使用STM8的UART与485芯片进行通信。STM8的UART接收中断没有接收0X00数据时,通信数据正常,数据也不会丢失;当接收数据中含有0X00时,就会进入数据溢出中断,而且接收的数据也会丢失,如果发送八个数据,很多时候只能接收到6个;网上的很多方法都试过,也没效果;代码发出来,大神帮忙看看。
void ALL_GPIO_Config(void)
/////////////////////////////// LED //////////////////////////////////////////////
GPIO_Init(GPIOC, GPIO_PIN_6, GPIO_MODE_OUT_PP_LOW_FAST);
GPIO_Init(GPIOC, GPIO_PIN_7, GPIO_MODE_OUT_PP_LOW_FAST);
GPIO_Init(GPIOD, GPIO_PIN_3, GPIO_MODE_OUT_PP_LOW_FAST);
LED_G_OFF;LED_R_OFF;LED_Y_OFF;
/////////////////////////////// UART //////////////////////////////////////////////
GPIO_Init(GPIOD, GPIO_PIN_4, GPIO_MODE_OUT_PP_HIGH_FAST); //RS485接收转换使能
GPIO_Init(GPIOD, GPIO_PIN_5, GPIO_MODE_OUT_PP_LOW_SLOW);
GPIO_Init(GPIOD, GPIO_PIN_6, GPIO_MODE_IN_PU_IT);
void UART1_Config(void)
CLK_PeripheralClockConfig(CLK_PERIPHERAL_UART1, ENABLE);
//初始化UART中的所有寄存器
UART1_DeInit();
//UART的参数初始化
UART1_Init(9600, UART1_WORDLENGTH_8D, UART1_STOPBITS_1, UART1_PARITY_NO, UART1_SYNCMODE_CLOCK_DISABLE, UART1_MODE_TXRX_ENABLE);
UART1_ITConfig(UART1_IT_TXE,DISABLE);//关闭串口发送中断
UART1_ITConfig(UART1_IT_RXNE_OR,ENABLE);//打开串口接收中断
//使能UART
UART1_Cmd(ENABLE);
//中断使能
enableInterrupts();
** @function UART1_RX_IRQHandler
** @author
** @version V1.0
** @date 接收中断
unsigned char IT_States[4]= {0};
INTERRUPT_HANDLER(UART1_RX_IRQHandler, 18)
unsigned char kk = 0;
unsigned char status=UART1->SR;
if(UART1_GetFlagStatus(UART1_FLAG_OR) == SET)//stm8 uart?生溢出??的原因
UART1->SR &= 0xDF;
UART1_ClearFlag(UART1_FLAG_OR); //清除ORE
kk = UART1_ReceiveData8();
LED_G_ON;
else if(UART1_GetFlagStatus(UART1_FLAG_RXNE) != RESET) //查看UART1中?是否?生
// TIM2_SetCounter(0);
// TIM2_Cmd(ENABLE);
LED_R_ON_OFF;
USART1_RECEIVE_BUFF[rec_len] = UART1_ReceiveData8();
rec_len++;
if(rec_len>=100) rec_len = 0;
UART1_ClearITPendingBit(UART1_IT_RXNE); //清除UART1挂起?志
** @function UART1_TX_IRQHandler
** @author
** @version V1.0
** @date 发送中断
INTERRUPT_HANDLER(UART1_TX_IRQHandler, 17)
if( (RESET != UART1_SR_TC) && (RESET != UART1_CR2_TCIEN) ) //if(UART1_SR & 0x80) //
if(uart_len != 0)
UART1_SendData8(*uart_buf);
uart_buf++;
uart_len--;
else
UART1_ITConfig(UART1_IT_TXE, DISABLE); //close send interrupt
RX485;
