- var GPS = {
- PI: 3.14159265358979324,
- x_pi: 3.14159265358979324 * 3000.0 / 180.0,
- delta: function (lat, lon)
- var a = 6378245.0; // a: 卫星椭球坐标投影到平面地图坐标系的投影因子。
- var ee = 0.00669342162296594323; // ee: 椭球的偏心率。
- var dLat = this.transformLat(lon - 105.0, lat - 35.0);
- var dLon = this.transformLon(lon - 105.0, lat - 35.0);
- var radLat = lat / 180.0 * this.PI;
- var magic = Math.sin(radLat);
- magic = 1 - ee * magic * magic;
- var sqrtMagic = Math.sqrt(magic);
- dLat = (dLat * 180.0) / ((a * (1 - ee)) / (magic * sqrtMagic) * this.PI);
- dLon = (dLon * 180.0) / (a / sqrtMagic * Math.cos(radLat) * this.PI);
- return { 'lat': dLat, 'lon': dLon };
- //WGS-84 to GCJ-02
- gcj_encrypt: function (wgsLat, wgsLon)
- if (this.outOfChina(wgsLat, wgsLon))
- return { 'lat': wgsLat, 'lon': wgsLon };
- var d = this.delta(wgsLat, wgsLon);
- return { 'lat': wgsLat + d.lat, 'lon': wgsLon + d.lon };
- //GCJ-02 to WGS-84
- gcj_decrypt: function (gcjLat, gcjLon)
- if (this.outOfChina(gcjLat, gcjLon))
- return { 'lat': gcjLat, 'lon': gcjLon };
- var d = this.delta(gcjLat, gcjLon);
- return { 'lat': gcjLat - d.lat, 'lon': gcjLon - d.lon };
- //GCJ-02 to WGS-84 exactly
- gcj_decrypt_exact: function (gcjLat, gcjLon)
- var initDelta = 0.01;
- var threshold = 0.000000001;
- var dLat = initDelta, dLon = initDelta;
- var mLat = gcjLat - dLat, mLon = gcjLon - dLon;
- var pLat = gcjLat + dLat, pLon = gcjLon + dLon;
- var wgsLat, wgsLon, i = 0;
- while (1)
- wgsLat = (mLat + pLat) / 2;
- wgsLon = (mLon + pLon) / 2;
- var tmp = this.gcj_encrypt(wgsLat, wgsLon)
- dLat = tmp.lat - gcjLat;
- dLon = tmp.lon - gcjLon;
- if ((Math.abs(dLat) < threshold) && (Math.abs(dLon) < threshold))
- break;
- if (dLat > 0) pLat = wgsLat; else mLat = wgsLat;
- if (dLon > 0) pLon = wgsLon; else mLon = wgsLon;
- if (++i > 10000) break;
- //console.log(i);
- //GCJ-02 to BD-09
- bd_encrypt: function (gcjLat, gcjLon)
- var x = gcjLon, y = gcjLat;
- var z = Math.sqrt(x * x + y * y) + 0.00002 * Math.sin(y * this.x_pi);
- var theta = Math.atan2(y, x) + 0.000003 * Math.cos(x * this.x_pi);
- bdLon = z * Math.cos(theta) + 0.0065;
- bdLat = z * Math.sin(theta) + 0.006;
- return { 'lat': bdLat, 'lon': bdLon };
- //BD-09 to GCJ-02
- bd_decrypt: function (bdLat, bdLon)
- var x = bdLon - 0.0065, y = bdLat - 0.006;
- var z = Math.sqrt(x * x + y * y) - 0.00002 * Math.sin(y * this.x_pi);
- var theta = Math.atan2(y, x) - 0.000003 * Math.cos(x * this.x_pi);
- var gcjLon = z * Math.cos(theta);
- var gcjLat = z * Math.sin(theta);
- //WGS-84 to Web mercator
- //mercatorLat -> y mercatorLon -> x
- mercator_encrypt: function (wgsLat, wgsLon)
- var x = wgsLon * 20037508.34 / 180.;
- var y = Math.log(Math.tan((90. + wgsLat) * this.PI / 360.)) / (this.PI / 180.);
- y = y * 20037508.34 / 180.;
- return { 'lat': y, 'lon': x };
- // Web mercator to WGS-84
- // mercatorLat -> y mercatorLon -> x
- mercator_decrypt: function (mercatorLat, mercatorLon)
- var x = mercatorLon / 20037508.34 * 180.;
- var y = mercatorLat / 20037508.34 * 180.;
- y = 180 / this.PI * (2 * Math.atan(Math.exp(y * this.PI / 180.)) - this.PI / 2);
- // two point's distance
- distance: function (latA, lonA, latB, lonB)
- var earthR = 6371000.;
- var x = Math.cos(latA * this.PI / 180.) * Math.cos(latB * this.PI / 180.) * Math.cos((lonA - lonB) * this.PI / 180);
- var y = Math.sin(latA * this.PI / 180.) * Math.sin(latB * this.PI / 180.);
- var s = x + y;
- if (s > 1) s = 1;
- if (s < -1) s = -1;
- var alpha = Math.acos(s);
- var distance = alpha * earthR;
- return distance;
- outOfChina: function (lat, lon)
- if (lon < 72.004 || lon > 137.8347)
- return true;
- if (lat < 0.8293 || lat > 55.8271)
- return true;
- return false;
- transformLat: function (x, y)
- var ret = -100.0 + 2.0 * x + 3.0 * y + 0.2 * y * y + 0.1 * x * y + 0.2 * Math.sqrt(Math.abs(x));
- ret += (20.0 * Math.sin(6.0 * x * this.PI) + 20.0 * Math.sin(2.0 * x * this.PI)) * 2.0 / 3.0;
- ret += (20.0 * Math.sin(y * this.PI) + 40.0 * Math.sin(y / 3.0 * this.PI)) * 2.0 / 3.0;
- ret += (160.0 * Math.sin(y / 12.0 * this.PI) + 320 * Math.sin(y * this.PI / 30.0)) * 2.0 / 3.0;
- return ret;
- transformLon: function (x, y)
- var ret = 300.0 + x + 2.0 * y + 0.1 * x * x + 0.1 * x * y + 0.1 * Math.sqrt(Math.abs(x));
- ret += (20.0 * Math.sin(x * this.PI) + 40.0 * Math.sin(x / 3.0 * this.PI)) * 2.0 / 3.0;
- ret += (150.0 * Math.sin(x / 12.0 * this.PI) + 300.0 * Math.sin(x / 30.0 * this.PI)) * 2.0 / 3.0;
- return ret;
加载百度地图的关键代码 <script type="text/javascript" src="//api.map.baidu.com/api?v=2.0&ak=您的密钥"></script>其他的代码都是配置代码了。
然后再JavaScript编写MQTT的协议就行了。
下面开始做MQTT初始化;XXXX为服务器地址,需要配置服务器为Wss,即需要证书。
- client = new Paho.MQTT.Client("XXXXX", Number(8084), GenNonDuplicateID());
连接MQTT,并订阅 Pos的位置。
//初始化客户端选项 conn_opts
client.connect({
onSuccess: onConnect
//连接服务器并注册连接成功处理事件
function onConnect() {
console.log("onConnected");
client.subscribe("pos", {
qos: 0
client.onConnectionLost = onConnectionLost;
client.onMessageArrived = onMessageArrived;
这里是添加标志的代码
- var myIcon = new BMap.Icon("__INDEX__/img/car.gif", new BMap.Size(20, 40));
- var point = new BMap.Point(lon, lat);
- var marker = new BMap.Marker(point, {
- icon: myIcon
未完待续。。。。。
