[MCU] MSP430F5529LP的SPI中断方式通讯
878|4
 楼主| ddh531810421 发表于 2020-11-9 17:59 | 显示全部楼层 |阅读模式
想测试一下MSP430F5529LP这个板子的SPI通讯,用它上面的USCI_B1和USCI_B0的SPI引脚连接,B1作主机,B0作从机,想完成通讯,但是按照MSP430F5xx_6xx_DriverLib_Users_Guide-2_91_13_01.pdf的例子写的程序跑不起来,进入发送中断后,发送中断标志会被清除,然后就没法发送,卡住了,代码如下:
 楼主| ddh531810421 发表于 2020-11-9 18:00 | 显示全部楼层
#include "driverlib.h"
#include "msp430.h"
// Initialize data values
static uint8_t transmitData = 0x01;
static uint8_t receiveData = 0;
int main( void )
  WDT_A_hold(WDT_A_BASE);
//Initialize Master,USCI_B1作主机
  USCI_B_SPI_initMasterParam param = {0};
  param.selectClockSource = USCI_B_SPI_CLOCKSOURCE_SMCLK;
  param.clockSourceFrequency = UCS_getSMCLK();
  param.desiredSpiClock = 115200;
  param.msbFirst = USCI_B_SPI_MSB_FIRST;
  param.clockPhase = USCI_B_SPI_PHASE_DATA_CHANGED_ONFIRST_CAPTURED_ON_NEXT;
  param.clockPolarity = USCI_B_SPI_CLOCKPOLARITY_INACTIVITY_HIGH;
  bool returnValue = USCI_B_SPI_initMaster(USCI_B1_BASE, &param);
  if (STATUS_FAIL == returnValue){
    return 0;
  //Initialize Slave,USCI_B0作从机
  returnValue = USCI_B_SPI_initSlave(USCI_B0_BASE, USCI_B_SPI_MSB_FIRST,USCI_B_SPI_PHASE_DATA_CHANGED_ONFIRST_CAPTURED_ON_NEXT,USCI_B_SPI_CLOCKPOLARITY_INACTIVITY_HIGH);
    return 0;
  //Enable USCI_B_SPI module
  USCI_B_SPI_enable(USCI_B0_BASE);
  USCI_B_SPI_enable(USCI_B1_BASE);
  //Enable Receive interrupt
  USCI_B_SPI_enableInterrupt(USCI_B0_BASE, UCRXIE);
  USCI_B_SPI_enableInterrupt(USCI_B1_BASE, UCTXIE);
  //Configure port pins to reset slave
  // Wait for slave to initialize
  __delay_cycles(100);
  // USCI_B1 TX buffer ready?
// while (!USCI_B_SPI_getInterruptStatus(USCI_B1_BASE, UCTXIFG));
  //Transmit Data to slave
  //USCI_B_SPI_transmitData(USCI_B1_BASE, transmitData);
  // CPU off, enable interrupts
  __bis_SR_register(LPM0_bits + GIE);
  //while(1);
  // This is the USCI_B0 interrupt vector service routine.
  #pragma vector=USCI_B0_VECTOR
  __interrupt void USCI_B0_ISR(void)
  switch(__even_in_range(UCB0IV,4))
  // Vector 2 - RXIFG
  case 2:
    while (!USCI_B_SPI_getInterruptStatus(USCI_B0_BASE, UCRXIFG));
    receiveData = USCI_B_SPI_receiveData(USCI_B0_BASE);
  break;
  default: break;
  #pragma vector=USCI_B1_VECTOR
  __interrupt void USCI_B1_ISR(void)
  switch(__even_in_range(UCB1IV,4))
  // Vector 2 - RXIFG
  case 4:
  transmitData++;
  // Send next value
  //Delay between transmissions for slave to process information
  __delay_cycles(40);
  break;
  default: break;
其中使用的函数和宏都是driverlib中给的usci_b_spi.h和.c的,以及板子定义的资源
zhangmangui 发表于 2020-11-9 23:18 | 显示全部楼层
建议下载MSP430WARE看看有可以参考的例程不
 楼主| ddh531810421 发表于 2020-11-10 15:27 | 显示全部楼层
我下来了它的参考例程,修改以后能跑,例程的意思是先发送,然后就能进入接受中断(这里不是很明白,为什么发送数据后能进自己的接收中断,我从机根本没发数据,甚至线都没连),然后在中断里继续发送,(主机是MSP430F5529LP,从机是一块调试好的NXP板子)但是我发的数据是0,1,2这样递增,收到的却是128,0,129,1,130,2这样的,有点没想明白
 楼主| ddh531810421 发表于 2020-11-10 15:31 | 显示全部楼层
我下来了它的参考例程,修改以后能跑,例程的意思是先发送,然后就能进入接受中断(这里不是很明白,为什 ...
#define SPICLK                          500000
uint8_t transmitData = 0x00, receiveData = 0x00;
uint8_t returnValue = 0x00;
void main (void)
    //Stop watchdog timer
    //Set P2.6 for cs
    GPIO_setAsOutputPin(
        GPIO_PORT_P2,
        GPIO_PIN6
    GPIO_setOutputHighOnPin(
        GPIO_PORT_P2,
        GPIO_PIN6
    //Set P1.0 to output direction
        GPIO_PORT_P1,
        GPIO_PIN0
    //P3.5,4,0 option select
    GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P3,GPIO_PIN0 + GPIO_PIN1 + GPIO_PIN2);
    //GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P2,GPIO_PIN7);
    //Initialize Master
    param.desiredSpiClock = SPICLK;
    returnValue =  USCI_B_SPI_initMaster(USCI_B0_BASE, &param);
        return;
    //Enable SPI module
        USCI_B_SPI_clearInterrupt(USCI_B0_BASE, USCI_B_SPI_RECEIVE_INTERRUPT);
    USCI_B_SPI_enableInterrupt(USCI_B0_BASE, USCI_B_SPI_RECEIVE_INTERRUPT);
    //LED On
        GPIO_PORT_P1,
        GPIO_PIN0
//片选
    GPIO_setOutputLowOnPin(
        GPIO_PORT_P2,
        GPIO_PIN6
    //Wait for slave to initialize
    //Initialize data values
    transmitData = 0x00;
    //USCI_A0 TX buffer ready?
               USCI_B_SPI_TRANSMIT_INTERRUPT)) ;
    USCI_B_SPI_transmitData(USCI_B0_BASE, transmitData);
    //CPU off, enable interrupts
//This is the USCI_B0 interrupt vector service routine.
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
__interrupt
#elif defined(__GNUC__)
__attribute__((interrupt(USCI_B0_VECTOR)))
#endif
void USCI_B0_ISR (void)
    switch (__even_in_range(UCB0IV,4)){
        //Vector 2 - RXIFG
        case 2:
            //Increment data
            transmitData++;
            //Send next value
            transmitData
            __delay_cycles(200);
            break;
        default: break;
