用的是CCS2.20版本提供的SDFLASH,设置好SDFLASH后,主要是要将需要下载的.out文件写进去.
关键在于在线仿真时的cmd文件要加以更换成新的.使用的是:
-o .DebugPULSE_AD.out
-m PULSE_AD.map
MEMORY
PAGE 0 :
OTP : origin = 0x3D7800, length = 0x000800
FLASHJ : origin = 0x3D8000, length = 0x002000
FLASHI : origin = 0x3DA000, length = 0x002000
FLASHH : origin = 0x3DC000, length = 0x004000
FLASHG : origin = 0x3E0000, length = 0x004000
FLASHF : origin = 0x3E4000, length = 0x004000
FLASHE : origin = 0x3E8000, length = 0x004000
FLASHD : origin = 0x3EC000, length = 0x004000
FLASHC : origin = 0x3F0000, length = 0x004000
FLASHB : origin = 0x3F4000, length = 0x002000
FLASHA : origin = 0x3F6000, length = 0x001FF6
BEGIN : origin = 0x3F7FF6, length = 0x000002
PASSWDS : origin = 0x3F7FF8, length = 0x000008
ROM : origin = 0x3FF000, length = 0x000FC0
VECTORS : origin = 0x3FFFC2, length = 0x00003E
PAGE 1 :
/* SARAM */
RAMM0M1 : origin = 0x000000, length = 0x000800
/* Peripheral Frame 0: */
DEV_EMU : origin = 0x000880, length = 0x000180
FLASH_REGS : origin = 0x000A80, length = 0x000060
CSM : origin = 0x000AE0, length = 0x000010
XINTF : origin = 0x000B20, length = 0x000020
CPU_TIMER0 : origin = 0x000C00, length = 0x000008
CPU_TIMER1 : origin = 0x000C08, length = 0x000008
CPU_TIMER2 : origin = 0x000C10, length = 0x000008
PIE_CTRL : origin = 0x000CE0, length = 0x000020
PIE_VECT : origin = 0x000D00, length = 0x000100
/* Peripheral Frame 1: */
ECAN_A : origin = 0x006000, length = 0x000100
ECAN_AMBOX : origin = 0x006100, length = 0x000100
/* Peripheral Frame 2: */
SYSTEM : origin = 0x007010, length = 0x000020
SPI_A : origin = 0x007040, length = 0x000010
SCI_A : origin = 0x007050, length = 0x000010
XINTRUPT : origin = 0x007070, length = 0x000010
GPIOMUX : origin = 0x0070C0, length = 0x000020
GPIODAT : origin = 0x0070E0, length = 0x000020
ADC : origin = 0x007100, length = 0x000020
EV_A : origin = 0x007400, length = 0x000040
EV_B : origin = 0x007500, length = 0x000040
SPI_B : origin = 0x007740, length = 0x000010
SCI_B : origin = 0x007750, length = 0x000010
MCBSP_A : origin = 0x007800, length = 0x000040
/* CSM Password Locations */
CSM_PWL : origin = 0x3F7FF8, length = 0x000008
/* SARAM */
RAML0L1 : origin = 0x008000, length = 0x002000
RAMH0 : origin = 0x3F8000, length = 0x002000
SECTIONS
/* Allocate program areas: */
.reset : > BEGIN PAGE = 0
vectors : > VECTORS PAGE = 0
.cinit : > FLASHJ PAGE = 0
.text : > FLASHA PAGE = 0
/* Allocate data areas: */
.stack : > RAMM0M1 PAGE = 1
.bss : > RAML0L1 PAGE = 1
.ebss : > RAML0L1 PAGE = 1
.const: load = FLASHB PAGE 0, run = RAML0L1 PAGE 1
/* Get Run Address */
__const_run = .;
/* Mark Load Address*/
*(.c_mark)
/* Allocate .const */
*(.const)
/* Compute Length */
__const_length = .-__const_run;
.econst: load = FLASHB PAGE 0, run = RAML0L1 PAGE 1
__econst_run = .;
*(.ec_mark)
*(.econst)
__econst_length = .-__econst_run;
.sysmem : > RAMH0 PAGE = 1
/* Allocate IQ math areas: */
