QT实现地址薄的功能的程序,熟悉下QT的基本操作
166|0
 楼主| 过期账户 发表于 2018-9-27 12:38 | 显示全部楼层 |阅读模式
ui, TE, se, AD, AC
QT实现地址薄的功能,熟悉下QT的基本操作,对QT有所帮助
下载附件
保存到相册
2016-4-7 01:29 上传
全部源码下载:
qt地址薄源码.rar
(506.1 KB, 下载次数: 6)
2016-4-7 01:31 上传
点击文件名下载附件
下载积分: 黑币 -5
部分源码预览:
#include "addressbook.h"
#include "ui_addressbook.h"
AddressBook::AddressBook(QWidget *parent) :
    QWidget(parent),
    ui(new Ui::AddressBook)
    ui->setupUi(this);
    ui->nameLine->setReadOnly(true);
    ui->addressText->setReadOnly(true);
    ui->submitButton->hide();
    ui->cancelButton->hide();
    ui->nextButton->setEnabled(false);
    ui->previousButton->setEnabled(false);
    ui->editButton->setEnabled(false);
    ui->removeButton->setEnabled(false);
    ui->findButton->setEnabled(false);
    connect(ui->addButton,SIGNAL(clicked()),this,SLOT(addContact()));
    connect(ui->submitButton,SIGNAL(clicked()),this,SLOT(submitContact()));
    connect(ui->cancelButton,SIGNAL(clicked()),this,SLOT(cancel()));
    connect(ui->nextButton,SIGNAL(clicked()),this,SLOT(next()));
    connect(ui->previousButton,SIGNAL(clicked()),this,SLOT(previous()));
    connect(ui->editButton, SIGNAL(clicked()), this, SLOT(editContact()));
    connect(ui->removeButton, SIGNAL(clicked()), this, SLOT(removeContact()));
    connect(ui->findButton, SIGNAL(clicked()), this, SLOT(findContact()));
    setWindowTitle(tr("地址薄--汪佐"));
AddressBook::~AddressBook()
    delete ui;
void AddressBook::changeEvent(QEvent *e)
    QWidget::changeEvent(e);
    switch (e->type())
        case QEvent::LanguageChange:
              ui->retranslateUi(this);
             break;
        default:
             break;
void AddressBook::addContact()
    oldName = ui->nameLine->text();
    oldAddress = ui->addressText->toPlainText();
    ui->nameLine->clear();
    ui->addressText->clear();
    updateInterface(AddingMode);
void AddressBook::submitContact()
  QString name = ui->nameLine->text();
  QString address = ui->addressText->toPlainText();
  if (name == "" || address == "")
      QMessageBox::information(this, tr("空的"), tr("请输入姓名或地址."));
      return ;
if (currentMode == AddingMode)
     if (!contacts.contains(name))
        contacts.insert(name, address);
        QMessageBox::information(this, tr("添加成功"), tr("\"%1\" 已经添加。").arg(name));
     else
        QMessageBox::information(this, tr("添加失败"), tr("\"%1\" 已经存在。").arg(name));
        return;
else
     if (currentMode == EditingMode)
          if (oldName != name)
                       QMessageBox::information(this, tr("修改成功1"), tr("\"%1\" 已经修改。").arg(oldName));
                       contacts.remove(oldName);
          else if (oldAddress != address)
                     QMessageBox::information(this, tr("修改成功2"), tr("\"%1\" 已经修改。").arg(name));
                     contacts[name] = address;
         else
              QMessageBox::information(this, tr("无法修改"), tr("\"%1\" 已经存在。").arg(oldName));//防止修改后重名
              return;
       updateInterface(NavigationMode);
  if (contacts.isEmpty())
     int number = contacts.size();
     ui->nextButton->setEnabled(number > 1);
     ui->previousButton->setEnabled(number > 1);
     ui->addButton->setEnabled(true);
void AddressBook::cancel()
    ui->nameLine->setText(oldName);
    ui->addressText->setText(oldAddress);
void AddressBook::next()
    QMap<QString, QString>::iterator i = contacts.find(name);
    if (i != contacts.end())
        i++;
    if (i == contacts.end())
        i = contacts.begin();
    ui->nameLine->setText(i.key());
    ui->addressText->setText(i.value());
void AddressBook::previous()
        return;
    if (i == contacts.begin())
        i = contacts.end();
    i--;
void AddressBook::editContact()
    updateInterface(EditingMode);
void AddressBook::removeContact()
    if (contacts.contains(name))
        int button = QMessageBox::question(this,tr("删除确认"),tr("确认要删除  \"%1\"?").arg(name), QMessageBox::Yes | QMessageBox::No);
        if (button == QMessageBox::Yes)
            previous();
            contacts.remove(name);
            QMessageBox::information(this, tr("删除成功"),tr("\"%1\" 已经删除。").arg(name));
void AddressBook::updateInterface(Mode mode)
    currentMode = mode;
    switch (currentMode)
       case AddingMode:
       case EditingMode:
               ui->nameLine->setReadOnly(false);
               ui->nameLine->setFocus(Qt::OtherFocusReason);
               ui->addressText->setReadOnly(false);
               ui->addButton->setEnabled(false);
               ui->submitButton->show();
               ui->cancelButton->show();
       break;
    case NavigationMode:
        ui->editButton->setEnabled(number >= 1);
        ui->removeButton->setEnabled(number >= 1);
        ui->previousButton->setEnabled(number >1);
        ui->findButton->setEnabled(number > 2);
        break;
void AddressBook::findContact()
  FindDialog *dialog = new FindDialog;
  if (dialog->exec() == QDialog::Accepted)
      QString contactName = dialog->findText();
      if (contacts.contains(contactName))
          ui->nameLine->setText(contactName);
          ui->addressText->setText(contacts.value(contactName));
      else
           QMessageBox::information(this, tr("未找到联系人"),tr("地址簿中没有\"%1\" 。").arg(contactName));
           return;
复制代码
