今晚捣鼓了一下TN9,红外体温计模块。
代码:
#include "main.h"
/** @addtogroup Projects_Examples_MD
/** @addtogroup Examples
#define uchar unsigned char
#define uint unsigned int
void ACK_0() { md_gpio_set_pin_low(ACK_GPIO_PORT, ACK_GPIO_PIN);} //
void ACK_1() { md_gpio_set_pin_high(ACK_GPIO_PORT, ACK_GPIO_PIN);}
#define DATA md_gpio_get_input_data(DATA_GPIO_PORT, DATA_GPIO_PIN)
#define CLOCK md_gpio_get_input_data(CLOCK_GPIO_PORT, CLOCK_GPIO_PIN)
float Temp;
float Temp1,Temp2;
unsigned char ReadData[5];
unsigned int a,b;
//????:Delay()
void Delay(unsigned char us) //5,7,9
while(--us);
//????:Delayms()
void Delayms(unsigned int ims)
unsigned int i,j;
for(i=0;i<ims;i++)
for(j=0;j<65;j++) { Delay(1); }
* @brief This function configures GPIO
* @param None
* @retval None
void config_gpio(void)
md_gpio_set_pin_function(CLOCK_GPIO_PORT, CLOCK_GPIO_PIN, GPIO_FUNC_1);
md_gpio_set_pin_push_pull(CLOCK_GPIO_PORT, CLOCK_GPIO_PIN);
md_gpio_set_pin_mode_input(CLOCK_GPIO_PORT, CLOCK_GPIO_PIN);
md_gpio_set_pin_function(DATA_GPIO_PORT, DATA_GPIO_PIN, GPIO_FUNC_1);
md_gpio_set_pin_push_pull(DATA_GPIO_PORT, DATA_GPIO_PIN);
md_gpio_set_pin_mode_input(DATA_GPIO_PORT, DATA_GPIO_PIN);
md_gpio_set_pin_function(ACK_GPIO_PORT, ACK_GPIO_PIN, GPIO_FUNC_1);
md_gpio_set_pin_push_pull(ACK_GPIO_PORT, ACK_GPIO_PIN);
md_gpio_set_pin_mode_output(ACK_GPIO_PORT, ACK_GPIO_PIN);
md_gpio_set_pin_function(LED2_GPIO_PORT, LED2_GPIO_PIN, GPIO_FUNC_1);
md_gpio_set_pin_push_pull(LED2_GPIO_PORT, LED2_GPIO_PIN);
md_gpio_set_pin_mode_output(LED2_GPIO_PORT, LED2_GPIO_PIN);
void TN_IRACK_EN(void)
ACK_0();
Delay(1);
void TN_IRACK_UN(void)
ACK_1();
Delay(1);
void TN_ReadData(unsigned char Flag)
unsigned char i,j,k,BitState=0;
for(k=0;k<7;k++)
for(j=0;j<5;j++)
for(i=0;i<8;i++)
while(1)
if(CLOCK==0)
break;
Delay(1);
Delay(1);
if(DATA==1)
BitState=1;
else
BitState=0;
ReadData[j]= ReadData[j]<<1;
ReadData[j]= ReadData[j]|BitState;
Delay(1);
while(1)
if(CLOCK==1)
break;
Delay(1);
if(ReadData[0]==Flag)
k=8;
TN_IRACK_UN();
float TN_GetData(unsigned char X)
//Ack_Clk_Data_init;
config_gpio();
TN_ReadData(X);
Temp=(ReadData[1]<<8)|ReadData[2];
Temp=(float)Temp/16.00-273.15;
return Temp;
float TN_GetTemp(unsigned char mode)
float T;
TN_IRACK_UN();
TN_IRACK_EN();
if(mode==0)
T=TN_GetData(0x4c);
else
T=TN_GetData(0x66);
return T;
* @brief Test main function
* @retval Status.
int main()
md_init_1ms_tick();
config_gpio();
while (1)
Temp1=TN_GetTemp(0);
Temp2=TN_GetTemp(1);
a=((unsigned int)(Temp1*10));
b=((unsigned int)(Temp2*10));
Delayms(1500);
效果图:
a是体温,b是环境温度。
把手靠近TN9,指示30来度,否则和环境温度差不多。
