENABLE);
void GPIO_Configuration(void)                            //用重映射功能,
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;;
GPIO_Init(GPIOC,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;     //RX
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;     //TX
GPIO_Init(GPIOD,&GPIO_InitStructure);
GPIO_PinRemapConfig(GPIO_Remap2_CAN1,ENABLE);
unsigned char CAN_Configuration(void)
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;         //初始化
CanTxMsg TxMessage;             //发送
volatile u8 TxMailBox = 0;
u32 i;
CAN_DeInit(CAN1);           //缺省模式
CAN_StructInit(&CAN_InitStructure);
CAN_InitStructure.CAN_TTCM = DISABLE;
CAN_InitStructure.CAN_ABOM = DISABLE;
CAN_InitStructure.CAN_AWUM = DISABLE;
CAN_InitStructure.CAN_NART = DISABLE;
CAN_InitStructure.CAN_RFLM = DISABLE;
CAN_InitStructure.CAN_TXFP = DISABLE;
CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
CAN_InitStructure.CAN_BS1 = CAN_BS1_3tq;
CAN_InitStructure.CAN_BS2 = CAN_BS2_2tq;
CAN_InitStructure.CAN_Prescaler = 12;
CAN_Init(CAN1,&CAN_InitStructure);      //CAN初始化有返回值  #define CANINITFAILED ((uint8_t)0x00)
    //Error =CAN_Init(&CAN_InitStructure);
    // if (Error == 0)
    // return FAILED;  //判断初始化 是否成功  不成功我们会有灯显示
//CAN_ITConfig(CAN1,CAN_IT_FMP0,ENABLE);                     //有一个消息就中断,FIFO0中断
  CAN_FilterInitStructure.CAN_FilterNumber = 1;
  CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
  CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
/* (注:标准帧数据帧、标准远程帧和扩展远程帧均被过滤)*/
TxMessage.StdId = 0x321;
TxMessage.ExtId =0x01;         //扩展帧
TxMessage.IDE = CAN_ID_STD;
TxMessage.RTR = CAN_RTR_DATA;        //数据帧
TxMessage.DLC = 2;
TxMessage.Data[0] = 0x12;
TxMessage.Data[1] = 0x34;
CAN_Transmit(CAN1,&TxMessage);
TxMailBox = CAN_Transmit(CAN1,&TxMessage);
i=0;
while((CAN_TransmitStatus(CAN1,TxMailBox)!=CANTXOK) && (i != 0xff))
  i++;
if(i==0xff)
  return 0;
else
  return 1;
void Delay(vu32 times)
for(;times!=0;times--);
int main(void)
  RCC_Configuration();
  GPIO_Configuration();;
  CAN_Configuration();
  while(1)
   TxTest = CAN_Configuration();
   if(TxTest==1)
   GPIO_SetBits(GPIOC,GPIO_Pin_5);
   Delay(1000000);
   GPIO_ResetBits(GPIOC,GPIO_Pin_5);
   Delay(1000000);
  if(TxTest==0)
   GPIO_SetBits(GPIOC,GPIO_Pin_6);
    Delay(1000000);
    GPIO_ResetBits(GPIOC,GPIO_Pin_6);
    Delay(1000000);
只有发送程序,没有接收,发送成功,PC5对应LED亮灭,发送失败,PC6对应LED亮灭,现在是发送失败,不知道那里有问题,还请高手讲解。
用的是103
