STM32H7中的ADC3模拟看门狗不能触发
571|0
 楼主| 求关注啊 发表于 2018-8-9 21:06 | 显示全部楼层 |阅读模式
一直在调STM32H7的ADC,发现一个奇怪的现象,根据数据手册可以得知每个ADC有都有三个看门狗。但是在配置的过程中发现ADC12的看门狗可以实现中断但是ADC3的一直实现不了。不知道是我配置的问题还是硬件bug,希望得到各位的指导。先贴出ADC1可以正常触发的程序:
void ADC1_Config(void){//配置ADC、ADC通道、看门狗
    ADC_ChannelConfTypeDef                                            ADC1_ChanConf;
    //ADC1配置
    ADC1_Handler.Instance        =ADC1;
    ADC1_Handler.Init.ClockPrescaler                                    =ADC_CLOCK_SYNC_PCLK_DIV4;         //4分频,ADCCLK=PER_CK/4=64/4=16MHZ
    ADC1_Handler.Init.Resolution                                              =ADC_RESOLUTION_12B;  //16位模式
    ADC1_Handler.Init.ScanConvMode                                                 =ADC_SCAN_DISABLE;   //非扫描模式
    ADC1_Handler.Init.EOCSelection                                           =ADC_EOC_SINGLE_CONV; //关闭EOC中断
   ADC1_Handler.Init.LowPowerAutoWait                                 =DISABLE;                                        //自动低功耗关闭
    ADC1_Handler.Init.ContinuousConvMode                         =DISABLE;          //关闭连续转换
    ADC1_Handler.Init.NbrOfConversion                                         =1;              //1个转换在规则序列中 也就是只转换规则序列1
    ADC1_Handler.Init.DiscontinuousConvMode                 =DISABLE;            //禁止不连续采样模式
    ADC1_Handler.Init.NbrOfDiscConversion      =1;                    //不连续采样通道数为0
    ADC1_Handler.Init.ExternalTrigConv         =ADC_EXTERNALTRIG_T3_TRGO;      //T3触发
    ADC1_Handler.Init.ExternalTrigConvEdge     =ADC_EXTERNALTRIGCONVEDGE_RISING;//上升沿
   ADC1_Handler.Init.ConversionDataManagement =ADC_CONVERSIONDATA_DMA_CIRCULAR;  //规则通道的数据仅仅保存在DR寄存器里面
                ADC1_Handler.Init.BoostMode                                                     =ENABLE;                                                        //BOOT模式关闭
                ADC1_Handler.Init.Overrun        =ADC_OVR_DATA_OVERWRITTEN;                        //有新的数据的死后直接覆盖掉旧数据
                ADC1_Handler.Init.OversamplingMode                           =DISABLE;                                        //过采样关闭
        HAL_ADC_Init(&ADC1_Handler);                                 //初始化
        //配置通道
          ADC1_ChanConf.Channel                     =        ADC_CHANNEL_19;  //通道
    ADC1_ChanConf.Rank                                                       =        ADC_REGULAR_RANK_1;        //1个序列
    ADC1_ChanConf.SamplingTime        =        ADC_SAMPLETIME_8CYCLES_5;  //采样时间
                ADC1_ChanConf.SingleDiff        =        ADC_SINGLE_ENDED;                                  //单边采集
                ADC1_ChanConf.OffsetNumber        =        ADC_OFFSET_NONE;
                ADC1_ChanConf.Offset        =        0;
    HAL_ADC_ConfigChannel(&ADC1_Handler,&ADC1_ChanConf);        //ADC的通道19
        //看门狗配置
                AnalogWDGConfig.WatchdogNumber            = ADC_ANALOGWATCHDOG_2;
                AnalogWDGConfig.WatchdogMode                                                         = ADC_ANALOGWATCHDOG_ALL_REG;
                AnalogWDGConfig.Channel        = ADC_CHANNEL_19;
                AnalogWDGConfig.ITMode        = ENABLE;
                AnalogWDGConfig.HighThreshold                                                 = 2000;
                AnalogWDGConfig.LowThreshold                                                  = 0;
                HAL_ADC_AnalogWDGConfig(&ADC1_Handler, &AnalogWDGConfig);
ADC是用定时器触发的,在HAL_ADC_MspInit();函数中配置使用DMA传输,以及对应的时钟使能。
下面是ADC3是不能进入中断的,问题代码:
void ADC3_Config(void){//配置ADC3、ADC3通道
                ADC_ChannelConfTypeDef                                    ADC3_ChanConf;
                //ADC3配置
                ADC3_Handler.Instance        =         ADC3;
                ADC3_Handler.Init.ClockPrescaler                                         =         ADC_CLOCKPRESCALER_PCLK_DIV4;
                ADC3_Handler.Init.Resolution                                                         =        ADC_RESOLUTION_12B;
    ADC3_Handler.Init.ScanConvMode                                                 =        ADC_SCAN_DISABLE;   //非扫描模式
    ADC3_Handler.Init.EOCSelection                                           =        ADC_EOC_SINGLE_CONV; //关闭EOC中断
