[MCU] LaunchPad SPI 通信 无法进中断
921|0
 楼主| jcky001 发表于 2020-12-1 16:09 | 显示全部楼层 |阅读模式
  • 手上有两个LaunchPad,现在从一个LaunchPad作为主机,通过SPI不断发送数据给另一个LaunchPad,接收到数据后通过SPI反馈回来,在再第一块LaunchPad接收SPI数据,并通过串口上传。但是主机在接收SPI数据的时候无法进入中断,看RXBUF寄存器确实接收到数据了。初始化有问题,但是查了半天没发现是什么问题,请大牛指点。
复制代码
从机程序
  • #include <msp430.h>
  • //从机,接收SPI数据返回回去,并通过串口发给电脑。
  • unsigned char temp = 0x00;
  • void Clk_init()
  •         BCSCTL1 = CALBC1_16MHZ;                    // Set DCO
  •         DCOCTL = CALDCO_16MHZ;
  • void IO_init()
  •         P1SEL = BIT1 + BIT2 + BIT5 + BIT6 + BIT7;                     // P1.1 = RXD, P1.2=TXD
  •         P1SEL2 = BIT1 + BIT2 + BIT5 + BIT6 + BIT7;
  • void Serial_init()
  •         UCA0CTL1 |= UCSSEL_2;                     // SMCLK
  •         UCA0BR0 = 0x82;                              // 16MHz 9600 UCA0BRX=1666=0x0682
  •         UCA0BR1 = 0x06;                              // 16MHz 9600
  •         UCA0MCTL = UCBRS2 + UCBRS1;               // Modulation UCBRSx = 6
  •         UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  •         IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt
  • void SPI_init()
  •         UCB0CTL1 = UCSWRST;                       // **Put state machine in reset**
  •         UCB0CTL0 |= UCCKPL + UCMSB + UCSYNC;      // 3-pin, 8-bit SPI master
  •         UCB0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  •         IE2 |= UCB0RXIE;                          // Enable USCI0 RX interrupt
  • void Init_all()
  •         Clk_init();
  •         IO_init();
  •         Serial_init();
  •         SPI_init();
  • int main(void)
  •         WDTCTL = WDTPW + WDTHOLD;                 // Stop watchdog timer
  •         //while (!(P1IN & BIT5));                   // If clock sig from mstr stays low,
  •        // it is not yet in SPI mode
  •         Init_all();
  •         __bis_SR_register(LPM4_bits + GIE);       // Enter LPM4, enable interrupts
  • #pragma vector=USCIAB0RX_VECTOR
  • __interrupt void USCI0RX_ISR(void)
  •         temp = UCB0RXBUF;
  •     while (!(IFG2&UCB0TXIFG));                // USCI_A0 TX buffer ready?
  •     UCB0TXBUF = temp;                    // TX -> RXed character
  •         while (!(IFG2&UCA0TXIFG));                // USCI_A0 TX buffer ready?
  •         UCA0TXBUF = temp;                    // TX -> RXed character
复制代码
