成功烧写TMS320F2812经验
2352|0
 楼主| 爱之翼V 发表于 2012-1-30 13:00 | 显示全部楼层 |阅读模式
用的是CCS2.20版本提供的SDFLASH,设置好SDFLASH后,主要是要将需要下载的.out文件写进去.
关键在于在线仿真时的cmd文件要加以更换成新的.使用的是:
-o .DebugPULSE_AD.out
-m PULSE_AD.map
MEMORY
PAGE 0 :
   OTP         : origin = 0x3D7800, length = 0x000800
   FLASHJ      : origin = 0x3D8000, length = 0x002000
   FLASHI      : origin = 0x3DA000, length = 0x002000
   FLASHH      : origin = 0x3DC000, length = 0x004000
   FLASHG      : origin = 0x3E0000, length = 0x004000
   FLASHF      : origin = 0x3E4000, length = 0x004000
   FLASHE      : origin = 0x3E8000, length = 0x004000
   FLASHD      : origin = 0x3EC000, length = 0x004000
   FLASHC      : origin = 0x3F0000, length = 0x004000
   FLASHB      : origin = 0x3F4000, length = 0x002000
   FLASHA      : origin = 0x3F6000, length = 0x001FF6
   BEGIN       : origin = 0x3F7FF6, length = 0x000002
   PASSWDS     : origin = 0x3F7FF8, length = 0x000008
   ROM         : origin = 0x3FF000, length = 0x000FC0
   VECTORS     : origin = 0x3FFFC2, length = 0x00003E
PAGE 1 :
   /* SARAM                     */
   RAMM0M1    : origin = 0x000000, length = 0x000800
   /* Peripheral Frame 0:   */
   DEV_EMU    : origin = 0x000880, length = 0x000180
   FLASH_REGS : origin = 0x000A80, length = 0x000060
   CSM        : origin = 0x000AE0, length = 0x000010
   XINTF      : origin = 0x000B20, length = 0x000020
   CPU_TIMER0 : origin = 0x000C00, length = 0x000008
   CPU_TIMER1 : origin = 0x000C08, length = 0x000008
   CPU_TIMER2 : origin = 0x000C10, length = 0x000008
   PIE_CTRL   : origin = 0x000CE0, length = 0x000020
   PIE_VECT   : origin = 0x000D00, length = 0x000100
   /* Peripheral Frame 1:   */
   ECAN_A     : origin = 0x006000, length = 0x000100
   ECAN_AMBOX : origin = 0x006100, length = 0x000100
   /* Peripheral Frame 2:   */
   SYSTEM     : origin = 0x007010, length = 0x000020
   SPI_A      : origin = 0x007040, length = 0x000010
   SCI_A      : origin = 0x007050, length = 0x000010
   XINTRUPT   : origin = 0x007070, length = 0x000010
   GPIOMUX    : origin = 0x0070C0, length = 0x000020
   GPIODAT    : origin = 0x0070E0, length = 0x000020
   ADC        : origin = 0x007100, length = 0x000020
   EV_A       : origin = 0x007400, length = 0x000040
   EV_B       : origin = 0x007500, length = 0x000040
   SPI_B      : origin = 0x007740, length = 0x000010
   SCI_B      : origin = 0x007750, length = 0x000010
   MCBSP_A    : origin = 0x007800, length = 0x000040
   /* CSM Password Locations */
   CSM_PWL    : origin = 0x3F7FF8, length = 0x000008
   /* SARAM                    */
   RAML0L1    : origin = 0x008000, length = 0x002000
   RAMH0      : origin = 0x3F8000, length = 0x002000
SECTIONS
   /* Allocate program areas: */
   .reset              : > BEGIN       PAGE = 0
   vectors             : > VECTORS     PAGE = 0
   .cinit              : > FLASHJ      PAGE = 0
   .text               : > FLASHA       PAGE = 0
   /* Allocate data areas: */
   .stack              : > RAMM0M1     PAGE = 1
   .bss                : > RAML0L1     PAGE = 1
   .ebss               : > RAML0L1     PAGE = 1
   .const:                        load =         FLASHB PAGE 0, run = RAML0L1 PAGE 1
            /* Get Run Address        */
            __const_run = .;
            /* Mark Load Address*/
            *(.c_mark)
            /* Allocate .const        */
            *(.const)
            /* Compute Length        */
            __const_length = .-__const_run;
   .econst:                        load =         FLASHB PAGE 0, run = RAML0L1 PAGE 1
            __econst_run = .;
            *(.ec_mark)
            *(.econst)
            __econst_length = .-__econst_run;
   .sysmem             : > RAMH0       PAGE = 1
   /* Allocate IQ math areas: */
