[应用相关] STM32数据类型定义
540|6
 楼主| features 发表于 2020-2-7 14:58 | 显示全部楼层 |阅读模式
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name          : stm32f10x_type.h
* Author             : MCD Application Team
* Version            : V2.0.1
* Date               : 06/13/2008
* Description        : This file contains all the common data types used for the
*                      STM32F10x firmware library.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __STM32F10x_TYPE_H
#define __STM32F10x_TYPE_H
/* Includes ------------------------------------------------------------------*/
/* Exported types ------------------------------------------------------------*/
typedef signed long  s32;
typedef signed short s16;
typedef signed char  s8;
typedef signed long  const sc32;  /* Read Only */
typedef signed short const sc16;  /* Read Only */
typedef signed char  const sc8;   /* Read Only */
typedef volatile signed long  vs32;
typedef volatile signed short vs16;
typedef volatile signed char  vs8;
typedef volatile signed long  const vsc32;  /* Read Only */
typedef volatile signed short const vsc16;  /* Read Only */
typedef volatile signed char  const vsc8;   /* Read Only */
typedef unsigned long  u32;
typedef unsigned short u16;
typedef unsigned char  u8;
typedef unsigned long  const uc32;  /* Read Only */
typedef unsigned short const uc16;  /* Read Only */
typedef unsigned char  const uc8;   /* Read Only */
typedef volatile unsigned long  vu32;
typedef volatile unsigned short vu16;
typedef volatile unsigned char  vu8;
typedef volatile unsigned long  const vuc32;  /* Read Only */
typedef volatile unsigned short const vuc16;  /* Read Only */
typedef volatile unsigned char  const vuc8;   /* Read Only */
typedef enum {FALSE = 0, TRUE = !FALSE} bool;
typedef enum {RESET = 0, SET = !RESET} FlagStatus, ITStatus;
typedef enum {DISABLE = 0, ENABLE = !DISABLE} FunctionalState;
#define IS_FUNCTIONAL_STATE(STATE) (((STATE) == DISABLE) || ((STATE) == ENABLE))
typedef enum {ERROR = 0, SUCCESS = !ERROR} ErrorStatus;
#define U8_MAX     ((u8)255)
#define S8_MAX     ((s8)127)
#define S8_MIN     ((s8)-128)
#define U16_MAX    ((u16)65535u)
#define S16_MAX    ((s16)32767)
#define S16_MIN    ((s16)-32768)
#define U32_MAX    ((u32)4294967295uL)
#define S32_MAX    ((s32)2147483647)
#define S32_MIN    ((s32)-2147483648)
/* Exported constants --------------------------------------------------------*/
/* Exported macro ------------------------------------------------------------*/
/* Exported functions ------------------------------------------------------- */
#endif /* __STM32F10x_TYPE_H */
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
mmuuss586 发表于 2020-2-12 17:04 | 显示全部楼层
airwill 发表于 2020-2-12 22:41 | 显示全部楼层
定义得够全的,  这是懒人的定义啊
wakayi 发表于 2020-3-1 12:15 | 显示全部楼层
非常感谢楼主分享
wowu 发表于 2020-3-1 12:19 | 显示全部楼层
非常感谢楼主分享
xiaoqizi 发表于 2020-3-1 12:23 | 显示全部楼层
非常感谢楼主分享
磨砂 发表于 2020-3-2 11:29 | 显示全部楼层
非常感谢楼主分享
