在主函中调用这个函数程序就会一点儿也不执行
uint16_t EE_ReadVariable(uint16_t VirtAddress, uint16_t* Data)
uint16_t ValidPage = PAGE0;
uint16_t AddressValue = 0x5555, ReadStatus = 1;
uint32_t Address = 0x0803e800, PageStartAddress = 0x0803e800;
/* Get active Page for read operation */
ValidPage = EE_FindValidPage(READ_FROM_VALID_PAGE);
/* Check if there is no valid page */
if (ValidPage == NO_VALID_PAGE)
return NO_VALID_PAGE;
/* Get the valid Page start Address */
PageStartAddress = (uint32_t)(EEPROM_START_ADDRESS + (uint32_t)(ValidPage * PAGE_SIZE));
/* Get the valid Page end Address */
//Address = (uint32_t)((EEPROM_START_ADDRESS - 2) + (uint32_t)((1 + ValidPage) * PAGE_SIZE));
Address=CurWrAddress-2;
/* Check each active page address starting from end */
while (Address > (PageStartAddress + 2))
/* Get the current location content to be compared with virtual address */
AddressValue = (*(__IO uint16_t*)Address);
/* Compare the read address with the virtual address */
if (AddressValue == VirtAddress)
/* Get content of Address-2 which is variable value */
*Data = (*(__IO uint16_t*)(Address - 2));
/* In case variable value is read, reset ReadStatus flag */
ReadStatus = 0;
break;
else
/* Next address location */
Address = Address - 4;
/* Return ReadStatus value: (0: variable exist, 1: variable doesn't exist) */
return ReadStatus;
