Amlogic DVB模块集成参考源码
355|0
 楼主| kaloulin 发表于 2018-9-30 09:56 | 显示全部楼层 |阅读模式
希望资料有所帮助。
单片机源程序如下:
        This program is free software; you can redistribute it and/or modify
        it under the terms of the GNU General Public License as published by
        the Free Software Foundation; either version 2 of the License, or
        (at your option) any later version.
        This program is distributed in the hope that it will be useful,
        but WITHOUT ANY WARRANTY; without even the implied warranty of
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        GNU General Public License for more details.
        You should have received a copy of the GNU General Public License
        along with this program; if not, write to the Free Software
        Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
#ifndef CONFIG_ARM64
#include <mach/am_regs.h>
#else
#include <linux/reset.h>
#endif
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/moduleparam.h>
#include <linux/firmware.h>
#include <linux/init.h>
#include <linux/delay.h>
#include <linux/i2c.h>
#include <linux/version.h>
#include <linux/amlogic/aml_gpio_consumer.h>
#include <linux/platform_device.h>
#include "aml_fe.h"
#include "avl6862.h"
#include "r848a.h"
#include "aml_dvb.h"
#undef pr_err
#define pr_dbg(fmt, args...) \
        do {\
                if (debug_fe)\
                        printk("DVB FE: " fmt, ##args);\
        } while (0)
#define pr_err(fmt, args...) printk("DVB FE: " fmt, ## args)
#define pr_inf(fmt, args...)   printk("DVB FE: " fmt, ## args)
MODULE_PARM_DESC(debug_fe, "\n\t\t Enable frontend debug information");
static int debug_fe;
module_param(debug_fe, int, 0644);
MODULE_PARM_DESC(frontend_power, "\n\t\t Power GPIO of frontend");
static int frontend_power = -1;
module_param(frontend_power, int, 0644);
MODULE_PARM_DESC(frontend_reset, "\n\t\t Reset GPIO of frontend");
static int frontend_reset = -1;
module_param(frontend_reset, int, 0644);
static struct aml_fe avl6862_fe[FE_DEV_COUNT];
static char *device_name = "avl6862";
#if 1
static struct r848_config r848_config = {
        .i2c_address = 0x7A,
#endif
static struct avl6862_config avl6862_config = {
        .demod_address = 0x14,
        .tuner_address = 0x7A,
int avl6862_Reset(void)
        pr_dbg("avl6862_Reset!\n");
        gpio_request(frontend_reset,device_name);
        gpio_direction_output(frontend_reset, 0);
        msleep(600);
        gpio_direction_output(frontend_reset, 1);
        msleep(200);
        return 0;
int avl6862_gpio(void)
        pr_dbg("avl6862_gpio!\n");
        gpio_request(frontend_power,device_name);
        gpio_direction_output(frontend_power, 1);
        return 0;
static int avl6862_fe_init(struct aml_dvb *advb, struct platform_device *pdev, struct aml_fe *fe, int id)
        struct dvb_frontend_ops *ops;
        int ret, i2c_adap_id = 1;
        struct i2c_adapter *i2c_handle;
#ifdef CONFIG_ARM64
        struct gpio_desc *desc;
        int gpio_reset, gpio_power;
#endif
        pr_inf("Init AVL6862 frontend %d\n", id);
#ifdef CONFIG_OF
        if (of_property_read_u32(pdev->dev.of_node, "dtv_demod0_i2c_adap_id", &i2c_adap_id)) {
                ret = -ENOMEM;
                goto err_resource;
        pr_dbg("i2c_adap_id=%d\n", &i2c_adap_id);
        desc = of_get_named_gpiod_flags(pdev->dev.of_node, "dtv_demod0_reset_gpio-gpios", 0, NULL);
        gpio_reset = desc_to_gpio(desc);
        pr_dbg("gpio_reset=%d\n", gpio_reset);
        desc = of_get_named_gpiod_flags(pdev->dev.of_node, "dtv_demod0_power_gpio-gpios", 0, NULL);
        gpio_power = desc_to_gpio(desc);
        pr_dbg("gpio_power=%d\n", gpio_power);
#endif /*CONFIG_OF*/
        frontend_reset = gpio_reset;
        frontend_power = gpio_power;
        i2c_handle = i2c_get_adapter(i2c_adap_id);
        if (!i2c_handle) {
                pr_err("Cannot get i2c adapter for id:%d! \n", i2c_adap_id);
                ret = -ENOMEM;
                goto err_resource;
        avl6862_Reset();
        avl6862_gpio();
        fe->fe = dvb_attach(avl6862_attach, &avl6862_config, i2c_handle);
        if (!fe->fe) {
                pr_err("avl6862_attach attach failed!!!\n");
                ret = -ENOMEM;
                goto err_resource;
        if (dvb_attach(r848x_attach, fe->fe, &r848_config, i2c_handle) == NULL) {
                dvb_frontend_detach(fe->fe);
                fe->fe = NULL;
                pr_err("r848_attach attach failed!!!\n");
                ret = -ENOMEM;
                goto err_resource;
        pr_inf("AVL6862 and R848 attached!\n");
        if ((ret=dvb_register_frontend(&advb->dvb_adapter, fe->fe))) {
                pr_err("Frontend avl6862 registration failed!!!\n");
                ops = &fe->fe->ops;
                if (ops->release != NULL)
                        ops->release(fe->fe);
                fe->fe = NULL;
                ret = -ENOMEM;
                goto err_resource;
        pr_inf("Frontend AVL6862 registred!\n");
        return 0;
err_resource:
        return ret;
static int avl6862_fe_probe(struct platform_device *pdev)
        int ret = 0;
        struct aml_dvb *dvb = aml_get_dvb_device();
        if(avl6862_fe_init(dvb, pdev, &avl6862_fe[0], 0)<0)
                return -ENXIO;
        platform_set_drvdata(pdev, &avl6862_fe[0]);
        return ret;
static void avl6862_fe_release(struct aml_dvb *advb, struct aml_fe *fe)
        if(fe && fe->fe) {
                dvb_unregister_frontend(fe->fe);
static int avl6862_fe_remove(struct platform_device *pdev)
        struct aml_fe *drv_data = platform_get_drvdata(pdev);
        platform_set_drvdata(pdev, NULL);
        avl6862_fe_release(dvb, drv_data);
        return 0;
static int avl6862_fe_resume(struct platform_device *pdev)
        pr_dbg("avl6862_fe_resume \n");
        return 0;
static int avl6862_fe_suspend(struct platform_device *pdev, pm_message_t state)
        pr_dbg("avl6862_fe_suspend \n");
        return 0;
#ifdef CONFIG_OF
static const struct of_device_id aml_fe_dt_match[]={
                .compatible = "amlogic,dvbfe",
static struct platform_driver aml_fe_driver = {
        .probe = avl6862_fe_probe,
        .remove = avl6862_fe_remove,
        .resume = avl6862_fe_resume,
        .suspend = avl6862_fe_suspend,
        .driver = {
            .name = "avl6862",
        .owner = THIS_MODULE,
#ifdef CONFIG_OF
        .of_match_table = aml_fe_dt_match,
#endif
static int __init avlfrontend_init(void) {
         return platform_driver_register(&aml_fe_driver);
static void __exit avlfrontend_exit(void) {
        platform_driver_unregister(&aml_fe_driver);
module_init(avlfrontend_init);
module_exit(avlfrontend_exit);
MODULE_AUTHOR("afl1");
MODULE_DESCRIPTION("AVL6862 DVB-Sx/Tx/C frontend driver");
MODULE_LICENSE("GPL");
复制代码
