用过25LC160请进
2352|1
 楼主| 久之1990 发表于 2011-12-1 20:56 | 显示全部楼层 |阅读模式
想把数据存放在25LC160中,然后取出显示,但是倒腾了几天都没弄出来,数据手册也看了几遍,找不出问题,麻烦各位大神解释解释,非常感谢。
#include<iom88.h>
#include<avr_macros.h>
#define uchar unsigned char
#define uint  unsigned int
#define SPI_CS    PORTD_Bit5
#define SPI_SCK   PORTB_Bit5
#define SPI_HOLD  PORTD_Bit7
#define SPI_SI    PORTB_Bit3
#define SPI_SO    PORTB_Bit4
#define SPI_WP    PORTD_Bit6
#define SPI_RE_SO (PINB&0X10)
uchar table[] = {0xc0,0xf9,0xa4,0xb0,0x99,
                 0x92,0x82,0xf8,0x80,0x90};//0~9
void delay(uchar x)
  uchar kk;
  for(;x>0;x--)
    for(kk=100;kk>0;kk--);
  读字节数据子函数
  MCU从SPI读出数据
uchar SPI_READ()
  uchar dat;
  uchar i;
  SPI_CS = 0;
  DDRB &= 0XEF;
  for(i=0;i<8;i++)
    SPI_SCK = 0;
    delay(1);
    dat = dat<<1;
    if(SPI_RE_SO)
      dat |= 0x01;
    SPI_SCK = 1;
  return dat;
  写字节数据子函数
  MCU写数据到SPI,
void SPI_WRITE(uchar dat)
  uchar i;
  SPI_CS = 0;
  for(i=0;i<8;i++)
    SPI_SCK = 0;
    delay(1);
    if(dat&0x80)
      SPI_SI = 1;
    else
      SPI_SI = 0;
    SPI_SCK = 1;
    dat = dat<<1;
void WREN()  //写允许
  SPI_CS = 0;
  delay(1);
  SPI_WRITE(0x06);
  SPI_CS = 1;
  写字节数据子函数
  将数据写入指定地址
void Write_byte(uint add,uchar dat)
  uchar add_h,add_l;
  SPI_CS = 0;
  add_h = add>>8;
  add_l = add&0x00ff;
  SPI_WRITE(0x02);
  SPI_WRITE(add_h);
  SPI_WRITE(add_l);
  SPI_WRITE(dat);
  SPI_CS = 1;
uchar Read_byte(uint add)  //将数据从16bit地址读出
  uchar add_h,add_l;
  uchar value;
  SPI_CS = 0;
  add_h = add>>8;
  add_l = add&0x00ff;
  SPI_WRITE(0x03);
  delay(1);
  SPI_WRITE(add_h);
  SPI_WRITE(add_l);
  delay(1);
  value = SPI_READ();
  SPI_CS = 1;
  return value;
void WRDI()  //写禁止
  SPI_CS = 0;
  delay(1);
  SPI_WRITE(0x04);
  SPI_CS = 1;
uchar RDSR()  //读状态寄存器
  uchar value;
  SPI_CS = 0;
  delay(1);
  SPI_WRITE(0x05);
  value = SPI_READ();
  SPI_CS = 1;
  return value;
void WRSR(uchar stat)  //写状态寄存器
  SPI_CS = 0;
  delay(1);
  SPI_WRITE(0x01);
  SPI_WRITE(stat);
  SPI_CS = 1;
void SPI_init(void)
  SPI_CS = 1;
  delay(1);
  SPI_SCK = 1;
  WREN();
  delay(20);
  WRSR(0X02);
  delay(20);
void main(void)
  uchar temp=0;
  DDRD = 0XFF;
  DDRB = 0X2C;
  DDRC = 0xff;
  PORTD &= 0XEF;
  SPI_HOLD = 1;
  SPI_CS   = 0;
  SPI_WP  = 1;
  SPI_init();
  while(1)
    Write_byte(0x0001,0x55);
    temp = Read_byte(0x0001);
    PORTC = table[temp%10];
 楼主| 久之1990 发表于 2011-12-1 21:40 | 显示全部楼层
各位大神帮忙看下 1# 久之1990
