【RTOS】+ 雅特力初步学习
611|0
 楼主| wokice 发表于 2020-6-17 07:45 | 显示全部楼层 |阅读模式
1、最近比较忙,加班累成狗
2、初步学习单片机KEIL啥都不会,引脚都看不懂。
3、忙到最近终于看懂了一些
4、讲基本的流水灯程序作了简单的修改
由于用户按键是PA0,定义了一下
/* defined the LED2 pin: PD13 */
#define LED2_PIN    GET_PIN(D, 13)
/* defined the LED3 pin: PD14 */
#define LED3_PIN    GET_PIN(D, 14)
/* defined the LED4 pin: PD15 */
#define LED4_PIN    GET_PIN(D, 15)
/* defined the USER pin: PA0 */
#define USER_PIN    GET_PIN(A, 0)
int asd=0;
int main(void)
    uint32_t Speed = 300;
    /* set LED2 pin mode to output */
    rt_pin_mode(LED2_PIN, PIN_MODE_OUTPUT);
    /* set LED3 pin mode to output */
    rt_pin_mode(LED3_PIN, PIN_MODE_OUTPUT);
    /* set LED4 pin mode to output */
    rt_pin_mode(LED4_PIN, PIN_MODE_OUTPUT);
          rt_pin_mode(USER_PIN, PIN_MODE_INPUT);
         // asd = USER_PIN;
    while (1)
                        asd = rt_pin_read(USER_PIN);
                        if(asd ==1)
                                        rt_pin_write(LED2_PIN, PIN_LOW);
                                        rt_thread_mdelay(Speed);
                                        rt_pin_write(LED3_PIN, PIN_LOW);
                                        rt_pin_write(LED4_PIN, PIN_LOW);
                                        rt_pin_write(LED2_PIN, PIN_HIGH);
                                        rt_pin_write(LED3_PIN, PIN_HIGH);
                                        rt_pin_write(LED4_PIN, PIN_HIGH);
就是让按键按下的时候流水灯才正常跑,之前两个红色标注的地方不对,一个是定义错误,一个是定义了上拉输入,导致弄了半天程序也不对,希望看到的同学少走弯路
