求助,硬件IIC读写EEPROM,读写出错~
633|0
 楼主| 香菇选手 发表于 2018-7-14 11:36 | 显示全部楼层 |阅读模式
使用硬件I2C,配置了GPIO和I2C模式,测试读写EEPROM,总是返回写数据失败!驱动编写如下,请问大神哪些地方有可能出错呢??怎么就是读写不进去??
使用的F767IGT6开发版
int main(void)
    SystemClock_Config();
    LED_GPIO_Config();
    LED_BLUE;
    DEBUG_USART_Config();
    SysTick_Init();
    I2C_EE_Init();
    if(I2C_Test() ==1)
        LED_GREEN;
    else
        LED_RED;
    while (1)
void I2C_GPIO_Config(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  /*!< EEPROM_I2C Periph clock enable */
  EEPROM_I2C_CLK_ENABLE();
  /*!< EEPROM_I2C_SCL_GPIO_CLK and EEPROM_I2C_SDA_GPIO_CLK Periph clock enable */
  EEPROM_I2C_SCL_GPIO_CLK_ENABLE();
  EEPROM_I2C_SDA_GPIO_CLK_ENABLE();
  /*!< Configure EEPROM_I2C pins: SCL */
  GPIO_InitStructure.Pin = EEPROM_I2C_SCL_PIN;
  GPIO_InitStructure.Mode = GPIO_MODE_AF_OD;
  GPIO_InitStructure.Speed = GPIO_SPEED_FAST;
  GPIO_InitStructure.Pull  = GPIO_NOPULL;
  GPIO_InitStructure.Alternate = EEPROM_I2C_SCL_AF;
  HAL_GPIO_Init(EEPROM_I2C_SCL_GPIO_PORT, &GPIO_InitStructure);
  /*!< Configure EEPROM_I2C pins: SDA */
  GPIO_InitStructure.Pin = EEPROM_I2C_SDA_PIN;
  HAL_GPIO_Init(EEPROM_I2C_SDA_GPIO_PORT, &GPIO_InitStructure);
void I2C_Mode_Config(void)
    I2C_Handle.Instance = EEPROM_I2C;
    I2C_Handle.Init.Timing           = 0x90913232;//100KHz
    I2C_Handle.Init.OwnAddress1      = 0;
    I2C_Handle.Init.AddressingMode   = I2C_ADDRESSINGMODE_7BIT;
    I2C_Handle.Init.DualAddressMode  = I2C_DUALADDRESS_DISABLE;
    I2C_Handle.Init.OwnAddress2      = 0;
    I2C_Handle.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
    I2C_Handle.Init.GeneralCallMode  = I2C_GENERALCALL_DISABLE;
    I2C_Handle.Init.NoStretchMode    = I2C_NOSTRETCH_DISABLE;
    HAL_I2C_Init(&I2C_Handle);
    HAL_I2CEx_AnalogFilter_Config(&I2C_Handle, I2C_ANALOGFILTER_ENABLE);
void I2C_EE_Init(void)
  I2C_GPIO_Config();
  I2C_Mode_Config();
uint8_t I2C_Test(void)
    u16 i;
   printf("写入数据");
    for ( i=0; i<=255; i++ )
    I2c_Buf_Write = i;
    printf("0x%02X ", I2c_Buf_Write);
    if(i%16 == 15)
        printf("
  if(HAL_I2C_Mem_Write(&I2C_Handle, 0xA0, 0, I2C_MEMADD_SIZE_8BIT,I2c_Buf_Write,256, 0x10) == HAL_OK )
   printf("写入数据成功");
  else
     printf("写入数据失败");
      return 0;
  printf("读出数据");
  if(HAL_I2C_IsDeviceReady(&I2C_Handle,0xA0, 10, 1000)!=HAL_OK)
    return 0;
  HAL_I2C_Mem_Read(&I2C_Handle,0xA1, 0, I2C_MEMADD_SIZE_8BIT,I2c_Buf_Read,256, 0x10);
    for (i=0; i<256; i++)
        if(I2c_Buf_Read != I2c_Buf_Write)
            printf("0x%02X ", I2c_Buf_Read);
            printf("写入与读出不一致");
            return 0;
    if(i%16 == 15)
        printf("
   printf("读写测试成功");
    return 1;
