经过几位大佬的分享,实现了UART_Send_Data函数与printf函数同时在ML51工程中的使用方法。
- /* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved. */
- // Website: http://www.nuvoton.com
- // E-Mail : MicroC-8bit@nuvoton.com
- #include "ML51.h"
- * [url=home.php?mod=space&uid=247401]@brief[/url] UART0 Transfer and receive with interrupt subroutine.
- * @param None
- * [url=home.php?mod=space&uid=266161]@return[/url] None
- * [url=home.php?mod=space&uid=1543424]@Details[/url] Result stroage in XRAM UIDBuffer[0:8];
- unsigned char uart_receive_data,bufhead;
- bit receiveFlag,bufOverFlag;
- unsigned char my[10];
- unsigned char i=0;
- void Serial_ISR (void) interrupt 4
- if (RI)
- receiveFlag = 1;
- uart_receive_data = SBUF;
- clr_SCON_RI; // Clear RI (Receive Interrupt).
- if (TI)
- clr_SCON_TI; // Clear TI (Transmit Interrupt).
- void main (void)
- MFP_P46_GPIO;
- P46_PUSHPULL_MODE;
- For UART0 P0.5 asTXD output setting
- * include uart.c in Common Setting for UART0
- MFP_P31_UART0_TXD; /* set P3.1 and P3.0 as Quasi mode for UART0 trasnfer */
- MFP_P30_UART0_RXD;
- P31_QUASI_MODE;
- P30_QUASI_MODE;
- UART_Open(24000000,UART0_Timer1,115200); // Open UART0 use timer1 as baudrate generate and baud rate = 115200
- ENABLE_UART0_PRINTF;
- #if 0
- UART_Interrupt_Enable(UART0,Enable);
- while(1);
- #else
- UART0 loop test
- UART0 TXD send data received by RXD pin. Connect TXD pin and RXD pin check result.
- do{
- unsigned char temp;
- temp = UART_Receive_Data(UART0);
- UART_Send_Data(UART0,temp);
- my[i++]=temp;
- if(i>=10)
- UART_Send_Data(UART0,'a');
- for(i=0;i<10;i++)
- UART_Send_Data(UART0,my[i]);
- for(i=0;i<10;i++)
- my[i]=0;
- i=0;
- printf ("bbs.21ic.com" );
- DISABLE_UART0_PRINTF;
- }while(1);
- #endif
