同一个按键按一下改变一个值,三下及以上如何设置
406|0
 楼主| Spikess 发表于 2019-11-20 21:42 | 显示全部楼层 |阅读模式
大神们帮帮忙啊!!!!!试了好久都没搞出来
        case E_BUTTON9:        //LED3
                                if(nine_button == S_OFF)
                                        TIM3->ARR=1999;
                                        LCD_DispStr(0,200, (uint8_t *)" 360RPM   ", BLACK);
                                        nine_button = S_ON;
                                else if        (nine_button == S_ON)
                                                TIM3->ARR=3999;
                                        LCD_DispStr(0,200, (uint8_t *)" 180RPM   ", BLACK);
                                        nine_button = S_OFF;
                                        else        if(nine_button == S_OFF)
                                                TIM3->ARR=999;
                                        LCD_DispStr(0,200, (uint8_t *)" 90RPM   ", BLACK);
                                even = E_NULL;
                break;
这个程序前面两个转速可以来回调,可是怎么都调不到第三个转速!!!!!     如何设计可以让这三个转速来回调啊??????????????????????????
