[国产单片机] 【东软载波ESF0654 PDS开发板活动】+ AT24C04
840|8
 楼主| Cjy_JDxy 发表于 2019-12-18 18:58 | 显示全部楼层 |阅读模式
今晚捣鼓了一下AT24C04,模拟时序,开漏输出。
代码:
#include "main.h"
/** @addtogroup Projects_Examples_MD
/** @addtogroup Examples
#define uchar unsigned char
#define uint  unsigned int
#define SDA_L            md_gpio_set_pin_low(SDA_GPIO_PORT, SDA_GPIO_PIN);
#define SDA_H            md_gpio_set_pin_high(SDA_GPIO_PORT, SDA_GPIO_PIN);
#define SDA                                                        md_gpio_get_input_data(SDA_GPIO_PORT, SDA_GPIO_PIN)
#define SCL_L         md_gpio_set_pin_low(SCL_GPIO_PORT, SCL_GPIO_PIN);
#define SCL_H         md_gpio_set_pin_high(SCL_GPIO_PORT, SCL_GPIO_PIN);
unsigned char buffer[3];
* ?    ?: DelayMS()
* ?    ?: ????????,???????????16M(??????????)
* ????: msec ????,???,????
void DelayMS(uint msec)
    uint i,j;
    for (i=0; i<msec; i++)
        for (j=0; j<535; j++);
* ?    ?: InitLed()
* ?    ?: ??LED????IO?
void InitSDAInput(void)
            md_gpio_set_pin_function(SDA_GPIO_PORT, SDA_GPIO_PIN, GPIO_FUNC_1);
                        md_gpio_set_pin_push_pull(SDA_GPIO_PORT, SDA_GPIO_PIN);
                        md_gpio_set_pin_mode_input(SDA_GPIO_PORT, SDA_GPIO_PIN);
void InitSDAOutput(void)
                md_gpio_set_pin_mode_output(SDA_GPIO_PORT, SDA_GPIO_PIN);
                md_gpio_set_pin_open_drain(SDA_GPIO_PORT, SDA_GPIO_PIN);
//????:Delay()
void Delay(unsigned char us)  //5,7,9
  while(--us);
//????:Delayms()
void Delayms(unsigned int ims)
  unsigned int i,j;
    for(i=0;i<ims;i++)
      for(j=0;j<65;j++) { Delay(1); }
void Start()
        InitSDAOutput();
  SCL_H;
        Delay(10);
  SDA_H;
        Delay(10);
  SDA_L;
        Delay(10);
  SCL_L;
        Delay(10);
void Stop()
        InitSDAOutput();
  SDA_L;
        Delay(10);
  SCL_H;
        Delay(10);
  SDA_H;
        Delay(10);
char ACK ()
  char c;
        InitSDAOutput();
  SDA_H;
        Delay(10);
  SCL_H;
        Delay(10);
  InitSDAInput();
        Delay(10);
  if(SDA)
    c=1;
  else
    c=0;
        Delay(10);
  InitSDAOutput();
        Delay(10);
  SCL_L;
        Delay(10);
  return c;
void SendChar(unsigned char ch)
  unsigned char i;
  i=8;
        InitSDAOutput();
  do
    if((ch&0x80)==0x80)
      SDA_H;
    if((ch&0x80)==0x00)
      SDA_L;
                Delay(10);
    SCL_H;
                Delay(10);
    SCL_L;
                Delay(10);
    ch<<=1;
  }while(--i!=0);
unsigned char RecChar()
  unsigned char i,j;
  i=8;
  j=0;
        InitSDAInput();
        Delay(10);
  do
    SCL_H;
                Delay(10);
    j=(j<<1);
    if(SDA)
      j=j|SDA;
                Delay(10);
    SCL_L;