                ADC3_Handler.Init.LowPowerAutoWait                                 =        DISABLE;                                        //自动低功耗关闭
    ADC3_Handler.Init.ContinuousConvMode                         =        DISABLE;          //关闭连续转换
    ADC3_Handler.Init.NbrOfConversion                                         =        1;              //1个转换在规则序列中 也就是只转换规则序列1
    ADC3_Handler.Init.DiscontinuousConvMode                 =        DISABLE;            //禁止不连续采样模式
    ADC3_Handler.Init.NbrOfDiscConversion      =        1;                    //不连续采样通道数为0
    ADC3_Handler.Init.ExternalTrigConv         =        ADC_EXTERNALTRIG_T3_TRGO;      //T3触发
    ADC3_Handler.Init.ExternalTrigConvEdge     =        ADC_EXTERNALTRIGCONVEDGE_RISING;//上升沿
          ADC3_Handler.Init.ConversionDataManagement =        ADC_CONVERSIONDATA_DMA_CIRCULAR;  //规则通道的数据仅仅保存在DR寄存器里面
                ADC3_Handler.Init.BoostMode                                                     =        ENABLE;                                                        //BOOT模式关闭
                ADC3_Handler.Init.Overrun        =        ADC_OVR_DATA_OVERWRITTEN;                        //有新的数据的死后直接覆盖掉旧数据
                ADC3_Handler.Init.OversamplingMode                           =        DISABLE;                                        //过采样关闭
    HAL_ADC_Init(&ADC3_Handler);                                 //初始化
                //配置通道PH4 ADC3_INP15
          ADC3_ChanConf.Channel                     =        ADC_CHANNEL_3;  //通道
    ADC3_ChanConf.Rank                                                       =        ADC_REGULAR_RANK_1;        //1个序列
    ADC3_ChanConf.SamplingTime        =        ADC_SAMPLETIME_8CYCLES_5;  //采样时间
                ADC3_ChanConf.SingleDiff        =        ADC_SINGLE_ENDED;                                  //单边采集
                ADC3_ChanConf.OffsetNumber        =        ADC_OFFSET_NONE;
                ADC3_ChanConf.Offset        =        0;
    HAL_ADC_ConfigChannel(&ADC3_Handler,&ADC3_ChanConf);        //ADC的通道 15
        //看门狗配置
                AnalogWDGConfig.WatchdogNumber            = ADC_ANALOGWATCHDOG_1;
                AnalogWDGConfig.Channel        = ADC_CHANNEL_3;
void HAL_ADC_MspInit(ADC_HandleTypeDef* hadc){
                //*##- 1- Configure CLK###########/
                __HAL_RCC_GPIOF_CLK_ENABLE();        //开启GPIOH时钟
                __HAL_RCC_ADC3_CLK_ENABLE();        //使能ADC3时钟
                __HAL_RCC_ADC_CONFIG(RCC_ADCCLKSOURCE_CLKP);  //ADC外设时钟选择
                __HAL_RCC_DMA2_CLK_ENABLE();
                /*##- 2- Configure peripheral GPIO ############*/
                /* ADC3 Channel GPIO pin configuration */
                GPIO_Initure.Pin=GPIO_PIN_7;            //PH4
                GPIO_Initure.Mode=GPIO_MODE_ANALOG;     //模拟
                GPIO_Initure.Pull=GPIO_NOPULL;          //不带上下拉
                HAL_GPIO_Init(GPIOF,&GPIO_Initure);
                /*##- 3- Configure DMA ####################*/
                /*********************** Configure DMA parameters link ADC3 with DMA1_Stream2 ***/
                DmaHandle2.Instance                 = DMA2_Stream1;
                DmaHandle2.Init.Request             = DMA_REQUEST_ADC3;
                DmaHandle2.Init.Direction           = DMA_PERIPH_TO_MEMORY;
                DmaHandle2.Init.PeriphInc           = DMA_PINC_DISABLE;
                DmaHandle2.Init.MemInc              = DMA_MINC_ENABLE;
                DmaHandle2.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
                DmaHandle2.Init.MemDataAlignment    = DMA_MDATAALIGN_HALFWORD;
                DmaHandle2.Init.Mode                = DMA_CIRCULAR;
                DmaHandle2.Init.Priority            = DMA_PRIORITY_MEDIUM;
                /* Deinitialize  & Initialize the DMA for new transfer */
                HAL_DMA_DeInit(&DmaHandle2);
                HAL_DMA_Init(&DmaHandle2);
                /* Associate the DMA handle 把结构体中的两个连到一起*/
                __HAL_LINKDMA(hadc, DMA_Handle, DmaHandle2);
                HAL_NVIC_SetPriority(ADC_IRQn, 0, 0);
                HAL_NVIC_EnableIRQ(ADC_IRQn);
将道理应该这个俩个ADC配置没什么区别,但是实际实验就是不好用。不知道是我哪里疏忽了。再就是有一个非常诡异的问题,假如先配置ADC3之后再配置ADC1的话ADC3还会不工作很诡异。。。。
希望能得到各位的指导十分感谢
adc.c
2019-3-12 22:49 上传
点击文件名下载附件
