[应用相关] 主从硬件IIC
262|0
 楼主| jcky001 发表于 2021-1-5 14:20 | 显示全部楼层 |阅读模式
采用STM8S003F硬件I2C进行双机通讯,两个片子都使用内部16M,从机采用中断方式进行接收和发送数据(官方DEMO),主机是调用库函数向从机传数据。在主机里第一步就是检测总线是否忙,结果一直处于总线忙状态,从机也没有进入中断,硬件检查没接错线,是什么原因呢?
while(I2C_GetFlagStatus(I2C_FLAG_BUSBUSY))  ;                 // 等待总线释放    主机卡在这一直总线忙,从机进不了中断
从机初始化:
void main(void)
  Init_Clk();
  Init_IO();
  Init_Timer();
  Init_I2C();
  enableInterrupts();
while(1)
void Init_Clk(void)
  //  CLK_DeInit();
    CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
    CLK_HSICmd(ENABLE);         // 内部时钟默认8分频
//    CLK_HSECmd(ENABLE);
void Init_I2C(void)
     I2C_DeInit();
     I2C_Init(I2C_FREQUENCY, SLAVE_ADDRESS, I2C_DUTYCYCLE_2, I2C_ACK_CURR, I2C_ADDMODE_7BIT, 16);
     I2C_ITConfig( (I2C_IT_TypeDef)(I2C_IT_ERR | I2C_IT_EVT | I2C_IT_BUF), ENABLE);
     I2C_Cmd(ENABLE);
中断:
INTERRUPT_HANDLER(I2C_IRQHandler, 19)
  if ((I2C->SR2) != 0)          // 读I2C错误,清状态位。
    I2C->SR2 = 0;
    state1 = I2C_SR1;
    state2 = I2C_SR3;
    I2C_CR2 |= 0x04;
    LedStatus(1);       // Test
  WORD Event = I2C_GetLastEvent();
  switch (Event)
      /******* Slave transmitter ******/
      /* check on EV1 */
    case I2C_EVENT_SLAVE_TRANSMITTER_ADDRESS_MATCHED:
      Tx_Idx = 0;
      break;
      /* check on EV3 */
    case I2C_EVENT_SLAVE_BYTE_TRANSMITTING:
      /* Transmit data */
      I2C_SendData(Slave_Buffer_Rx[Tx_Idx++]);
      break;
      /******* Slave receiver **********/
      /* check on EV1*/
    case I2C_EVENT_SLAVE_RECEIVER_ADDRESS_MATCHED:      // 清接受地址
      //  Rx_Idx = 0;
          I2C->SR1;
          I2C->SR3;
      break;
      /* Check on EV2*/
    case I2C_EVENT_SLAVE_BYTE_RECEIVED:
      Slave_Buffer_Rx[Rx_Idx] = I2C_ReceiveData();
      break;
      /* Check on EV4 */
    case (I2C_EVENT_SLAVE_STOP_DETECTED):
            /* write to CR2 to clear STOPF flag */
            I2C->SR1;
            I2C->CR2 |= I2C_CR2_ACK;
      break;
    default:
     break;
主机:
void main(void)
  Init_Clk();
  Init_IO();
  Init_Timer();
  Init_I2C();
  enableInterrupts();
  IIC_WriteByte(SLAVE_ADDRESS, DATA_ADDRESS,TestDataIIC);
  while (1)
      Test();
void Init_Clk(void)
    CLK_HSICmd(ENABLE);
void Init_I2C(void)
     I2C_DeInit();
      I2C_ITConfig( (I2C_IT_TypeDef)(I2C_IT_EVT | I2C_IT_BUF), DISABLE);  //禁用中断
     I2C_Cmd(ENABLE);
void IIC_WriteByte(BYTE bDevice_ID, BYTE bwrite_Data_address, BYTE bData)
    I2C_GenerateSTART(ENABLE);                                  // 开始信号
    while( !I2C_CheckEvent(I2C_EVENT_MASTER_MODE_SELECT))  ;      // 等待应答 EV5
    I2C_Send7bitAddress(bDevice_ID, I2C_DIRECTION_TX);          // 写选择芯片地址
    while( !I2C_CheckEvent(I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED))  ;  // 等待应答 EV6
    I2C_ClearFlag(I2C_FLAG_ADDRESSSENTMATCHED);
    I2C_SendData(bwrite_Data_address);                          //  写芯片起始地址
    while( !I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTING) )  ;// 等待应答 EV8
    I2C_SendData(bData);                                        //  写数据
    while( !I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTED) ) ; // 等待应答 EV8_2
    I2C_GenerateSTOP(ENABLE);                                   // 停止信号