                Delay(10);
  }while(--i!=0);
        InitSDAOutput();
  return j;
void WriteChar(unsigned int addr,unsigned char ch)
  unsigned char c;
  c=((*((unsigned char *)&addr))<<1)&0x02;
  Start();
  SendChar(0xa0|c);
  ACK();
  SendChar(addr);
  ACK();
  SendChar(ch);
  ACK();
  Stop();
  for(ch=0xff;ch!=0;ch--) ;
unsigned char ReadChar(unsigned int addr)
  unsigned char ch;
  ch=((*((unsigned char *)&addr))<<1)&0x02;
  Start();
  SendChar(0xa0|ch);
  ACK();
  SendChar(addr);
  ACK();
  Start();
  SendChar(0xa1|ch);
  ACK();
  ch=RecChar();
  Stop();
  return ch;
  * @brief  This function configures GPIO
  * @param  None
  * @retval None
void config_gpio(void)
//        md_gpio_set_pin_function(CLOCK_GPIO_PORT, CLOCK_GPIO_PIN, GPIO_FUNC_1);
//        md_gpio_set_pin_push_pull(CLOCK_GPIO_PORT, CLOCK_GPIO_PIN);
//        md_gpio_set_pin_mode_input(CLOCK_GPIO_PORT, CLOCK_GPIO_PIN);
        md_gpio_set_pin_function(SCL_GPIO_PORT, SCL_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(SCL_GPIO_PORT, SCL_GPIO_PIN);
        md_gpio_set_pin_mode_output(SCL_GPIO_PORT, SCL_GPIO_PIN);
        md_gpio_set_pin_open_drain(SCL_GPIO_PORT, SCL_GPIO_PIN);
        md_gpio_set_pin_function(LED2_GPIO_PORT, LED2_GPIO_PIN, GPIO_FUNC_1);
        md_gpio_set_pin_push_pull(LED2_GPIO_PORT, LED2_GPIO_PIN);
        md_gpio_set_pin_mode_output(LED2_GPIO_PORT, LED2_GPIO_PIN);
  * @brief  Test main function
  * @retval Status.
int main()
        md_init_1ms_tick();
        config_gpio();
        buffer[0]=ReadChar(0);
        Delay(100);           //??????
        WriteChar(0,0x55);
        Delayms(20);
        WriteChar(1,0xaa);
        Delayms(20);
        WriteChar(2,0x18);
        Delayms(20);
        buffer[0]=ReadChar(1);
        buffer[1]=ReadChar(2);
        buffer[2]=ReadChar(0);
        while (1)
效果图:
ayb_ice 发表于 2019-12-19 13:52 | 显示全部楼层
这个语句很危险,与大小端有关系,移植性不好,可读性不好
 楼主| Cjy_JDxy 发表于 2019-12-19 16:57 | 显示全部楼层
是啊。你说怎么写好呢?大神
ayb_ice 发表于 2019-12-19 17:19 | 显示全部楼层
是啊。你说怎么写好呢?大神
这样你看行吗如果是小端格式,可以这样
c=(addr&0x01)?0x02:0x00;
c =( (addr & 0x01)<<1);
 楼主| Cjy_JDxy 发表于 2019-12-19 17:45 | 显示全部楼层
这样你看行吗如果是小端格式,可以这样
c =( (addr & 0x01) ...
没看懂啊?给我讲讲好吗?谢谢
ayb_ice 发表于 2019-12-20 08:35 | 显示全部楼层
没看懂啊?给我讲讲好吗?谢谢
如果强行把一个16位变量的地址强制转换成指向8位变量的指针,取出的值在大端模式与小端模式是不同的,
比如uint MyVar = 0x1234;
大端模式取到值是0x12,小端模式取到的值是0x34,显然这个代码移植性不好,而且BUG隐藏的很深
 楼主| Cjy_JDxy 发表于 2019-12-20 13:15 | 显示全部楼层
谢谢!你的代码是怎么避免这个问题得呢?
ayb_ice 发表于 2019-12-20 13:54 | 显示全部楼层
谢谢!你的代码是怎么避免这个问题得呢?
根本不需要使用指针,直接操作变量就可以避免这个问题,直接判断那个位值就可以了
 楼主| Cjy_JDxy 发表于 2019-12-20 14:16 | 显示全部楼层
根本不需要使用指针,直接操作变量就可以避免这个问题,直接判断那个位值就可以了 ...
好的
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
