STC52单片机控制16*16点阵程序滚动程序
2878|1
 楼主| a362880 发表于 2011-12-7 12:22 | 显示全部楼层 |阅读模式
我是自学单片机,C语言写过一个,指针学过一节课。。
现在做个16*16点阵。。能显示多个汉字,但是就是不会滚动显示,求那位老师,能帮我修改一个能滚动流动的程序。。谢谢
写得不好的地方,请指点,是我学习进步重要一步。。
#include <reg52.h>
#define int8 unsigned char
#define int16 unsigned int
sbit led=P0^0;
int8 j=0;
int16 q;
int16 temp=0;
void delay(int16 T)
while(T--);
int8 code tab[][32]={
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
/*--  文字:  你  --*/
/*--  宋体12;  此字体下对应的点阵为:宽x高=16x16   --*/
0x80,0x40,0xF0,0x2C,0x43,0x20,0x98,0x0F,0x08,0xE8,0x08,0x88,0x28,0x18,0x08,0x00,
0x00,0x00,0x7F,0x00,0x10,0x0C,0x03,0x21,0x40,0x3F,0x00,0x00,0x03,0x1C,0x08,0x00,
/*--  文字:  若  --*/
0x40,0x44,0x44,0x44,0x44,0xDF,0x64,0x54,0x44,0x44,0x5F,0x44,0x44,0x44,0x44,0x00,
0x10,0x08,0x04,0x02,0x7F,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x7E,0x00,0x00,0x00,
/*--  文字:  安  --*/
0x80,0x90,0x8C,0x84,0x84,0xF4,0x85,0x86,0x84,0x84,0x84,0x84,0x94,0x8C,0x84,0x00,
0x80,0x80,0x80,0x40,0x47,0x28,0x28,0x10,0x28,0x24,0x43,0xC0,0x40,0x00,0x00,0x00,
/*--  文字:  好  --*/
0x10,0x10,0xF0,0x1F,0x10,0xF0,0x80,0x82,0x82,0x82,0xF2,0x8A,0x86,0x82,0x80,0x00,
0x80,0x43,0x22,0x14,0x0C,0x73,0x20,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  ,  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x58,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  便  --*/
0x40,0x20,0xF0,0x1C,0x07,0xFA,0x2A,0x2A,0x2A,0xFE,0x2A,0x2A,0x2A,0xFA,0x02,0x00,
0x00,0x00,0xFF,0x00,0x80,0x83,0x45,0x29,0x19,0x17,0x21,0x21,0x41,0xC1,0x40,0x00,
/*--  文字:  是  --*/
0x80,0x80,0x80,0x80,0xBE,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xBE,0x80,0x80,0x80,0x00,
0x00,0x40,0x20,0x10,0x0E,0x10,0x20,0x3F,0x44,0x44,0x44,0x44,0x44,0x40,0x40,0x00,
/*--  文字:  晴  --*/
0x00,0xFC,0x44,0x44,0xFC,0x20,0x22,0xAA,0xAA,0xBF,0xAA,0xAA,0xAA,0x22,0x20,0x00,
0x00,0x0F,0x04,0x04,0x0F,0x00,0x00,0xFF,0x0A,0x0A,0x4A,0x8A,0x7F,0x00,0x00,0x00,
/*--  文字:  天  --*/
0x00,0x40,0x42,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0x42,0x42,0x40,0x00,
0x00,0x80,0x40,0x20,0x10,0x08,0x06,0x01,0x02,0x04,0x08,0x10,0x30,0x60,0x20,0x00,
/*--  调入了一幅图像:这是您新建的图像  --*/
/*--  宽度x高度=16x16  --*/
0x00,0x20,0x10,0x10,0x10,0x10,0x20,0x00,0x00,0x20,0x10,0x10,0x10,0x10,0x20,0x00,
0x00,0x00,0x00,0x00,0x00,0x10,0x28,0x28,0x29,0x28,0x28,0x10,0x00,0x00,0x00,0x00,
int8 code tab1[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
void cxh()
P0 = 0xff;
P1 = 0x00;
P2 = 0xff;
P3 = 0x00;
void main()
int8 i;
TMOD|=0X01;
TH0 =0XB0;
TL0=0X00;
EA=1;
ET0=1;
TR0=1;
while(1)
  cxh();
  for(i=0;i<8;i++)
   P1=tab[j] ;   //左上角
   P3=tab[j][16+i];//左下角
   P0=tab1;//列选
   delay(100);
   cxh();
  cxh();
  for(i=0;i<8;i++)
   P1=tab[j][8+i] ;//右上角
   P3=tab[j][24+i];//右下角
   P2=tab1;//列选
   delay(100);
   cxh();
void int1_yy(void) interrupt 1
TH0 =0XB0;
TL0=0X00;
q++;
if(q==30)//3秒显示下一个字
  q=0;
  j++;
if(j==12)//
  j=0;
 楼主| a362880 发表于 2012-9-21 20:53 | 显示全部楼层
没有人回答,我自力更新,已搞定。。花了很长的时间。。
