- #include "main.h"
- #include "tm1628.h"
- #include "lcd_5110.h"
- extern uint8_t buf[14],keys[3];
- const uint8_t dig[][2]=
- 0x03,0xf0, //'0'
- 0x02,0x10, //'1'
- 0x02,0xe8, //'2'
- 0x02,0xb8, //'3'
- 0x03,0x18, //'4'
- 0x01,0xb8, //'5'
- 0x01,0xf8, //'6'
- 0x02,0x90, //'7'
- 0x03,0xf8, //'8'
- 0x03,0xb8, //'9'
- 0x03,0x38, //'Y'
- 0x03,0xd0, //'M'
- 0x02,0x78, //'D'
- 0x01,0x58, //'h'
- 0x00,0x58, //'m'
- 0x00,0x38, //'s'
- 0x00,0x08, //'-'
- 0x00,0x20, //'-'
- void Delay_us(uint8_t s)
- uint8_t i;
- for(i=0; i<s; i++);
- // for(j=0; j<10; j++);
- *程 序 名:SI2C_Sda(uint8_t dir)
- *作 用:DAT引脚配置
- *输入参数:dir(0=输出,1=输入)
- *转出参数:无
- void SI2C_Sda(uint8_t dir) //DAT端口配置(根据需要配置成输出或输入模式)
- GPIO_InitTypeDef GPIO_InitStruct;
- if(dir == 0){
- GPIO_InitStruct.Pin = SI2C_SDA_Pin; //SDA输出模式、弱上拉
- GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
- GPIO_InitStruct.Pull = GPIO_NOPULL;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
- HAL_GPIO_Init(SI2C_SDA_GPIO_Port, &GPIO_InitStruct);
- else{
- GPIO_InitStruct.Pin = SI2C_SDA_Pin; //SDA输入模式
- GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
- HAL_GPIO_WritePin(SI2C_SDA_GPIO_Port,SI2C_SDA_Pin,GPIO_PIN_SET);
- *程 序 名:TM6128_Init
- *作 用:初始化TM6128芯片引脚
- *输入参数:无
- *返回参数:无
- void TM1628_Init(void)
- //配置GPIO
- GPIO_InitStruct.Pin = SI2C_SCL_Pin|SI2C_SDA_Pin;
- HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
- //设置引脚为高电平
- HAL_GPIO_WritePin(LED1_2_GPIO_Port,LED1_2_Pin,GPIO_PIN_SET);
- HAL_GPIO_WritePin(SI2C_SCL_GPIO_Port,SI2C_SCL_Pin,GPIO_PIN_SET);
- *程 序 名:TM6128_Data(viod)
- *作 用:将Buf缓冲区14个字节写入TM6128芯片
- * 同时读5个字节的键盘数据到Buf
- *输入参数:无
- *返回参数:无
- void TM1628_Data(void)
- uint8_t i;
- SI2C_Sda(0); //设置DIO为输出
- STB_reset(); //拉低STB开始操作
- TM1628_Write(0x03); //设置显示模式(7位10段)
- STB_set(); //结束本命令
- TM1628_Write(0x40); //设置写操作
- TM1628_Write(0xc0); //地址从0开始
- Delay_us(1);
- for(i=0; i<14; i++){
- TM1628_Write(buf[i]);
- Delay_us(2); //Twait>2us
- STB_set(); //拉高STB结束写操作
- Delay_us(4);
- STB_reset(); //拉低STB发出显示模式命令
- TM1628_Write(0x8c); //开显示,脉冲宽度11/16
- STB_reset(); //拉低STB发出读键盘命令
- TM1628_Write(0x42); //
- SI2C_Sda(1); //设置sda为输入状态
- STB_reset(); //拉低STB开始读按键
- for(i=0; i<5; i++){
- buf[i] = TM1628_Read();
- STB_set(); //拉高STB结束读操作
- //处理按键
- if(buf[0]&0x01)
- keys[0]++;
- if(buf[0]&0x08)
- keys[1]++;
- if(buf[1]&0x01)
- keys[2]++;
- LCD_write_value(0,3,3,0,1,keys[0]);
- LCD_write_value(30,3,3,0,1,keys[1]);
- LCD_write_value(60,3,3,0,1,keys[2]);
- *程 序 名:TM6128_Read
- *作 用:TM6128芯片读1字节操作
- *输入参数:无
- *返回参数:读到的数据(1bety)
- uint8_t TM1628_Read(void)
- uint8_t dat,i;
- // CLK_reset(); //拉高CLK准备读数据
- for(i=0;i<8;i++){
- CLK_reset(); //拉低CLK
- Delay_us(1); //延时并准备数据
- dat>>=1;
- CLK_set(); //拉高CLK
- if(1 == HAL_GPIO_ReadPin(SI2C_SDA_GPIO_Port,SI2C_SDA_Pin))
- dat|=0x80;
- else
- __NOP();
- // Delay_us(1);
- return dat;
- *程 序 名:TM6128_Write
- *作 用:TM6128芯片写1字节操作
- *输入参数:要写入的数据(bety)
- *返回参数:无
- void TM1628_Write(uint8_t dat)
- uint8_t i;
- //开始写一字节数据(低位先)
- for(i=0;i<8;i++){
- CLK_reset(); //拉低CLK准备写数据
- if(dat&0x01)
- DIO_set();
- else
- DIO_reset();
- // Delay_us(1); //延时并准备数据
- __NOP();
- __NOP();
- __NOP();
- dat = dat>>1;
- *程 序 名:Display_Digits(uint16_t value)
- *作 用:TM6128芯片显示变量(3位有效数字)
- *输入参数:要显示的变量(value)
- *返回参数:无
- void Display_Digits(uint16_t value)
- uint8_t n; //当前位值
- n = value / 100;
- buf[1] = dig[n][0];
- buf[0] = dig[n][1];
- n = value % 100 / 10;
- buf[3] = dig[n][0];
- buf[2] = dig[n][1];
- n = value % 10;
- buf[5] = dig[n][0];
- buf[4] = dig[n][1];
- TM1628_Data();
