[应用相关] [stm32] 中断
443|11
 楼主| deadtime 发表于 2020-1-1 16:49 | 显示全部楼层 |阅读模式
STM32, TI, IO, ni, pi
  1. #include  "stm32f10x.h"
  2. #include  "stm32f10x_tim.h"
  3. #include  "misc.h"
  4. #include  "stm32f10x_gpio.h"
  5. unsigned int CCR2_Val=45000;
  6. extern void time_ini(void);
  7. unsigned int capture1=0;
  8. TIM_TimeBaseInitTypeDef  TIM3_TimeBaseStructure;
  9. TIM_OCInitTypeDef  TIM3_OCInitStructure;
  10. TIM_BDTRInitTypeDef TIM3_BDTRInitStructure;
  11. void time_ini(void){
  12.   GPIO_InitTypeDef GPIO_InitStructure;
  13.   RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);            //定时器3 时钟使能
  14.
  15.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;                        //PB5复用为TIM3的通道2
  16.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  17.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  18.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  19.   /* TIM3局部复用功能开启     在TIM3的局部复用开启时,PB5会被复用为TIM3_CH2*/
  20.   GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3 , ENABLE);
  21.   /* Time Base configuration */
  22.   /*-------------------------------------------------------------------
  23.   TIM3CLK=72MHz  预分频系数Prescaler=63 经过分频 定时器时钟为1.125MHz
  24.   捕获/比较寄存器2 TIM3_CCR2= CCR2_Val
  25.   2通道产生的更新频率是=1.125MHz/CCR2_Val=25Hz
  26.
  27.   -------------------------------------------------------------------*/
  28.   TIM3_TimeBaseStructure.TIM_Prescaler = 630;                        //预分频器TIM3_PSC=630
  29.   TIM3_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;        //计数器向上计数模式 TIM3_CR1[4]=0
  30.   TIM3_TimeBaseStructure.TIM_Period =0xffff;                        //自动重装载寄存器TIM3_APR
  31.   TIM3_TimeBaseStructure.TIM_ClockDivision = 0x0;                    //时钟分频因子 TIM3_CR1[9:8]=00
  32.   TIM_TimeBaseInit(TIM3,&TIM3_TimeBaseStructure);                    //写TIM3各寄存器参数
  33.
  34.   TIM3_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle ;                //TIM3_CCMR1[14:12]=011  翻转 当TIM3_CCR2=TIM3_CNT时,翻转OC2REF的电平
  35.   TIM3_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;    //输入/捕获2输出允许  OC2信号输出到对应的输出引脚PB5
  36.   TIM3_OCInitStructure.TIM_Pulse =CCR2_Val;                            //若CC1通道配置为输出:CCR2是装入当前捕获/比较2 TIM3_CCR2寄存器的值(预装载值)。
  37.        //当前捕获/比较寄存器包含了与计数器TIM3_CNT比较的值,并且在OC端口上输出信号
  38.   TIM3_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;            //输出极性  低电平有效 TIM3_CCER[5]=1;
  39.   TIM_OC2Init(TIM3, &TIM3_OCInitStructure);
  40.   TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Disable);                //TIM3_CCMR1[1]=0  禁止TIM3_CCR2寄存器的预装载功能,可随时写入TIM3_CCR2
  41.        //且新值马上起作用
  42.    TIM_Cmd(TIM3,ENABLE);                                            //启动定时器3 TIM3_CR1[0]=1;
  43.    TIM_ITConfig(TIM3,TIM_IT_CC2,ENABLE);                             //TIM3_DIER[2]=1  允许捕获/比较2中断
  44. }
  45. void RCC_Configuration(void){
  46.   SystemInit();
  47.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  48.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
  49.                           | RCC_APB2Periph_GPIOD| RCC_APB2Periph_GPIOE , ENABLE);
  50. }
  51. void NVIC_Configuration(void)
  52. {
  53.   NVIC_InitTypeDef NVIC_InitStructure;
  54.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  55.   NVIC_InitStructure.NVIC_IRQChannel =TIM3_IRQn ;               //配置定时器中断
  56.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  57.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  58.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  59.   NVIC_Init(&NVIC_InitStructure);
  60. }
  61. int main(void)
  62. {
  63.   RCC_Configuration();                        //系统时钟设置及外设时钟使能
  64.   NVIC_Configuration();                         //中断源配置
  65.   time_ini();                                 //定时器3的初始化
  66.   while(1);
  67. }
  68. void TIM3_IRQHandler(void){
  69.
  70. if (TIM_GetITStatus(TIM3, TIM_IT_CC2) != RESET)        //判断状态寄存器 TIM3_SR[2] 是否发生了捕获/比较2 中断
  71.   {
  72.     TIM_ClearITPendingBit(TIM3, TIM_IT_CC2);            //软件清除状态寄存器 TIM3_SR[2] 捕获/比较2 中断中断标志
  73.     capture1 = TIM_GetCapture2(TIM3);                    //获取TIM3_CCR2的预装值
  74.     TIM_SetCompare2(TIM3, capture1+ CCR2_Val);            //和CCR2_Val累加后装入TIM3_CCR2     这是为了配合计数器值的递增。以在下一次作出比较。
  75.
  76.   }
  77. }
mmuuss586 发表于 2020-1-16 09:57 | 显示全部楼层
感谢分享
晓伍 发表于 2020-2-3 10:49 | 显示全部楼层
非常感谢楼主分享
八层楼 发表于 2020-2-3 10:54 | 显示全部楼层
非常感谢楼主分享
观海 发表于 2020-2-3 10:59 | 显示全部楼层
非常感谢楼主分享
guanjiaer 发表于 2020-2-3 11:01 | 显示全部楼层
非常感谢楼主分享
heimaojingzhang 发表于 2020-2-3 11:08 | 显示全部楼层
非常感谢楼主分享
keaibukelian 发表于 2020-2-3 11:13 | 显示全部楼层
非常感谢楼主分享
labasi 发表于 2020-2-3 11:16 | 显示全部楼层
非常感谢楼主分享
paotangsan 发表于 2020-2-3 11:22 | 显示全部楼层
非常感谢楼主分享
renzheshengui 发表于 2020-2-3 11:26 | 显示全部楼层
非常感谢楼主分享
wakayi 发表于 2020-2-3 11:30 | 显示全部楼层
非常感谢楼主分享
