| #pragma config FOSC = INTOSCIO  // Oscillator Selection bits (INTOSCIO oscillator: I/O function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN)
 #pragma config WDTE = ON        // Watchdog Timer Enable bit (WDT enabled)
 #pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
 #pragma config MCLRE = ON       // MCLR Pin Function Select bit (MCLR pin function is MCLR)
 #pragma config CP = ON          // Code Protection bit (Program memory code protection is enabled)
 #pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)
 #pragma config BOREN = ON       // Brown Out Detect (BOR enabled)
 #pragma config IESO = ON        // Internal External Switchover bit (Internal External Switchover mode is enabled)
 #pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is enabled)