   IQmath              : > FLASHI      PAGE = 0   /* Math Code */
   IQmathFastTables    : > FLASHI      PAGE = 0   /* Math Tables in fast memory */
   IQmathTables        : > ROM         PAGE = 0   /* Math Tables In ROM */
   /* Allocate Peripheral Frame 0 Register Structures:   */
   DevEmuRegsFile      : > DEV_EMU     PAGE = 1
   FlashRegsFile       : > FLASH_REGS  PAGE = 1
   CsmRegsFile         : > CSM         PAGE = 1
   XintfRegsFile       : > XINTF       PAGE = 1
   CpuTimer0RegsFile   : > CPU_TIMER0  PAGE = 1
   CpuTimer1RegsFile   : > CPU_TIMER1  PAGE = 1
   CpuTimer2RegsFile   : > CPU_TIMER2  PAGE = 1
   PieCtrlRegsFile     : > PIE_CTRL    PAGE = 1
   PieVectTable        : > PIE_VECT    PAGE = 1
   /* Allocate Peripheral Frame 2 Register Structures:   */
   ECanaRegsFile       : > ECAN_A      PAGE = 1
   ECanaMboxesFile     : > ECAN_AMBOX  PAGE = 1
   /* Allocate Peripheral Frame 1 Register Structures:   */
   SysCtrlRegsFile     : > SYSTEM      PAGE = 1
   SpiaRegsFile        : > SPI_A       PAGE = 1
   SciaRegsFile        : > SCI_A       PAGE = 1
   XIntruptRegsFile    : > XINTRUPT    PAGE = 1
   GpioMuxRegsFile     : > GPIOMUX     PAGE = 1
   GpioDataRegsFile    : > GPIODAT     PAGE = 1
   AdcRegsFile         : > ADC         PAGE = 1
   EvaRegsFile         : > EV_A        PAGE = 1
   EvbRegsFile         : > EV_B        PAGE = 1
   ScibRegsFile        : > SCI_B       PAGE = 1
   McbspaRegsFile      : > MCBSP_A     PAGE = 1
   CsmPwlFile          : > CSM_PWL     PAGE = 1
然后把lib文件替换成:rts2800_fl040830.lib
就可以啦.
希望你也成功!!!
本人qq: 15007807  欢迎以后交流.
点评:
FLASH不用分这么细的,编大一点的程序会有麻烦
以下是本人做过的某项目CMD文件
MEMORY
PAGE 0 :
   /* For this example, H0 is split between PAGE 0 and PAGE 1 */
   /* BEGIN is used for the "boot to HO" bootloader mode      */
   /* RESET is loaded with the reset vector only if           */
   /* the boot is from XINTF Zone 7.  Otherwise reset vector  */
   /* is fetched from boot ROM. See .reset section below      */
   RAMM0      : origin = 0x000000, length = 0x000400
   BEGIN      : origin = 0x3f7ff6, length = 0x000002
   PRAMH0     : origin = 0x3d8000, length = 0x004000   /*   */
   RESET      : origin = 0x3FFFC0, length = 0x000002
PAGE 1 :
   LSARAM     : origin = 0x3de000, length = 0x008000 /*   */
   RAMM1      : origin = 0x000400, length = 0x000400
   DRAMH0     : origin = 0x3f8000, length = 0x001000 /*   */
   BUFA       : origin = 0x8000,   length=0x1000
   BUFB       : origin = 0x9000,   length=0x1000
   BUFC       : origin = 0x3f9000, length=0x1000
   RECORDDATA : origin = 0x80020,  length=0x700
   PARAMETER  : origin = 0x80725,  length=0x20
   PASSWORD   : origin = 0x80005,  length=0x08
SECTIONS
   /* Setup for "boot to H0" mode:
      The codestart section (found in DSP28_CodeStartBranch.asm)
      re-directs execution to the start of user code.
      Place this section at the start of H0  */
   codestart        : > BEGIN,        PAGE = 0
   ramfuncs         : > PRAMH0        PAGE = 0
   .text            : > PRAMH0,       PAGE = 0
   .cinit           : > PRAMH0,       PAGE = 0
   .pinit           : > PRAMH0,       PAGE = 0
   .switch          : > RAMM0,        PAGE = 0
   .reset           : > RESET,        PAGE = 0, TYPE = DSECT /* not used, */
   .stack           : > RAMM1,        PAGE = 1
   .ebss            : > DRAMH0,       PAGE = 1
   .econst          : > LSARAM,       PAGE = 1
   .esysmem         : > DRAMH0,       PAGE = 1
   .bufferA         : {}>BUFA         PAGE 1
   .bufferB         : {}>BUFB         PAGE 1
   .bufferC         : {}>BUFC         PAGE 1
   .RecordData      : {}>RECORDDATA   PAGE 1
   .parameter       : {}>PARAMETER    PAGE 1
   .password        : {}>PASSWORD     PAGE 1
