| 1、是这样的,我用两个STM32单片机,1号单片机STM32单片机发生频率F,2号单片机测量这个频率,通过2号单片机设定目标频率,通过PID算法控制,控制DAC输出电压,1号单片机通过ADC测量这个电压值,发生800-1500HZ频率的,就是不知道PID算法执行OUT参数怎么设置?2、我在网上找到一个别人程序中 if(pp->SumError>900)  pp->SumError=900; else if(pp->SumError<-900)   pp->SumError=-900;这几句什么用处,看到不少很明白,为什么要加这几句话,我很好奇,为什么他的算法没有积分时间,微分时间?感觉这个程序经典的。PID这三个参数怎么处理。//extern int U_Set;
 //extern u16 CCR1_Val;
 PID Function
 The PID (比例、积分、微分) function is used in mainly
 control applications. PIDCalc performs one iteration of the PID
 algorithm.
 While the PID function works, main is just a dummy program showing
 a typical usage.
 typedef struct PID {
 float SetPoint; // 设定目标Desired value
 float Proportion; // 比例常数Proportional Const
 float Integral; // 积分常数Integral Const
 float Derivative; // 微分常数Derivative Const
 float LastError; // Error[-1]
 float PrevError; // Error[-2]
 float SumError; // Sums of Errors
 } PID;
 PID计算部分
 PID   vPID={0,0.1,0.001,0.001,0,0,0};
 float PIDCalc( PID *pp, float NextPoint )
 float dError,
 Error;
 Error = pp->SetPoint - NextPoint; // 偏差
 pp->SumError += Error; // 积分
 dError = pp->LastError - pp->PrevError; // 当前微分
 pp->PrevError = pp->LastError;
 pp->LastError = Error;
 return (pp->Proportion * Error // 比例项
 + pp->Integral * pp->SumError // 积分项
 + pp->Derivative * dError // 微分项
 float Vol(int vSet,int v3){
 float vOut; // PID Response (Output)
 float vIn; // PID Feedback (Input)
 vPID.SetPoint = vSet; // Set PID Setpoint
 vIn = (float)v3; // Read Input
 vOut = PIDCalc ( &vPID,vIn ); // Perform PID Interation
 return vOut;
 void mian()
 while(1)
 if(Flag_3S==1)
 if(target-TIM_ExtCntFreq>=6||target-TIM_ExtCntFreq<=-6)
 Pv=Vol(target,TIM_ExtCntFreq);// PID算法
 dac_value=dac_value+Pv/2.04;//DAC 寄存器调节
 DAC_SetChannel1Data(DAC_Align_12b_R,dac_value);
 led3=~led3;
 Flag_3S=0;
