报错信息如下, 这是怎么回事
Error connecting to the target:
Error 0x80000240/-2092
Fatal Error during: Initialization, OCS,
Device driver: Emulation Connection Loss Detected on Target CPU.
It is recommended to RESET EMULATOR.  This will disconnect each
target from the emulator.  The targets should then be power cycled
or hard reset followed by an emureset and reconnect to each target.
Sequence ID: 0
Error Code: -2092
Error Class: 0x80000240
I/O Port = 240
Board Name: F2810 XDS510 Emulator
Cpu Name: CPU_1
Abort:                Close Code Composer Studio.
Retry:                Try to connect to the target again.
Cancel:                Remain disconnected from the target
Diagnostic:        Run diagnostic utility. |
