无表头单链表的基本操作
217|0
 楼主| 丑帅丑帅的 发表于 2018-10-5 12:06 | 显示全部楼层 |阅读模式
typedef struct node
        int data;
        struct node *next;
}Lnode,*linklist;
void link_print(linklist head);        //打印链表
        linklist   *p = head;
        if (p == NULL)
                printf("empty list \n");
        while(p != NULL)
                printf("p->data  is   %d\n",p->data);
                p = p->next;
linklist link_create()                //创建链表(后插)并且返回链表的头指针
        linklist head=NULL,tail=NULL,s1=NULL;
        int a;
        printf("请输入数据,零除外\n ");
        scanf("%d\n",&a);
        while(a != 0)
                s1 = (linklist)malloc(Lnode);
                if(s1 == NULL)
                        printf("malloc  fail\n");
                        return head;
                s->data = a;
                if (head == NULL)
                        head = s1;
                        tail = s1;
                        head->next = NULL;
                else
                        tail ->next = s1;
                        tail = s1;
                        tail ->next = NULL;
                scanf("%d\n",&a);
        return head;
linklist link_create()                //创建链表(前插)并且返回链表的头指针
        int a;
        scanf("%d\n",&a);
        while(a != 0)
                if(s1 == NULL)
                        return head;
                s->data = a;
                if (head == NULL)
                        head = s1;
                        head->next = NULL;
                else
                         s1->next = head;
                        head = s1
                scanf("%d\n",&a);
        return head;
int link_getLength(linklist head)//测试链表的长度
        linklist  p=head ;
        int len = 0;
        while(p != NULL)
                len ++;
                p=p->next;
        return len;
linklist link_searchByindex(linklist head,int index)  //查找链表中的第几个结点
        int i=0;
        linklist p = head ;
        if((index<1)||(index>link_getLength(head)))
                printf(" 不存在 \n");
                return head;
        for(i=1;i<index;i++)
                p=p->next;
        return p;
void delete_list(linklist head)   //删除整个链表
        linklist p = head ;
        while(head != NULL)
                p = head->next;
                free(head);
                head = p;
int link_insert_add(linklist head,int data,int index)
*入参:head:要插入链表头指针的地址,data插入的数据,index:插入位置
*返回值:插入成功返回0,插入失败返回-1,
        linklist p = head,s1=NULL;
                printf("没有这个位子");
                return -1;
        s1=(linklist)malloc(sizeof(Lnode));
        if(s1 == NULL)
                return -1;
        s1 ->data = data;
        if((index ==1)||(head == NULL))
                s1->next =head;
                head = s1;
        else
                int len=link_getLength(head);
                linklist p=NULL;
                p = link_searchByindex(head,index-1);
                if(p!=NULL)
                        s1->next = p->next;
                        p->next = s1;
                else
                        printf("insert  error\n");
                        free(s1);
                        return -1;
        return 0;
linklist link_delete(linklist head,int index)             //删除链表中的第index个节点
        linklist p=head,p1=NULL;
        if(p==NULL)
                printf("empty  list\n");
                return head;
                printf("没有这个节点\n");
                return head;
        if(index ==1)
                head =p->next;
                free(p);
        if(index ==(link_getLength(head)))
                index=index-1;
                while(index--)
                        p1=p;
                        p=p->next;
                p1->next=NULL;
                free(p);
        if((index != 1)&&(index !=(link_getLength(head))))
                index=index-1;
                while(index--)
                        p1=p;
                        p=p->next;
                p1->next = p->next;
                free(p);
        return head;
linklist getMaxFormOld(linklist pold)//找节点中最大的data
        linklist pMax = pold;
        linklist p=pold->next;
        while(p!=NULL)
                if(pMax->data < p->data)
                        pMax = p;
                p=p->next;
        return pMax;
linklist removeFormOld(linklist pold,linklist pmax)//移除链表中的最大节点
        if(pold == pmax)
                pold =pold->next;
        else
                linklist p =pold;
                while(p!=NULL)
                        if(p->next ==pmax)
                        break;
                        p=p->next;
                p->next =pmax->next;
        return pold;
linklist addToNew(linklist pnew,linklist pmax)//添加新的节点
        pmax->next = pnew;
        pnew = pmax;
        return pnew;
linklist link_sort(linklist pOld)
        linklist pNew = NULL;
        linklist pmax;
        while(pOld!=NULL)
        /*从旧链表上找最大值节点的地址*/
                pmax = getMaxFormOld(pOld);
        /*将最大值节点从旧链表上拆下来*/
                pOld=removeFormOld(pOld,pmax);
        /*将最大值节点以前插入的方式插入到新链表*/
                pNew=addToNew(pNew,pmax);
        return pNew;
