字符设备gpio
150|0
 楼主| 无幻 发表于 2018-9-27 16:50 | 显示全部楼层 |阅读模式
GPIO, LED, se, ev, ST
经过几个下班业余时间,终于完成了一个比较全面的字符设备了,(注释掉的为阻塞read方法)该字符设备结合了s3c6410的led和key,key为非中断驱动,接下来可以研究异步通知,中断和内核定时器了(这个在工作实际应用中比较常用,比如一个i2c设备如gsensor,不需要中断的时候(节约gpio口),可以结合内核定时器和工作队列来实现固定时间读取)。期待下期吧·······
要应用测试程序的请留言。
参考:linux设备驱动程序(第三版)
    linux设备驱动开发详解
file:gpio.h#ifndef _GPIO_H_
#define _GPIO_H_
#include <linux/cdev.h>
#include <linux/wait.h>
#include <linux/semaphore.h>
#define LED_MAJOR  0
#define DEVICE_NAME "leds"
#define GPKCON0 0
#define GPKCON1 1
#define GPKDAT  2
#define GPKPUD  3
#define MAX_NUM 6
struct led_dev{
    struct cdev cdev;
    struct semaphore sem;
    wait_queue_head_t w_wait;
    wait_queue_head_t r_wait;
    unsigned int* base;
    unsigned int key;
    unsigned char rflag;
    unsigned char wflag;
    unsigned int val;
#define BITSET(name, val)  do{name |= val;}while(0)
#define BITCSET(name, mask, val)  do{ name &= ~mask; \
                                      name |= val }while(0)
#define BITCLR(name, mask)    do{ name &= ~mask;}while(0)
#endif复制代码
file:gpio.c
#include <linux/module.h>
#include <linux/fs.h>
#include <linux/slab.h>
#include <linux/device.h>
#include <mach/map.h>
#include <mach/regs-gpio.h>
#include <mach/gpio-bank-k.h>
#include <mach/gpio-bank-n.h>
#include <asm/io.h>
#include <asm/uaccess.h>
#include <linux/sched.h>
#include <linux/poll.h>
#include "gpio.h"
#define GPIO_DEBUG
#ifdef GPIO_DEBUG
#define dprintk(fmt, arg...)     printk("###GPIO DEBUG###%s():"fmt, __func__, ##arg)
#else
#endif
static int led_major = LED_MAJOR;
struct led_dev* led;
static int led_open(struct inode* inode, struct file* filp)
    dprintk("open!\n");
    filp->private_data = led;
    return 0;
static int led_close(struct inode* inode, struct file* filp)
    dprintk("close!\n");
    return 0;
static ssize_t led_read(struct file* filp, char __user* buff, size_t count, loff_t* offp)
    struct led_dev* led = filp->private_data;
    if(down_interruptible(&led->sem))
        return -ERESTARTSYS;
#if 0
    dprintk("led->rflag=%d, led->wflag=%d\n", led->rflag, led->wflag);
    while(!led->rflag){
        DEFINE_WAIT(wait);
        up(&led->sem);
        if(filp->f_flags & O_NONBLOCK)
            return -EAGAIN;
        dprintk("prepare to wait!\n");
        prepare_to_wait(&led->r_wait, &wait, TASK_INTERRUPTIBLE);
        if(led->rflag == 0)
            schedule();
        dprintk("finish wait!\n");
        finish_wait(&led->r_wait, &wait);
        if(signal_pending(current))
#endif
    if(count < 0 || count > 2)
        count = 1;
    led->key = readl(S3C64XX_GPNDAT);
    dprintk("led->key is 0x%x\n", led->key);    //led->key & 0x3f
    if(copy_to_user(buff, &led->key, count))
        return -EFAULT;
    led->rflag = 0;
    if((led->key & 0x3f) != 0x3f){
        led->wflag = 1;
        wake_up_interruptible(&led->w_wait);
    up(&led->sem);
    return count;
static ssize_t led_write(struct file* filp, const char __user* buff, size_t count, loff_t* offp)
    DECLARE_WAITQUEUE(wait, current);
    add_wait_queue(&led->w_wait, &wait);
    while(!led->wflag){
        if(filp->f_flags & O_NONBLOCK){
            up(&led->sem);
            remove_wait_queue(&led->w_wait, &wait);
            return -EAGAIN;
        __set_current_state(TASK_INTERRUPTIBLE);
        up(&led->sem);
        dprintk("into schedule!\n");
        schedule();
        dprintk("out schedule!\n");
        if(signal_pending(current)){
            up(&led->sem);
            set_current_state(TASK_RUNNING);
        count = 1;
