/* Set core clock as PLL_CLOCK from PLL */
CLK_SetCoreClock(PLL_CLOCK);
我们经常在例子中用到这个函数,我们可以看到这个函数就是设置内核时钟的,上面这个是这种PLL作为内核时钟。
- * [url=home.php?mod=space&uid=247401]@brief[/url] Set HCLK frequency
- * @param[in] u32Hclk is HCLK frequency
- * [url=home.php?mod=space&uid=266161]@return[/url] HCLK frequency
- * [url=home.php?mod=space&uid=1543424]@Details[/url] This function set HCLK frequency. The frequency unit is Hz. The range of u32Hclk is 25 MHz ~ 50 MHz.
- * The register write-protection function should be disabled before using this function.
- uint32_t CLK_SetCoreClock(uint32_t u32Hclk)
- uint32_t u32HIRCSTB;
- /* Read HIRC clock source stable flag */
- u32HIRCSTB = CLK->CLKSTATUS & CLK_CLKSTATUS_OSC22M_STB_Msk;
- /* The range of u32Hclk is 25 MHz ~ 50 MHz */
- if(u32Hclk > FREQ_50MHZ)
- u32Hclk = FREQ_50MHZ;
- else if(u32Hclk < FREQ_25MHZ)
- u32Hclk = FREQ_25MHZ;
- /* Switch HCLK clock source to HIRC clock for safe */
- CLK->PWRCON |= CLK_PWRCON_OSC22M_EN_Msk;
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- CLK->CLKSEL0 |= CLK_CLKSEL0_HCLK_S_HIRC;
- CLK->CLKDIV &= (~CLK_CLKDIV_HCLK_N_Msk);
- /* Configure PLL setting if HXT clock is stable */
- if(CLK->CLKSTATUS & CLK_CLKSTATUS_XTL12M_STB_Msk)
- u32Hclk = CLK_EnablePLL(CLK_PLLCON_PLL_SRC_HXT, u32Hclk);
- /* Configure PLL setting if HXT clock is not stable */
- else
- u32Hclk = CLK_EnablePLL(CLK_PLLCON_PLL_SRC_HIRC, u32Hclk);
- /* Select HCLK clock source to PLL */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_PLL, CLK_CLKDIV_HCLK(1));
- /* Disable HIRC if HIRC is disabled before setting core clock */
- if( u32HIRCSTB == 0 )
- CLK->PWRCON &= ~CLK_PWRCON_OSC22M_EN_Msk;
- return u32Hclk;
这个函数只能设置两个值,50MHz,25MHz
先将HCLK设置到HIRC,确保百分百能运行,这个时候HCLK还是22MHz
然后确认外部晶振是否正常运行,如果正常运行设置到外部晶振,然后设置PLL为50MHz,
如果晶振没有正常运行设置PLL时钟源为HIRC,同样设置PLL到50MHz
然后再将HCLK设置到PLL上去。
