函数I2C_EE_BufferWrite中,对于需要写入的起始地址与整数页数是否对齐进行了判断,并且对写入的数据总数是否满足整数页数进行了判断。在处理写入地址非对齐模式的时候有bug。见如下代码:void I2C_EE_BufferWrite(u8* pBuffer, u8 WriteAddr, u16 NumByteToWrite)
u8 NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0;
Addr = WriteAddr % I2C_PageSize;
count = I2C_PageSize - Addr;
NumOfPage = NumByteToWrite / I2C_PageSize;
NumOfSingle = NumByteToWrite % I2C_PageSize;
/* If WriteAddr is I2C_PageSize aligned */
if(Addr == 0)
/* If NumByteToWrite < I2C_PageSize */
if(NumOfPage == 0)
I2C_EE_PageWrite(pBuffer, WriteAddr, NumOfSingle);
I2C_EE_WaitEepromStandbyState();
/* If NumByteToWrite > I2C_PageSize */
else
while(NumOfPage--)
I2C_EE_PageWrite(pBuffer, WriteAddr, I2C_PageSize);
WriteAddr += I2C_PageSize;
pBuffer += I2C_PageSize;
if(NumOfSingle!=0)
/* If WriteAddr is not I2C_PageSize aligned */
else
if(NumOfPage== 0) //这里没有考虑到写入的地址不是跟I2C_PageSize对齐,并且写入的数量超过一页的情况。
else
NumByteToWrite -= count;
if(count != 0)
I2C_EE_PageWrite(pBuffer, WriteAddr, count);
WriteAddr += count;
pBuffer += count;
while(NumOfPage--)
if(NumOfSingle != 0)
上述代码中没有考虑到不对齐的时候,如果写入的数据超过当前页剩余的部分,就会出现这小部分覆盖了前面的数据的情况。比如从0x03开始写入7个字节,当前分页剩余只有5个字节,写入7个会依次写入到0x03,0x04,0x05,0x06,0x07,0x00,0x01覆盖0x00,0x01这两个字节。此处应该对当前页剩余的字节数进行一个判断。 |