    if(copy_from_user(&led->val, buff, count))
        return -EFAULT;
    dprintk("led->val=0x%x\n", led->val);
    writel(led->val << 4, led->base + GPKDAT);
    led->rflag = 1;
    led->wflag = 0;
    wake_up_interruptible(&led->r_wait);
    up(&led->sem);
    return count;
static long led_ioctl(struct file* filp, unsigned int cmd, unsigned long arg)
    unsigned int tmp;
    switch(cmd){
        case 0:
        case 1:
            dprintk("cmd=%d, arg=%d\n", cmd, arg);
            tmp = readl(led->base + GPKDAT);
            tmp &= ~(1 << (4 + arg));        //clear
            tmp |= ( (!cmd) << (4 + arg) );  //set
            writel(tmp, led->base + GPKDAT);
            up(&led->sem);
            break;
        default:
            break;
    return 0;
static unsigned int led_poll(struct file* filp, poll_table* wait)
    unsigned int mask = 0;
    down(&led->sem);
    poll_wait(filp, &led->w_wait, wait);
    poll_wait(filp, &led->r_wait, wait);
    if(led->rflag)
        mask |= POLLIN | POLLRDNORM;
    if(led->wflag)
        mask |= POLLOUT | POLLWRNORM;
    up(&led->sem);
    return mask;
static const struct file_operations led_fops = {
    .open           = led_open,
    .release        = led_close,
    .read              = led_read,
    .write             = led_write,
    .unlocked_ioctl = led_ioctl,
    .poll            = led_poll,
static void led_setup_cdev(struct led_dev* dev, int index)
    int err, devno = MKDEV(led_major, 0);
    cdev_init(&dev->cdev, &led_fops);
    dev->cdev.owner = THIS_MODULE;
    err = cdev_add(&dev->cdev, devno, 1);
    if(err)
        printk("error add cdev!\n");
struct class* led_class;
int led_init(void)
    int result;
    unsigned tmp;
    dev_t devno = MKDEV(led_major, 0);
    if(led_major)
        result = register_chrdev_region(devno, 1, DEVICE_NAME);
    else{
        dprintk("alloc_chrdev_region\n");
        result = alloc_chrdev_region(&devno, 0, 1, DEVICE_NAME);
        led_major = MAJOR(devno);
    if(result < 0)
        return result;
    led = kmalloc(sizeof(struct led_dev), GFP_KERNEL);
    if(!led){
        result = -ENOMEM;
        goto malloc_error;
    memset(led, 0, sizeof(struct led_dev));
    led_setup_cdev(led, 0);
    init_MUTEX(&led->sem);
    init_waitqueue_head(&led->w_wait);
    init_waitqueue_head(&led->r_wait);
    led->rflag = 0;
    led->wflag = 0;
    dprintk("S3C64XX_GPK_BASE=0x%x\n", (unsigned int)S3C64XX_GPK_BASE);
    led->base = S3C64XX_GPK_BASE;
    led->val = 0xf << 4;
    dprintk("led->base=0x%x\n", (unsigned int)led->base);
    tmp = readl(led->base + GPKCON0);
    tmp = (tmp & ~(0xffffU<<16))|(0x1111U<<16);
    writel(tmp, led->base + GPKCON0);
    dprintk("led->base=0x%x\n", (unsigned int)(led->base + GPKDAT));
    dprintk("S3C64XX_GPKDAT=0x%x\n", (unsigned int)S3C64XX_GPKDAT);
    writel(led->val, led->base + GPKDAT);
    tmp = readl(S3C64XX_GPNCON);
    tmp &= ~0xfffU;
    writel(tmp, S3C64XX_GPNCON);
//    dprintk("key val is 0x%x\n", readl(S3C64XX_GPNDAT));
    led_class = class_create(THIS_MODULE, "led_class");
    device_create(led_class, NULL, MKDEV(led_major, 0), NULL, "%s", DEVICE_NAME);
    return 0;
malloc_error:
    unregister_chrdev_region(devno, 1);
    return result;
void led_exit(void)
    cdev_del(&led->cdev);
    device_destroy(led_class, MKDEV(led_major, 0));
    class_destroy(led_class);
    kfree(led);
    unregister_chrdev_region(MKDEV(led_major, 0), 1);
module_init(led_init);
module_exit(led_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("jf.s <jingfeng.shi@emdoor.com>");复制代码
