1、查看LED1和LED2对应的GPIO口
2、对es32f369x的gpio操作 es32f369x的gpio的特别之处,可以配置CMOS或者TTL电平、是否输入滤波功能、配置驱动能力。
3、程序代码 - #include <string.h>
- #include "main.h"
- #include "md_syscfg.h"
- #include "md_cmu.h"
- #include "md_gpio.h"
- int main()
- md_gpio_init_t x;
- /* Configure system clock */
- md_cmu_clock_config_default();
- /* Initialize SysTick Interrupt */
- md_init_1ms_tick();
- /* Enable ALL peripheral */
- SYSCFG_UNLOCK();
- md_cmu_enable_perh_all();
- SYSCFG_LOCK();
- x.mode = MD_GPIO_MODE_OUTPUT;
- x.odos = MD_GPIO_PUSH_PULL;
- x.pupd = MD_GPIO_PUSH_UP;
- x.nodrv = MD_GPIO_OUT_DRIVE_1; //灌电流能力
- x.podrv = MD_GPIO_OUT_DRIVE_1; //拉电流能力
- x.flt = MD_GPIO_FILTER_DISABLE; //输入滤波功能
- x.type = MD_GPIO_TYPE_CMOS; //cmos或者ttl电平
- x.func = MD_GPIO_FUNC_1;
- md_gpio_init(GPIOF, MD_GPIO_PIN_0, &x);
- md_gpio_init(GPIOF, MD_GPIO_PIN_1, &x);
- md_gpio_set_pin_low(GPIOF, MD_GPIO_PIN_0);
- md_gpio_set_pin_low(GPIOF, MD_GPIO_PIN_1);
- while (1)
- md_delay_1ms(500);
- md_gpio_set_pin_high(GPIOF, MD_GPIO_PIN_0);
- md_gpio_set_pin_high(GPIOF, MD_GPIO_PIN_1);
4、blink