IQmath : > FLASHI PAGE = 0 /* Math Code */
IQmathFastTables : > FLASHI PAGE = 0 /* Math Tables in fast memory */
IQmathTables : > ROM PAGE = 0 /* Math Tables In ROM */
/* Allocate Peripheral Frame 0 Register Structures: */
DevEmuRegsFile : > DEV_EMU PAGE = 1
FlashRegsFile : > FLASH_REGS PAGE = 1
CsmRegsFile : > CSM PAGE = 1
XintfRegsFile : > XINTF PAGE = 1
CpuTimer0RegsFile : > CPU_TIMER0 PAGE = 1
CpuTimer1RegsFile : > CPU_TIMER1 PAGE = 1
CpuTimer2RegsFile : > CPU_TIMER2 PAGE = 1
PieCtrlRegsFile : > PIE_CTRL PAGE = 1
PieVectTable : > PIE_VECT PAGE = 1
/* Allocate Peripheral Frame 2 Register Structures: */
ECanaRegsFile : > ECAN_A PAGE = 1
ECanaMboxesFile : > ECAN_AMBOX PAGE = 1
/* Allocate Peripheral Frame 1 Register Structures: */
SysCtrlRegsFile : > SYSTEM PAGE = 1
SpiaRegsFile : > SPI_A PAGE = 1
SciaRegsFile : > SCI_A PAGE = 1
XIntruptRegsFile : > XINTRUPT PAGE = 1
GpioMuxRegsFile : > GPIOMUX PAGE = 1
GpioDataRegsFile : > GPIODAT PAGE = 1
AdcRegsFile : > ADC PAGE = 1
EvaRegsFile : > EV_A PAGE = 1
EvbRegsFile : > EV_B PAGE = 1
ScibRegsFile : > SCI_B PAGE = 1
McbspaRegsFile : > MCBSP_A PAGE = 1
CsmPwlFile : > CSM_PWL PAGE = 1
然后把lib文件替换成:rts2800_fl040830.lib
就可以啦.
希望你也成功!!!
本人qq: 15007807 欢迎以后交流.
点评:
FLASH不用分这么细的,编大一点的程序会有麻烦
以下是本人做过的某项目CMD文件
MEMORY
PAGE 0 :
/* For this example, H0 is split between PAGE 0 and PAGE 1 */
/* BEGIN is used for the "boot to HO" bootloader mode */
/* RESET is loaded with the reset vector only if */
/* the boot is from XINTF Zone 7. Otherwise reset vector */
/* is fetched from boot ROM. See .reset section below */
RAMM0 : origin = 0x000000, length = 0x000400
BEGIN : origin = 0x3f7ff6, length = 0x000002
PRAMH0 : origin = 0x3d8000, length = 0x004000 /* */
RESET : origin = 0x3FFFC0, length = 0x000002
PAGE 1 :
LSARAM : origin = 0x3de000, length = 0x008000 /* */
RAMM1 : origin = 0x000400, length = 0x000400
DRAMH0 : origin = 0x3f8000, length = 0x001000 /* */
BUFA : origin = 0x8000, length=0x1000
BUFB : origin = 0x9000, length=0x1000
BUFC : origin = 0x3f9000, length=0x1000
RECORDDATA : origin = 0x80020, length=0x700
PARAMETER : origin = 0x80725, length=0x20
PASSWORD : origin = 0x80005, length=0x08
SECTIONS
/* Setup for "boot to H0" mode:
The codestart section (found in DSP28_CodeStartBranch.asm)
re-directs execution to the start of user code.
Place this section at the start of H0 */
codestart : > BEGIN, PAGE = 0
ramfuncs : > PRAMH0 PAGE = 0
.text : > PRAMH0, PAGE = 0
.cinit : > PRAMH0, PAGE = 0
.pinit : > PRAMH0, PAGE = 0
.switch : > RAMM0, PAGE = 0
.reset : > RESET, PAGE = 0, TYPE = DSECT /* not used, */
.stack : > RAMM1, PAGE = 1
.ebss : > DRAMH0, PAGE = 1
.econst : > LSARAM, PAGE = 1
.esysmem : > DRAMH0, PAGE = 1
.bufferA : {}>BUFA PAGE 1
.bufferB : {}>BUFB PAGE 1
.bufferC : {}>BUFC PAGE 1
.RecordData : {}>RECORDDATA PAGE 1
.parameter : {}>PARAMETER PAGE 1
.password : {}>PASSWORD PAGE 1
